Honda CR-V & Element 2WD & 4WD Element & CR-V
Compression testing a 2000 crv
Old Aug 5, 2017 | 06:02 PM
Simon Szuba's Avatar
Default Compression testing a 2000 crv
Hey guys, how do I safely disable fuel and spark to do a compression test on a 2000 CRV? I've Googled and YouTubed and can't find any info! Thanks guys!!
Old Aug 6, 2017 | 06:59 AM
ThisIsMatt's Avatar
Default Re: Compression testing a 2000 crv
In truth, you don't really need to disable spark. Yes, it's safer if you do, but if you just make sure the unplugged spark plug wire isn't anywhere near something it can arc to (including yourself), you're good. If you want to disable just the fuel supply, you can pull the fuel pump fuse. A quick google search should show you were that is, or you could check your owner's manual...if it still is (or ever was) in your possession. If you do want to disable both spark and fuel, there's a simple way. Behind your glove box you'll find something called the "main relay". This item is actually a common fail point in Hondas of the 90's. Its job is to enable both fuel and spark, so when it dies you'll get a no-start condition in which you'll lack both fuel and spark. That tends to be a dead give-away that the relay has failed. Usually with a no-start condition you'll only lose one of the two. Anyway, if you unplug this relay you'll disable both fuel and spark in one swell foop. Good luck!
FullOutPwr
Jul 17, 2014 04:46 PM
drb88
Aug 12, 2013 02:18 PM
brucepick
32
Nov 21, 2009 05:47 AM
Eg4-TuRbO
Jul 30, 2004 11:48 PM
