Reving at 7200rpm which it suppose to be 7900rpm
Old 04-19-2012, 08:15 AM
rvang10dc5's Avatar
Icon2 Reving at 7200rpm which it suppose to be 7900rpm
Having problems with my rsx. I change out the starter since it dead on me. After that car won't start. change the ground wire and car starts fine. Was testing the car out to see if anything was wrong. So took it out for a run and was redlining at 7200rpm. The check engine been on but when i first had it, it the cel been on and was redline at 7900. Got any idea what is wrong? The cel throws out p0420.
Old 04-19-2012, 06:33 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: Reving at 7200rpm which it suppose to be 7900rpm
Did you disconnect the battery when you took everything apart to change the starter?
Clear the code once and take it for a spin
then stop abusing your car and fix the problem causing your CEL.........
EFmine
09-11-2013 02:50 AM
biev
06-26-2007 03:30 PM
DarkBB4
04-23-2007 10:47 AM
teknikEG6
04-15-2006 03:04 PM
BigDawwg6969
10-05-2003 10:08 AM
Quick Reply: Reving at 7200rpm which it suppose to be 7900rpm
