Honda CR-V & Element 2WD & 4WD Element & CR-V
08 Element Engine Change
Old May 28, 2017 | 07:47 AM
quietjet's Avatar
Default 08 Element Engine Change
I'm changing the engine in my Element. Can I do this in the garage using jack stands and engine hoist (removal from below)--Or will I have to pull it out the top? Thanks...
Old Oct 18, 2022 | 08:40 PM
Mechanick303's Avatar
Default Re: 08 Element Engine Change
Depending upon if its automatic or manual determines removal method. If its a manual your gonna have to drop the cradle with engine and tranny on it, only due to the fact that you won't have enough room to clear the input shaft. If its automatic you can easily go through the top without having to really touch the tranny at all. It's actually not too bad, definitely doable at home. But if its manual your gonna need a lift forsure.
Armstrong57
29
Sep 16, 2007 11:44 AM
NatedoggAZ
Aug 13, 2007 08:23 PM
