Ek Rhd k20a Jdm no start has all 3 components
Hey guys, this is a last resort situation. I have a Jdm k20a in a Rhd ek hatch. I'm using a 02-04 k20a2 harness with a matching ecu (kpro) with a hasport sub harness. A z1 tranny, and a cut rbc with a z1 throttle body. The car used to run fine, then I upgraded to a cut rbc, and z1 tranny. The car started up fine, but was throwing out a lot of dust from when I powder coated the rbc and valve cover. I took them off and sprayed them with compressed air, put everything back on, and now no start. Engine cranks, I have fuel pressure, I have spark, compression, and injector impulse, but NO START. the timing chain is spinning, and the indicator light on the ecu is green. I dont know what else to do? Any help is appreciated no codes thrown either
Re: Ek Rhd k20a Jdm no start has all 3 components
Try some starter fluid into the intake. See if it fires up. If it does, its a fuel problem. If it doesnt, its something else (ignition, timing, etc.).
Found out my problem after having sooooo many months off torture from not knowing. It was my compression, after testing it with a good gauge, compression readings were 30-60-0-0. Bought a new swap waiting on delivery
kyle_civic
11-30-2006 01:26 PM
