Honda Fit Honda Fit (Jazz)
Adding 12 volt Outlets
Old Aug 6, 2014 | 04:35 AM
SilverEX15's Avatar
Default Adding 12 volt Outlets
I usually add a separate fuse block inside the car so I can install additional 12v outlets and accessories. Is there an easy way to get a wire from the battery through the firewall in a 2015 Fit?
Old Aug 6, 2014 | 05:28 AM
burnoutboy's Avatar
The Credible Hulk
Default Re: Adding 12 volt Outlets
I just used one of these and a Marinco 12V ACC socket in my EG.
Put it in the original fuse for the lighter and add a fuse of equal value for the new socket. Bada bing, bada boom DONE.
Old Aug 6, 2014 | 08:00 PM
claymore's Avatar
Look to where the A/C hose go into the cabin. Tape the wire you want to use to a straightened coat hanger. Carefully push the hanger along the hose into the cabin go inside or have someone inside pull the hanger until the wire is inside.
Old Aug 11, 2014 | 05:48 AM
SilverEX15's Avatar
Clever.
Old Aug 11, 2014 | 05:51 AM
SilverEX15's Avatar
Do you have a link for that? Is it for the small size fuses?
Got it!
Amazon Amazon
Old Aug 11, 2014 | 07:47 PM
claymore's Avatar
Just go to your local auto parts store and pluck the one you want off the shelf.
Old Aug 18, 2014 | 03:36 AM
SilverEX15's Avatar
I found a spot above the passenger's feet and ran a wire through there from the battery. A chopstick poked through the grommet, with a wire taped to it. That went to a fuse block and two 12v outlets. I decided to put a switch in one of the blanks on the left to turn the fuse block on and off, just for safety. I found these on Amazon, made by Laser Blue.
http://www.amazon.com/s/ref=nb_sb_no...lue%20switches
emooheo
Audio / Security / Video
11
Oct 6, 2010 05:53 AM
edwinbaby
Sep 7, 2010 02:08 PM
gsrstyle
Oct 13, 2003 03:42 PM
PatrickGSR94
Apr 6, 2003 05:46 PM
95gsr
Sep 18, 2001 09:25 AM
