Honda S2000 Honda S2000
Wiring in Accessories
Old Mar 16, 2009 | 11:32 AM
ExVtec's Avatar
Default Wiring in Accessories
I've got my AEM guage, and radar detector to wire in for power.
I've read that there is a spare fuse for such items, however I don't want to be ghetto and just jam the wires in there and push a fuse in. I like to solder/tape/etc. In the past I've always found other wires, what do you all do for power?
Thanks in advance.
Old Mar 16, 2009 | 01:20 PM
S2KFTW's Avatar
Default Re: Wiring in Accessories
I permanently wired my valentine 1 and two serial gauges to the spare terminals in the fuse box. if you look at the fuse box there's 2 or 3 accessory terminals. at least one has constant 12V power and at least one is only on when the key is in the on position. there's also two factory grounding points right near the fuse box to use.
Old Mar 16, 2009 | 05:27 PM
ExVtec's Avatar
I see the factory grounds, they are on the side...but I didn't see the 2-3 accessory terminals..??
Old Mar 16, 2009 | 05:44 PM
CXHATCHver2.2's Avatar
You could just get a splitter at advance or autozone. Has the wires and everything ready to go.
Old Mar 16, 2009 | 09:29 PM
ExVtec's Avatar
The fuse with wires coming out of it? Negative. I looked @ both places, they only have the larger fuses there..not the super small ones.
Old Mar 17, 2009 | 06:36 AM
That's weird. I was just in the Advance here yesterday and had the one with the small fuses in my hand. And I have one from Autozone in my hatch for the gauges. Just ask them if they can order it cause I know they both carry them.
Old Mar 17, 2009 | 07:58 AM
White Smoke's Avatar
i my honda
Global Mod
The accessory plugs looks kinda like the color ones here. This is a civic fuse box though.
There are two ways to tap into these fuse block outputs. The preferred way is to go the junkyard and find a mid-nineties Honda/Acura with power door locks. Under the driver's side door panel you can find a little brown plug that fits perfectly into the fuse outputs. Only the brown plug will work. The second way is to plug in a female quick disconnect. Don't forget you also always add an additional inline fuse.
Old Mar 17, 2009 | 05:26 PM
ExVtec's Avatar
Would a 99 Si have that plug?
I know where one is being parted out after it being totaled.
Old Mar 18, 2009 | 05:27 AM
i my honda
Global Mod
I am thinking no, but am not sure...
Old Mar 18, 2009 | 05:57 AM
ExVtec's Avatar
Damn you!!! I had my hopes up.
So, you are saying 92-95 Teg or Civic eh?
Old Mar 18, 2009 | 06:06 AM
i my honda
Global Mod
Yes... But you don't have to use that plug. A female disconnect works just fine as well.
Old Mar 18, 2009 | 06:25 AM
ExVtec's Avatar
Whats a female disconnect?
Old Mar 18, 2009 | 06:44 AM
i my honda
Global Mod
I would recommend an isolated version as seen here
Old Mar 18, 2009 | 07:00 AM
ExVtec's Avatar
Omg, I never thought about those things. I actually think I have some laying around...lol.
Thanks buddy.
Old Mar 18, 2009 | 08:06 AM
marty's Avatar
under the driverside of an AP1
E - parking lights activated power goes into that plug - i suppose to light up gauges
D - constant, so with or without a key its alwasy powered
C - ignition, with the key forward it is powered on.
Old Mar 18, 2009 | 08:33 AM
ExVtec's Avatar
Marty your pic is dead.
Old Mar 18, 2009 | 05:07 PM
ExVtec's Avatar
I found the quick disconnects while I was @ Home Depot. So I should be able to knock that out in the next few days.
Old Mar 18, 2009 | 05:19 PM
marty's Avatar
http://www.s2ki.com/forums/index.php...ic=295920&st=0
Go a few posts down on page one, It shows the same exact picture.
sony224422
Oct 5, 2005 06:09 AM
EliteRacer05
Aug 5, 2005 10:01 AM
FlaN.
Mar 16, 2004 12:31 AM
