Honda S2000 Honda S2000
s2k ckp question.
Old Jan 21, 2009 | 07:58 AM
crave13k's Avatar
Default s2k ckp question.
so im getting a p0339 and p0339 (pd). which is the ckp. i erased the code with my scanner and swapped my crank position sensor with a friend but im still getting the same code. can anyone tell me what to check for? i checked the plugs and ground connections but they seem fine. please help.
Old Jan 21, 2009 | 09:14 AM
TreyDM's Avatar
Default Re: s2k ckp question.
Well if the sensor is ok, check the reluctor ring teeth, in which the sensor receives input from, for debris or broken and bent teeth. If thats not your culprit, check the wiring circuit. If all else fails replace the ecm.
Old Jan 21, 2009 | 09:57 AM
crave13k's Avatar
how do u check the wiring circuit
sh!ft
Oct 10, 2012 08:57 PM
enigma94
Jun 15, 2004 07:12 PM
xci_ed6
11
Apr 16, 2004 01:04 PM
devonic
Apr 24, 2003 11:15 AM
