Honda S2000 Honda S2000
Kpro S2k install (extra sensors)
Old Mar 11, 2009 | 05:19 AM
vtec lag's Avatar
Default Kpro S2k install (extra sensors)
I want to switch to a Kpro set up but was worried that i wont be mechanically inclined to install all those extra sensors needed. I know nothing about the sensors if its hard or easy ( ive read that its hard work) does anyone have a write up on this?
Old Mar 11, 2009 | 06:31 AM
papa5murf's Avatar
Default Re: Kpro S2k install (extra sensors)
It's easy if you're mechanically inclined. If you're not confident in your mechanical ability, then have a shop do it for you.
Old Mar 11, 2009 | 06:34 AM
vtec lag's Avatar
Mmm well i have removed and installed my cylinder head+timed and adjusted my valves all on my own. This shouldn't be a problem then maybe im just a bit paranoid that i would mess something up.
Old Mar 11, 2009 | 03:07 PM
papa5murf's Avatar
If you can do that, you can do the sensor change. It's basically just taking one off and replacing it with the new updated version. You have to take the valve cover off, but then again, you've adjusted valves so you should be fine.
Have a helms manual with you, and you're set.
Old Mar 11, 2009 | 04:02 PM
vtec lag's Avatar
Yeah i got the manual i guess i am good to go Thanks for your input man.
Elgrys.Mendez
12
Jun 25, 2010 01:04 AM
ALLMOTOR CRX
Jun 1, 2007 06:52 PM
rukawa1one
Feb 24, 2004 11:45 AM
GSlowR
Aug 27, 2001 08:58 PM
