Honda S2000 Honda S2000
Map sensor
Old Sep 1, 2009 | 10:14 PM
chasmataz's Avatar
Default Map sensor
I have posted my vtec problems here on different threads , but i was wondering , how do you test the connector to the map sensor? I did replace the map , and no changes with the vtec working but is it possible its bad wires etc to the map.
Old Sep 2, 2009 | 12:08 AM
im a monster hehe's Avatar
Default Re: Map sensor
here is a picture of the map censor.
are you sure you checked the right map censor?
Old Sep 2, 2009 | 07:11 AM
chasmataz's Avatar
Nope nvr checked this one lol
Old Sep 3, 2009 | 04:56 PM
BryanM.'s Avatar
Resident Gearhead
Very serious situation lol
Old Sep 3, 2009 | 05:38 PM
bigmacnfries's Avatar
america is satisfactory? haha...
Old Sep 9, 2009 | 08:33 PM
chasmataz's Avatar
bump
Old Sep 9, 2009 | 09:53 PM
da9driverx's Avatar
three cables most like a ground, signal and source i dont eaxctly what the signal wire voltage is sopouse to read but if you have a digital multi meter with the switch on and engine off check for a ground to read 12v and signal wire (one of the two left) and write down the reading you get the conect it start the car prop the one with out the signal and check the voltage the call your local honda dealer and compare volt readings with them that will tell you if your map is good:}
fancyfruitcup
Mar 19, 2014 08:57 PM
carlos8
Engine Management and Tuning
Dec 26, 2013 01:15 PM
rnbguy
Jan 20, 2008 03:46 PM
aldong
Oct 8, 2006 06:15 PM
SpoolnByYou
Dec 24, 2005 02:35 PM
