Honda S2000 Honda S2000
problem with Skunk2 springs on AP2...
Old Mar 11, 2009 | 12:10 PM
Curry_Spice's Avatar
Default problem with Skunk2 springs on AP2...
Hey guys I am posting this for my brother. He has an 04 AP2 and put his springs on today, but for some reason the passengers side sits higher than the drivers side. Has anyone else run into this problem? Maybe they need to settle? Any insight is greatly appreciated!
Old Mar 11, 2009 | 12:57 PM
bigmacnfries's Avatar
Default Re: problem with Skunk2 springs on AP2...
side to side should be even - they're probably on wrong
Old Mar 11, 2009 | 01:11 PM
White Smoke's Avatar
i my honda
Global Mod
Has the car been wrecked? What about recent alignments?
Old Mar 11, 2009 | 01:13 PM
nope car is pristine, my broski called skunk2 and they said that set was not preloaded and you need to cut the bump stops off, so we'll go from there....
Old Mar 11, 2009 | 01:17 PM
preloading's gonna help
Old Mar 11, 2009 | 01:48 PM
how would you guys go about preloading them?
Old Mar 11, 2009 | 01:54 PM
iHEARTmyFERIO's Avatar
IIRC....
preloading the suspension means resting the car's weight on the suspension prior to tightening up the bolts. this is done by either tightening the bolts when the car is already on the ground, or by lifting up each wheel using jackstands to pre-load the suspension while you tighten up the bolts (tophats, shock towers, etc; everything you unbolted to install).
if i'm wrong, please feel free to correct me. i'm considering the purchase of tein s-techs and would also need sound advice on how to install them properly.
Old Mar 11, 2009 | 11:32 PM
iam7head's Avatar
Originally Posted by iHEARTmyFERIO
IIRC....
you are right on preload.
cutting the bumpstop will not do anything about static ride height tho
98-black-GSR
Oct 24, 2013 10:46 PM
dc2JDMwhore
May 5, 2010 06:24 AM
mortificationrock
Mar 18, 2010 04:19 AM
95BoostedEJ1
Suspension & Brakes
May 29, 2009 06:43 PM
Havokgsr
Apr 8, 2003 11:45 PM
