Honda CR-V & Element 2WD & 4WD Element & CR-V
Crankshaft Timing Belt Pulley stuck
Old 08-20-2017, 01:44 AM
crvglenn's Avatar
Default Crankshaft Timing Belt Pulley stuck
While changing my timing belt, I decided to attempt to remove the crankshaft timing belt pulley with a 3 jaw gear puller so that I can replace the crankshaft oil seal. Unfortunately, I broke one of the teeth on the timing belt pulley and now the car doesn't start. The repair manual says the pulley just slides off but I see a key deeply embedded in the slot of the pulley. I don't think the pulley will slide off until I can get this key out of the slot and I have sprayed it with heavy duty lubricant the past 2 days. Can anyone suggest the best way to approach this?
Any help/suggestion is appreciated.
hmtcrxsir
18
12-06-2014 03:17 AM
us31wking
08-21-2014 04:50 AM
hmtcrxsir
12-22-2009 10:21 AM
99blackdc2
07-28-2006 07:23 PM
Mover
06-29-2003 02:57 PM
Quick Reply: Crankshaft Timing Belt Pulley stuck
