Honda S2000 Honda S2000
Engine Pull or Engine drop?
Old Feb 10, 2009 | 04:20 PM
hon2984's Avatar
Default Engine Pull or Engine drop?
Hey whats up everybody. I new to the S2000 forum but not new to honda-tech. I have an S2000 in the shop with a spun rod bearing. We are getting a used F20C. The car is a 2000. I have done plenty motor pulls before and turn wrenches for a living. I do have access to ALL DATA. But for some reason the information on the engine removal is not listed. I havent yet been able to lift it and get a look from undernearth. From the looks of it it has to come out the bottom. It looks pretty tight to be disconnecting bell housing bolts on the top of the tranny. Any body have any advice?
Old Feb 10, 2009 | 05:28 PM
h_s's Avatar
h_s
Default Re: Engine Pull or Engine drop?
pull... the electronic steering rack assist may be a bitch to get around
Old Feb 10, 2009 | 11:09 PM
andre@raw's Avatar
I have work on many s2000 for years and to me is easier if you take the tranny out first and then pull the motor out the top (the motor and tranny togheter wont clear if you try to come out the top and if you drop it with the sbframe out the bottom to me seem s like a hell of a lot more work) If you're gonna take my advise just lower the subframe a little to be able to get to the top bolts and to make clear the transmission tunel.
G/L
Old Feb 11, 2009 | 04:36 AM
White Smoke's Avatar
i my honda
Global Mod
Take the trans off first and pull it out. There are plenty of trans removal links online. You have to lower the sub frame to get to the bolts.
Old Feb 13, 2009 | 04:05 PM
hon2984's Avatar
Much appreciated. Thanks
Old Feb 13, 2009 | 04:17 PM
MidwestAutoWorks's Avatar
damn we dropped mine through the bottom tranny attached and brought it up back throgh same way.. No issues. i did not have AC on mine which was the only difference
Old Feb 17, 2009 | 12:39 PM
rollinx25's Avatar
Either way is fine. We pulled mine out the top taking the tranny off first.
kb58
Honda S2000
12
Oct 17, 2005 01:14 PM
integ98_supraTails
Honda S2000
20
Jul 19, 2005 04:14 PM
integ98_supraTails
Jul 17, 2005 02:33 PM
swappin247
32
May 26, 2005 03:16 PM
.:Swig:.
Mar 14, 2004 07:03 PM
