Honda S2000 Honda S2000
Sandwhich Adapter
Old Feb 16, 2009 | 12:08 PM
ExVtec's Avatar
Default Sandwhich Adapter
Turbo install:
I was thinking of using an oil sandwhich adapter where the filter goes. Would a regular Honda adapter work ok?
I'd still leave the stock cooler in place as well.
Thanks in advance.
Old Feb 16, 2009 | 12:59 PM
ExVtec's Avatar
Default Re: Sandwhich Adapter
I found one for 30 bucks..so I picked it up.
Shall see what happens.
Old Feb 16, 2009 | 04:33 PM
White Smoke's Avatar
i my honda
Global Mod
Depends on the manifold you are running. Many manifolds require the filter to be removed or leave very little room for a sandwich. I HIGHLY recommend getting a re-location kit. Most people remove the factory oil heat exchanger and replace the threaded stud thing with a shorter one from another make honda (required when remove the exchanger).
Old Feb 16, 2009 | 04:56 PM
dagle's Avatar
yep, best invention ever. oil change is even more of a breeze
Old Feb 16, 2009 | 07:19 PM
ExVtec's Avatar
I appreciate the information, but this has nothing to do with me. I have a top mount so moving my filter is of no concern to me
I ordered the adapter, and will run my feed from it.
Old Feb 16, 2009 | 07:49 PM
SuzukaBlueAP2's Avatar
ExVtec: what brand sandwich adapter did you get?
what relocation setup do you have?
Old Feb 16, 2009 | 08:31 PM
ExVtec's Avatar
Only 2 I've seen are Blox & GE.
I grabbed a Blox from streetrays.com Only thing I've heard is that you need to have them on tight.
mhoang7
Honda Civic (2001 - 2005)
10
Jun 9, 2008 02:11 PM
Halo
26
Jul 4, 2006 04:43 AM
Blackack26
Dec 7, 2003 09:40 PM
Dirt
Sep 5, 2002 02:05 PM
no_limit
Aug 2, 2001 03:44 AM
