Honda S2000 Honda S2000
Starter location???
Old Mar 9, 2009 | 09:14 AM
veilsides2000's Avatar
Default Starter location???
Okay so my car will start fine but then at any given moment it won't restart. I'll push start it, and when I make it home it will restart fine. I think the starter is on the way out, but I have no idea where it is.
Anybody have a diagram on where it is? And possibly a DIY write up. I searched but it didn't net any satisfying results.
I appreciate it a lot guys.
the car is MY02, and I jsut replaced the alternator and the battery. they are both brand new.
Old Mar 9, 2009 | 11:12 AM
Default Re: Starter location???
Bump?
Old Mar 9, 2009 | 12:50 PM
White Smoke's Avatar
i my honda
Global Mod
I don't have a picture but it's pretty easy to find. lol The starter is on the driver's side of the engine block, close to the firewall where the engine mates to the trans.
There are only 2 bolts holding the starter. But one of the bolts is a PITA to get to. You may need to pull the alternator and use a very long extension to reach it. Also, be very careful when using an extension... It will run just past the knock sensor, which is VERY fragile and pretty expensive to replace.
Old Mar 9, 2009 | 04:52 PM
Jason.H.'s Avatar
and make sure u disconnect the battery!
Old Mar 9, 2009 | 09:52 PM
thanks for the help! I guess Ill pull the knock sensor out before everything.
Ill try to do a write up with pics tommorow night from my friends shop.
Old Mar 9, 2009 | 10:39 PM
S2KFTW's Avatar
its where the tranny meets the engine block, driver's side under the intake manifold.
this shot gives you an idea where the starter is on the block, getting to it will suck. you'll most likely have to get the alternator out of the way and maybe the intake manifold just to reach it and replace it.
Old Mar 12, 2009 | 08:03 AM
Yeah It definitely sucked getting to it. What sucked even more is that the new new one won't work as soon as we got it in. It worked fine when we tested it but as soon as it was in the car..... the arm wouldn't pop out to start the car. The starter went bad, and now I gotta do the whole thing over again lol.
Old Mar 12, 2009 | 09:17 AM
S2KFTW's Avatar
oh man that SUCKS! you need to go and pimp slap the guy who sold you that thing!
Old Mar 12, 2009 | 09:34 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
ohhh for ****s sake... that sucks big time...
reminds me of when i was replacing my cap and rotor on my GSR... i replaced everything fine, started the car, let it warm up for a few mins went inside to grab a beer and when i came out it was off... i was like WTF... ended up being the ICM was fried... you try and fix one thing and another breaks...
Old Mar 12, 2009 | 10:40 AM
i my honda
Global Mod
Those ICM's are JUNK! You can eliminate them with an MSD
Old Mar 23, 2009 | 06:36 PM
Yeah... So the old starter has been working fine for the last 1.5 weeks, but just shat out on me today. Lets see if this new starter holds up.
ochsy03
Honda CR-V & Element
10
Nov 10, 2012 03:49 PM
geces23
May 11, 2006 01:13 PM
94AcuraIntegraGsr
Apr 8, 2006 02:25 PM
rafiq7
Dec 14, 2004 07:46 AM
Chairman Kaga
Oct 28, 2002 04:23 PM
