Honda S2000 Honda S2000
New Flywheel with First Clutch Job?
Old 10-06-2009, 06:42 PM
Ralleh's Avatar
Default New Flywheel with First Clutch Job?
Little over 40K on an AP1 and replacing the clutch with an OEM one. I'm wondering if anything needs to be done to the flywheel or if I can just replace it in another 40K or however long this clutch lasts.
Old 10-07-2009, 04:08 AM
i my honda
Global Mod
White Smoke's Avatar
Default Re: New Flywheel with First Clutch Job?
The FW should be fine, but check it for scoring or other damage. If necessary, just have it resurfaced.
Old 10-07-2009, 04:16 AM
HondaKyle's Avatar
my flywheel was fine when I changed my clutch out with 72K miles...
Old 10-07-2009, 12:26 PM
4doorH22's Avatar
I don't know of anyone who's had to replace a flywheel due to normal wear and tear, but I don't know anyone with real crazy HP. Your flywheel should last a real long time. 9 out of 10 people probably just slap on a new clutch without resurfacing it without any problems. Obviously if you wanted to put on an aftermarket lightweight flywheel clutch change is the best time.
Old 10-08-2009, 10:04 AM
ExVtec's Avatar
I ALWAYS resurface a flywheel when you install a new clutch.
Cost about 30 bucks and can usually be done the same day, if not pick it up the next day.
Do it right or do it twice.
Old 10-08-2009, 10:43 AM
dagle's Avatar
^-- or better yet toss in the flywheel with brake rotors or other items and get a nice bundle deal. most machinists own their equipment and welcome return customers!
Old 10-08-2009, 10:58 AM
Ralleh's Avatar
So most machine shops can do this no problem? You don't have to take it somewhere special?
Old 10-08-2009, 11:23 AM
SirStig's Avatar
It sounds good in theory. I'm not sure about where you are but I brought my flywheel to get resurfaced at a machine shop that did mostly rotors and they totally messed it up somehow. I brought it to a clutch shop to get it machined right.
Old 10-08-2009, 01:08 PM
mikey3165's Avatar
i say if you need to resurface it you might as well just get a new one cuz i got mine resurfaced and idk if they might have cut to much or what but my clutch started slipping soon after cuz there wasnt much flywheel surface left but i recommend just buy a new one if you have to resurface it even if it is oem
Old 10-08-2009, 04:14 PM
SirStig's Avatar
nah you can resurface a couple times. If you bring it to a clutch shop, they will let you know when you need a new one. Much more cost efficient to recut it. only 25 bucks when i did it
Old 10-10-2009, 07:47 PM
mymomsdrunk's Avatar
the factory service manual does not recommend resurfacing the flywheel, if your going to separate the engine/trans id suggest replacing everything at one time, it is about an 5-8h project...
Old 10-13-2009, 05:40 AM
ExVtec's Avatar
I've resurfaced the flywheel for every clutch swap I've ever done.
A few clutches had special instructions on what they wanted.
The s2k has had it's resurfaced as well.
B_Swapped93
04-04-2013 06:30 PM
UNKNOWN_MEMBER
06-30-2005 09:45 AM
StolenTeg
08-03-2004 10:33 PM
dynamo
05-13-2004 07:46 AM
JohnR265
10-12-2001 04:16 PM
Quick Reply: New Flywheel with First Clutch Job?
