Engine direction of rotation
Old Jan 7, 2015 | 06:59 AM
genuser's Avatar
Default Engine direction of rotation
Hello. Just joined the site. I thought I will start with a couple of simple questions.
Out of curiocity, I was reading about direction of engine rotation. I read that Honda engines are some of the few that rotate counter-clockwise (when viewed from flywheel side). I looked at my 2014 CRV from the pulleys side (it has the K24Z7 engine). The crank pulley seems to be rotating clockwise. So the flywheel must be rotating counter-clockwise, when viewed from flywheel side.
Is this correct for K24Z7?
Are all K-series engines CCW including the DIG K24W?
Thank you.
Old Jan 7, 2015 | 09:02 AM
hondamark35's Avatar
Default Re: Engine direction of rotation
always from the crank pulley side.
you were reading some general stuff. not all Hondas are CCW. The D, H, F (except F20C) and B-series run CCW. All V6 (C and J-series) and newer I4s, K, R and L-series run CW like most other engines.
Old Jan 7, 2015 | 09:22 AM
genuser's Avatar
Thank you.
Yes, I was reading this "authoritative" source :-) What Car Engines Rotate Anti-Clockwise? | eHow
Blaze45
Jan 6, 2012 09:17 AM
slide inside
Jul 11, 2010 01:19 PM
kadidle
Aug 14, 2008 04:03 AM
altoid
Jun 27, 2003 12:34 AM
