service manual issue?
I hav been working on fixing a problem with my wifes 07 Fit. I am trouble shooting a p0717 code witch is a main input shaft speed sensor issue. The problem I came to was this. On page 14-114, step 30 tells you to check the voltage between t of the pins at the comuter and says something to the effect " do you get 0 volts or 5 volts. Then it says if yes got to_____ or No go to ______. If you have a service manual and look it up you will see what I am talking about. T question is should I be getting 0 volts or 5 volts? One of the next steps does have it written as a range of voltage (something like 1.5 -3.5 volts). anyon seen this and or gotten any clarification?
Steve91
10-24-2003 11:20 PM
