Honda S2000 Honda S2000
s2000 dash help
Old Oct 17, 2009 | 03:21 PM
FEDONV8's Avatar
Default s2000 dash help
hey guy i am reinstall a new dash in my home boy s2000 can anybody tell me how rough the situation is or where to start before i start wrong. droppiing the steering column bad idea or what?
Old Oct 18, 2009 | 05:52 AM
N_Vigz's Avatar
Default Re: s2000 dash help
i've heard you do not need to drop the column, removing the wheel will be necessary though. i will be tackling this project soon too. good luck!
Old Oct 18, 2009 | 07:33 PM
powerhouse fab's Avatar
New User
I would start by droping the column (4 bolts) and even take it out to give you some room! another bolt on the steering joint and just unplug the connectors.
next; cluster, pass air bag, radio cover...
Old Oct 19, 2009 | 06:32 AM
White Smoke's Avatar
i my honda
Global Mod
dropping the steering column is not a bad idea, but you might be able to do the swap w/o dropping it. The wheel would have to be removed thought for sure. Dropping the column is easier then removing the wheel. You have to drop the column just to change the cluster...
Old Oct 19, 2009 | 06:26 PM
S2Carbonworks's Avatar
I have pulled the dash out of my s2000 3 times now, and it is not necessary to pull the steering column, or even touch it.
Just pull the wheel, gauges, radio, a pillars, and air bags. Then disconnect all the harness on both sides of the fender/footwells. Then just lift the dash out. Takes me about 3 hours to do it, and about 2.5 to put it back in.
Old Oct 19, 2009 | 07:17 PM
N_Vigz's Avatar
disconnect the battery first of course!
Jap_Spec_Imports
Aug 11, 2009 06:33 AM
JDM_EK4_Coupe
Honda S2000
May 26, 2007 12:30 PM
JdmAcclude
Apr 13, 2007 09:32 PM
StraightCivic
Mar 6, 2005 07:32 PM
