2004 crv crank no start
Hey.
2004 crv k24 crank no start. Replaced battery crank is speedy and sounds good. Replaced fuel pump have pressure at rail. Replaced spark plugs because they were old and shitty. Can hear the relays clicking on.
green key light on dash goes out. No check engine codes.
any ideas? I dont know what other sensors or whatever are in here that would cause this and not throw a code.
Pretty sure its not getting spark now based on this so leaning to like ignition switch but it cranks.
Edit. Pulled intake off to try starter fluid. Still didnt light up but now it has a p0113 iat sensor 1 circuit high.
Re: 2004 crv crank no start
P0113 might indicate that you didn’t plug something back in on the intake? Or possibly damaged the sensor/wiring for it. Check it out.
Check the maroon/burgundy/red relay behind the glovebox. Tap on it, remove and reseat, if it still doesn’t start - I’d test that relay. Same thing happened to my 02 randomly, and I didn’t get spark while cranking.
Replaced cps and that brown relay. Still crank no start. Gauge cluster kind of freaked out for a bit there when i first tried to start it the needles were shaking. But now its not doing it anymore.
deepdownpaul
11-05-2009 09:21 PM
