Honda S2000 Honda S2000
AP2 ballast question
Old Oct 13, 2009 | 08:43 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default AP2 ballast question
No, this is not "can you put AP2 headlights on a AP1.
I'm doing the AP2 headlight swap. I was originally going to mod headlights to fit the AP1 ballasts. But I think that later down the road, there will be moisture and rattling issues.
I found AP2 ballasts for $315 with igniters (both). So I bought the AP2 ballasts to reduce head aches. I'll make my money back selling the AP1 ballasts anyway (hopefully).
ANYWAY the AP2 needs a small section of wire to attatch the ballast to the car's harness.
It's honda part number 33147-S2A-A11.
It is in this illustration. Part number 14.
I don't have this harness and it's a little pricey from Honda. Does anyone know if it's just wires or is there a resistor in there as well?
If it's just wires, I can find the plugs from a junkyard. They look like either VTEC plugs or reverse switch plugs. Honda uses a lot of the same plugs on a lot of stuff...so...I'm sure I could find a solution if it's just wires.
If there's a resistor in it, how many OHMs is the resistor? The AP1 wiring looks like there's a little resistor there. But it's a totally different ballast with totally different wiring.
Finally...does anyone know of any harnesses for sale?
Old Oct 15, 2009 | 08:16 PM
B serious's Avatar
Default Re: AP2 ballast question
I actually found out some stuff. Hopefully this will help people in the future:
I was right. The plugs are the same as civic/integra/other model reverse switch plugs. The ones located on the harness clipped to the transmission on civics/integras. Manual ones at least. I'm not sure if the automatic ones are the same.
You need 2 male and 2 female for 2 headlights. There is no resistor in line. It's just wires.
You can make your own harness by raiding 2 cars at a junkyard. Save $46 per harness or $32 per harness depending on where you get it from. That's a ridiculous price to pay for 2 freaking wires.
Old May 24, 2011 | 10:21 AM
White Smoke's Avatar
i my honda
Global Mod
Found this in a search, good reference info!
SlamsItIn
Lighting
Aug 7, 2013 11:22 AM
SlamsItIn
Spug
Feb 5, 2012 08:43 AM
freshvibes
Jan 22, 2010 06:56 PM
loki2323
Audio / Security / Video
Sep 6, 2005 07:52 AM
