Honda S2000 Honda S2000
ap1 vs ap2 suspension!
Old Sep 18, 2009 | 07:01 PM
esean93's Avatar
Default ap1 vs ap2 suspension!
which one has a stiffer spring rate?i want a oem quality ride but would like if my springs were a bit stiffer.i have a ap1 btw
Old Sep 18, 2009 | 07:05 PM
Boots's Avatar
Default Re: ap1 vs ap2 suspension!
ap1
Old Sep 18, 2009 | 08:14 PM
-=Zeqs=-'s Avatar
Ya, AP1 is suppose to be more "pure" of a sports car.
Old Sep 18, 2009 | 11:24 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
ap2 CR
Old Sep 19, 2009 | 03:41 AM
Francesco's Avatar
Originally Posted by jdm_dc_fan
ap2 CR
I guess the OP didn't take this option into consideration.
Old Sep 19, 2009 | 03:52 AM
HondaKyle's Avatar
ap1... I think the CR is the same or really close to the AP1
Old Sep 19, 2009 | 07:42 AM
esean93's Avatar
ap1 is indeed a more "pure" of a sports car.the feel of it is much better,but lets not get into this.
i didnt consider the cr but edmunds say that the springs are stiffer than than the 08 by 38% front and 17% rear.the damping rates are up by 50% front and 32% rear.the cr suspension seems much more appealing.where can i find some?
Old Sep 19, 2009 | 08:35 AM
Boots's Avatar
ap2 CR
you know they have the same spring rate, right?
Old Sep 19, 2009 | 08:47 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
in the rear they are, but the CR is WAY WAY WAY stiffer up front.
Old Sep 19, 2009 | 10:30 AM
-=Zeqs=-'s Avatar
www.thehardtopguy.com
you can find some CR suspension there.
Old Sep 19, 2009 | 10:44 AM
esean93's Avatar
Old Sep 19, 2009 | 10:53 AM
Boots's Avatar
from everything ive read or heard, AP1 spring rates are the same as the CR, perhaps i was misinformed
Old Sep 19, 2009 | 10:57 AM
esean93's Avatar
thanks for the link!does anybody know how the cr rides compared to coilovers that are around 1000$?anyone driven a cr?
Old Sep 19, 2009 | 03:00 PM
jdm_dc_fan's Avatar
seems to happen alot on HT
Old Sep 19, 2009 | 03:05 PM
jdm_dc_fan's Avatar
thats a broad statement. for 1k you can have shitty ride quality or decent ride quality.
to answer your question CR suspension should only be a little different from your ap1 but in a better way. If you dont reaserch your coilovers and cheap out, you can actually handle worse than a oem cr springs.
from the sound of it OP, it seems that you want to make your car handle better but not daily drive stiff suspension. i recomend just getting eibach pro kit until you decide to step up to coilovers. they have similar spring rates to the CR, lowers your car 1" and is still smooth for DD. and ive seen them go for 100$ used.
Old Sep 19, 2009 | 03:39 PM
Francesco's Avatar
I can't find any rates online to compare CR with the ap1/ ap2. For the most part online is stating the fronts are stiffer, but they are also stating they are stiffer due to the thicker sway bar as well as the possibility of different spring rates.
Old Sep 19, 2009 | 03:57 PM
Rodney's Avatar
anyone driven a cr?
i have a cr and a base model 07. cr is much rougher then the base. i put ap1 wheels on the cr to soften the ride a bit, as well as pulling a 1000# trailer, but you def know you are in a CR.
00-01 - Fr: 218(3.9) - Rr: 291(5.2)
02-03 - Fr: 240(4.3) - Rr: 230(4.1) Guestimate
2004 - 2007
If calculated against 02-03 rates
Fr: 256(4.57) - Rr: 207(3.7) (guestimate)
2005 - 2008
Fr: 275 (6.7) - Rr: 226 (5.8)
2008 CR
Fr: 377 (8.6) - Rr: 264 (6.4)
this is common data found online, BUT one of my competitors has tested the front springs and found his CR were a touch over 400#.
Old Sep 19, 2009 | 04:40 PM
esean93's Avatar
you are exactly right!i want it to handle nice but not completely untolerable as a daily.sooner or later,i will go with coilovers so i wont buy springs for now and go through the trouble of swaping them and getting an alignment.im just going to go with a nice set of coilovers for a 1k.
im assuming i will have to buy cr shocks and springs,and that the ap1 shocks cant handle the cr springs.the complete cr suspension kit in the link is over 1000.
Old Sep 19, 2009 | 04:46 PM
esean93's Avatar
iirc, front rates are ~238-250 for ap1/2 but CR is low 400's for the front springs. rear cr springs are equivalent to 00/01 ap1 springs.
i am very confused between aftermarket or cr now!
Old Sep 19, 2009 | 10:40 PM
jdm_dc_fan's Avatar
no, oem CR suspension is non adjustable spring/shock combo. but dont dare pay 1k for them. theres a reason why you dont see base models s2k's upgrading to CR shock/spring combo. your better off going with koni/GC combo.
Old Sep 20, 2009 | 03:54 AM
HondaKyle's Avatar
2004 - 2007
2005 - 2008
2008 CR
Rodney really knows his ****.
Old Sep 20, 2009 | 08:36 AM
esean93's Avatar
2004 - 2007
2005 - 2008
2008 CR
thanks for the info!i think im going to go with aftermarket though,1000 for oem coils is not worth it to me.
Old Sep 20, 2009 | 08:40 AM
esean93's Avatar
yep!i might go with BCs,screw comfort!roads around orlando are pretty smooth anyways!haha
Old Sep 20, 2009 | 02:41 PM
Philbert's Avatar
the rates above have been discredited, based on the suspension test done by SCC. the now accepted numbers are:
AP1 [00-01]: 218 (3.9 kg/mm) 291 (5.2 kg/mm) ( Published )
AP1 [02-03]: 249 (4.4 kg/mm) 306 (5.46 kg/mm) (From SCC, also note that the UK Press release stated firmer springs )
AP2 [04-07]: 266 (4.75 kg/mm) 275 (4.91 kg/mm) ( 7% stiffer Fr, 10% lower Rr, compared to prev)
AP2 [08 --]: 284 (5.07 kg/mm) 299 (5.33 kg/mm) ( 7% stiffer Fr, 9% Stiffer Rr, compared to prev)
CR [08 --]: 389 (7 kg/mm) 349 (6.25 kg/mm) ( 37% Stiffer Fr, 17% Stiffer Rr, compared to prev)
(SCC tested 392 lb/in (7.00 kg/mm) 342 lb/in (6.22 kg/mm) for the CR)
Old Sep 21, 2009 | 02:03 PM
4doorH22's Avatar
They increased the spring rates from '07 to '08 some 20lbs/in F&R huh? I checked the part numbers for the springs at www.hondaautomotiveparts.com and they are indeed different (between '07 and '08 base and of course the CR).
A L I A S
Apr 24, 2015 08:42 PM
tianporn
Suspension & Brakes
Sep 2, 2014 02:20 PM
Mr JDM South
Suspension & Brakes
16
Dec 28, 2007 05:43 AM
itr1236
Mar 6, 2003 09:13 PM
Matt Groove
Oct 15, 2002 07:16 AM
