Honda S2000 Honda S2000
Ebrake light blinks...!???
Old Aug 24, 2009 | 03:05 PM
PeakBoostSi's Avatar
Default Ebrake light blinks...!???
so my S has been blinking the ebrake when i make hard right turns...why?
Then when i slow down and take off again it goes away...
Anyone know whats going on?
Old Aug 24, 2009 | 03:36 PM
Zaakro's Avatar
Default Re: Ebrake light blinks...!???
have you checked the level of your brake fluid?
Old Aug 24, 2009 | 04:04 PM
bigmacnfries's Avatar
or brake pads?
have you checked anything?
Old Aug 24, 2009 | 05:24 PM
Boots's Avatar
i would say its definantly the fluid level, and if the fluid level is low, you probably need new pads as well
Old Aug 25, 2009 | 04:56 AM
White Smoke's Avatar
i my honda
Global Mod
Your brake fluid is low. Check around the master to make sure it's not leaking. Also make sure your pads and rotors are within spec.
Old Aug 25, 2009 | 07:41 AM
Yea i checked out the manual and it actually says if it blinks it is most likely the brake fluid level...i will check tonight and let everyone know.
Old Aug 25, 2009 | 04:48 PM
mist sITR's Avatar
your floatie isn't floating!!
Old Aug 26, 2009 | 10:40 PM
Honda Sport's Avatar
correct! I replace brake master cyl caps all the time at work cause the float doesn't float anymore. there's a service bulletin on them.
also make sure fluid level is good.
ElCivic89
Mar 16, 2012 01:54 PM
Live~Civic
Dec 28, 2010 09:31 PM
jjr_99prelude
Aug 31, 2007 09:23 PM
DaveSi677
Aug 23, 2005 02:03 PM
98type_r
Apr 4, 2002 11:14 AM
