Honda S2000 Honda S2000
nsx wheels
Old Nov 9, 2009 | 07:39 PM
N_Vigz's Avatar
Default nsx wheels
anyone got pics of the 16/17 inch NA1 wheels on an S?
i've seen the pic of the GPW slammed on 'em but more pics must be floating around.
im debating refinishing the set i got..
-Nick.
Old Nov 10, 2009 | 05:23 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: nsx wheels
search...
Old Nov 10, 2009 | 05:48 AM
S2KILLA's Avatar
https://honda-tech.com/forums/showth...&highlight=nsx
Old Nov 10, 2009 | 09:05 AM
N_Vigz's Avatar
you just did it for me, thanks.
Old Nov 10, 2009 | 09:19 AM
S2KILLA's Avatar
no ****... i was just pointing out the fact that it was very easy to do it and instead youve made another useless thread...
Old Nov 10, 2009 | 09:46 AM
sixsixsix's Avatar
OneWayHighway
http://lmgtfy.com/?q=NSX+Wheels+on+S2000
and vise-versa
Old Nov 12, 2009 | 09:52 PM
allenborder's Avatar
New User
hi there...
I just got new 18/19 wheels that require a 5 mm spacer in the front. Do I also need to change out my studs to longer ARP studs? Where do I buy them at?
Also right now I have the spacer that one of those cheapers ones, I heard they are better spacers I can use but they cost like $100 can someone tell me which ones are those and where I can buy them. Sorry for my lack of knowledge in spacers and studs, its confusing me. Also there is a black center ring I think they call it. Which is a big o rubber ring, whats that called and where can I buy it as well. When you put new wheels on these are the 3 things to add correct ?
Old Nov 13, 2009 | 08:32 AM
sixsixsix's Avatar
OneWayHighway
Originally Posted by allenborder
hi there...
A 5mm spacer would be the absolute limit to run on stock studs. If you have the cash to spare, Id definitely do it the right way and change out the stock studs for longer ones. Safety first.
"Project Kics" makes a quality spacer kit that includes the extended studs. Unfortunately, the smallest they offer is a 10mm.
"H&R" also makes a quality spacer kit w/ extended studs for the S2000. They do offer a 5mm spacer.
The black ring you speak of is a Hubcentric ring. Im guess you can find those at your local Tuner shop. If the wheel itself is hubcentric, then there's no need to run the rings.
Btw. Are you putting 18"/19" wheels on a S2000? Are you crazy???!!!
Old Nov 13, 2009 | 12:02 PM
S2Carbonworks's Avatar
You should polish and anodize them
Old Nov 14, 2009 | 10:53 AM
N_Vigz's Avatar
meh.
i think im gonna do em white, not into the whole polished look.
Old Nov 17, 2009 | 12:10 PM
Midnight Run's Avatar
looks ok..
Old Nov 19, 2009 | 01:18 PM
s4play's Avatar
Straight on view:
NSX rims from the rear side view:
Side profile – Tires are 245/40 in the rear and 215/40 up front (plan to use some 10mm spacers up front)
And lastly my favorite shot:
Lzonk
Honda S2000
Jul 21, 2010 02:01 PM
gfhb4s2000
Honda S2000
Jul 7, 2006 07:16 PM
Rob Dizzle
Jan 5, 2004 12:15 PM
