ram header dimensions
Old Nov 14, 2013 | 07:03 PM
GSRinmyCRX's Avatar
Icon2 ram header dimensions
anyone out there with a ramhorm k-tuned or plm header mind taking some measurement for me. everyone says that it wont fit in a crx but i think there is enough room with tucking everything that is on the fire wall. can someone take a measurement from the head flange to the point furthest back on the header.
Thanks.
Levi
Old Feb 5, 2014 | 03:54 AM
shiplet89's Avatar
Default Re: ram header dimensions
Bump on this^ I would love to know also bc I am currently piecing my swap together
Old Mar 12, 2014 | 11:42 AM
GSRinmyCRX's Avatar
updated. i picked up the headers and they clear the firewall no problem. i had to trim the cross member a little bit but nothing major.
Thanks.
Levi
Old Mar 12, 2014 | 05:57 PM
EG6_LS_BOOST's Avatar
Can u put some pics and what u have to take out front the firewall to make then fit
Old Mar 13, 2014 | 04:24 AM
GSRinmyCRX's Avatar
i cleared everything off my firewall since i am going to do a mild shave and brake/ wire tuck with this project. i do think it will fit if you leave the brakets that are welded on the firewall. my crx is currently under construction but i will look and see if i have any pictures saved of it installed.
Levi
Old Mar 13, 2014 | 03:42 PM
CHU-JDM-DC2's Avatar
Ok thank you
Old Mar 14, 2014 | 04:23 AM
GSRinmyCRX's Avatar
the angle on the second picture makes it look like it is going to hit the crossmember a lot but i only had to trim about a 1/2-inch off the front edge. yes i know the shell looks real nasty its a work in progress.
i am using innovative mounts.
Levi
Acura4life5
Dec 31, 2014 01:30 PM
dinko
Jun 25, 2007 10:01 AM
K.Quinn
Jun 22, 2006 10:39 AM
nsmB16
May 7, 2005 11:58 AM
