Battery Switch Help
Old Feb 12, 2015 | 09:20 AM
84Riceeater's Avatar
Icon2 mods please delete
Delete
Old Feb 12, 2015 | 11:59 AM
Snailor Built's Avatar
Default Re: Battery Switch Help
Looks good from what I can tell, my last chassis was setup like this.
Old Feb 12, 2015 | 12:03 PM
Thank you
Old Feb 12, 2015 | 01:20 PM
Andrew1706's Avatar
Is it necessary to use a fuse between the alternator and battery?
At the moment I have mine setup with a direct line, have I done this wrong?
Old Feb 12, 2015 | 02:40 PM
BrowNKiD's Avatar
If you wire the switch this way the car will continue to run with the switch turned off...You need to run the alt wire direct to the battery. Do a quick search theres a few threads on this already.
Old Feb 12, 2015 | 09:25 PM
a1320addict's Avatar
This should help
Old Feb 13, 2015 | 02:22 AM
fo0's Avatar
fo0
i have the same question
Old Feb 13, 2015 | 06:07 AM
AllMtrRex's Avatar
Joel,
Appreciate the wiring schematic above. If you could add the amperage of the two fuses and awg size for the wiring, It would be even more appreciated.
Old Feb 13, 2015 | 06:14 AM
That will depend on the circuits of the car - but I will typically recommend a 150A circuit breaker for the battery.
The starter motor can draw 125A+ with enough compression, the starter solenoid generally draws 10-15A. Depending on the type of cable used, 4AWG is normally just fine for the BAT +, BAT -, and starter motor. If the car is still on an alternator and has say (2) fuel pumps, water pump, larger fan, etc - 8AWG may be used.
Old Feb 15, 2015 | 07:22 AM
Thanks for the help. I have to make some adjustments.
Old Feb 16, 2015 | 07:51 AM
Heres my final draft before i start cutting wiring. Look correct?
Battery to alt*
Battery to 1 side of cutoff
Starter to other side of cutoff
Fuse/switchpanel to same side as starter on cutoff
Old Feb 16, 2015 | 07:53 AM
I'm not sure what indicates a 4 post cut off with a relay or the 2 post moroso style? What makes one better than the other
Old Feb 17, 2015 | 02:25 PM
BrowNKiD's Avatar
Thats exactly how mines wired.
Greg H
Jul 13, 2008 04:01 PM
JBLAZE622
Jun 27, 2008 11:55 AM
miamidamian
Jun 14, 2006 03:42 PM
philosofy1
17
Oct 13, 2005 12:13 PM
flip1199
Jun 19, 2004 12:13 PM
