Jan Fs Thread
Old Jan 3, 2015 | 04:21 PM
crazes's Avatar
Moderator
Default Jan Fs Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Jan 3, 2015 | 05:28 PM
SlowReaction's Avatar
Default Re: Jan Fs Thread
Display only unit with no logging. Unit is in mint condition. Comes with Aem CAN Communication cable, custom mounting bracket I had made and original box. $850obo
Prayoonto racing stage 2. Gears and pulse plates included. Had RBC intake gear.$650obo
Ferrea Roller rockers. Two tappets got jammed by previous owner so I replaces them when oem ones. Never had proclems been running for over a year. Cam caps included in the sale and will replace the missing bolts in the picture. $550obo
Old Jan 4, 2015 | 05:49 AM
zuptidi's Avatar
SOLD
Old Jan 4, 2015 | 06:44 AM
jdm knight's Avatar
For sale also Tial mvs 38mm with dumbtubes. $400 shipped in the usa
Old Jan 4, 2015 | 10:42 AM
CSRacing's Avatar
Default B series 95mm stroker crankshaft
For sale is a B series 95mm stroker crankshaft, has little use, all journals are is good condition. $250.00 shipped. If interested text or pm me. 314-420-4363 Thanks, Clay
Old Jan 4, 2015 | 11:04 AM
92cxturbo's Avatar
MagnaFuel MP-4303 inline fuel pump. Will support over 800hp on E98. Pump is less then a year old. Only has a few dyno sessions, and 8 track pass's. Include's mounting bracket, and fitting's.
MagnaFuel MP-7009 74 micron, E85 compatible, cleanable stainless, inline pre pump filter. Same amount of use as above, include's fittings.
Fuel Lab 6 micron, E85 compatible, cleanable stainless, inline post pump filter. Include's fittings. This is one of a few filters Tony Palo recommends when using ID injectors with out risking damage to the injector.
$550 shipped for everything.
Old Jan 4, 2015 | 11:26 AM
Almtrhb's Avatar
Borg warner class Limit billet 72mm Turbo, 1.10ar ceramic coated, used for 3 dyno pulls, 4 Lic passes and 3 full passes, has Vibrant Van Jean clamp welded onto it.... Car made decent power up to 42-45psi on a decent pass i went 170mph.... Turbo retails for $2850 on DP performance website sellimg for ****$1700**** Not including shipping or paypal fees. WILL NOT SHIP out of the US
714-388-7303 text for more info
Old Jan 4, 2015 | 02:57 PM
hondaracing84's Avatar
I have a set of K-tuned RDX 410cc injectors w/B series top hats and clips and pins. Used one race season only on the track and maybe 10 miles street. Awesome all motor injectors, good for street turbo setups needing something a little bigger. Only saw VP c16 & c45 race gas. $185 shipped.
PM me or text 580-382-1661
serious inquiries only
Old Jan 4, 2015 | 03:58 PM
turbo-2nr's Avatar
Sold
Old Jan 4, 2015 | 10:00 PM
Rboosted717's Avatar
Motec M4 Pro with custom pro style wiring harness built by Motec USA and modified by T1.
Asking Price: $2500obo (Retail was over $5100)
Items included:
- M4 Pro
- Honda B-series engine harness (built by Motec and modified by T1 Race Development)
- Two sets of optional Motec "wasted-spark" twin-coil boxes with integral igniters (one is used, the other is brand new)
- Modified OE Honda sparkplug wires for (optional) wasted spark ignition
- Modified OE Honda distributor housing for ref/sync if using the (optional) wasted spark ignition setup
- Motec Ignition Multiplexor (brand new)
- Motec Traction Control Multiplexor (brand new)
- Included sensors (GM boost control solenoid, 3bar map sensor, 1bar barometric sensor)
Items Not included
- T1 style cam trigger system
- M&W ignition box, coil packs and ignition harness. You Will need to purchase a T1 style ignition system unless you want to run the (included) wasted spark setup.
- Will require a Motec ignition expander box if you're not using the wasted spark setup. I >will< include it if you purchase the entire Motec system w/traction control unit, savings of $300)
- Motec Traction control multiplexor and harness not included (will include for an additional $400)
Details on the setup:
The M4 kit was originally purchased through Motec USA by Jerry Woods Enterprises (World Renowned Porsche Race Car Builder). The Motec harness was then modified to “Outlaw Spec” by T1 Race Development in 2009.
The M4 includes the upgraded advanced tuning option (Pro):
-Traction Control and Launch Control (2, 3 or 4 wheel)
-Gear Change Ignition Cuts
-Overrun Boost Enhancement (anti-lag)
-Ground Speed Limiting
-3D Mapping of Individual cylinder fuel and ignition tables
-Start/End of Injection Calibration
-Ignition Accel/Decel Calibration
-Ignition Dwell Table
-Second Load Fuel/Timing Table
-512 kB internal logging memory
-Wideband lambda control
The Motec built harness also includes the following T1 “Outlaw Spec” modifications:
-Pre-wired for 4 or 8 sequential fuel injectors (the secondary set of injectors runs in parallel off the first set). The Injector clips are USCAR style (for Injector Dynamics style injectors).
-Pre-wired for individual coil setup via a Motec Ignition Multiplexer, but also has previsions for a dual coil wasted spark ignition (will require some rewiring for waste spark ignition).
-Pre-wired for a cam trigger ignition but can be repinned to use the included Motec modified stock Honda distributor (the harness is pre-wired for both styles).
-Pre-wired for a Strain Gauge (This output can also be used for other purposes)
-Pre-wired for Traction Control via the included Motec Traction Control multiplexer (This output can be used for other purposes).
-Pre-wired for both a 1-3bar GM/Delco map sensor or 5bar Kavlico map senor (via the included GM to Kavlico adapter harness)
-Pre-wired to control an air valve solenoid (The setup includes a GM/Delco boost control solenoid). The output can also be used for other purposes.
-Pre-wired to use an OEM Honda coolant temp sensor
-Pre-wired to use a high-speed GM air temp sensor
-Pre-wired for a Honda VTEC setup or other auxiliary output
-Pre-wired for a 4-wire lambda connection
All documentation, receipts & diagrams are included. The condition of the M4 is excellent. You're basically getting a 60% used harness (in great condition) and a 40% brand new T1 modified harness (never used).
I will also include two working Honda B-Series turbo basemaps (one for a multi-coil coil “T1 style” ignition and one for the twin-coil "wasted spark" Motec ignition). The twin-coil/ 4-injector base map has made over 750whp and the multi-coil/ 8-injector map has made over 900whp. Both were developed with countless hours on the dyno and track logs.
Asking Price $2500 obo (Retail was over $5100)
Note: I will include the Motec ignition expander box if you purchase the entire system plus the Motec Traction control box/harness for $2900. That's an additional savings of $300.
Please contact me directly if you're interested, would like for more information or additional pictures.
Everything seen the picture below is included except for the optional Motec ignition expander and Motec Traction Control Multiplexor box/harness (see notes above).
Old Jan 5, 2015 | 03:44 AM
SPOOLINmatt's Avatar
706-three46-6024
Used ARP B18C Head Studs(Race Only, One Season): $75 Shipped OBO
Used Golden Eagle Pro Series Fuel Rail: $100 Shipped OBO
Battery/catch can/tie down setup ...civic/integra stock battery location. $275 Shipped
Old Jan 5, 2015 | 07:02 AM
EF'n Sedan's Avatar
'96 Civic DX Spindles, Calipers, Rotors, New Wheel bearings and Pads 1500 miles since hubs installed.
Driveshaftshop 3.9 Hubs / ARP Studs
Skunk2 UCA's
$400
Old Jan 6, 2015 | 07:18 AM
Universal Magnetic's Avatar
Contact: j.san-juan@students.clark.edu
Text:503-770-8364
Paypal Verified
Price: $1000 shipped (48 states). Paypal fees included
OR
Price: $900 picked up
Intercomp EZ Weigh Scales
  • PN#170125
  • Model#SW500
  • Gently used and in great condition
  • 15" x 15" x 2.5" (381 x 381 x 64mm) Billet Scale Pads
  • 1,500 lb (700 kg) Pad Capacity
  • 6,000 lb (2,800 kg) System Capacity
  • Cabled Indicator with Case
  • Fresh 9-Volt Battery installed
  • 12V AC adapter included
  • Instruction manual included
Old Jan 6, 2015 | 06:29 PM
Mo_Spec's Avatar
SOLD
Old Jan 7, 2015 | 06:33 AM
dbang003's Avatar
Parts are located in Central NJ. Prices are OBO and do not include shipping, paypal fees, etc.
Contact via PM or at dbang003@aol.com
Competition Clutch B Series Twin Disc $800 – maybe 1,000 miles on clutch, used for 1 autox and 2 track days at NJMP and driving to/from events. No launches or drag passes on clutch. Also includes proper flywheel bolts. Name:  image-364397998.jpg
Golden Eagle GSR B18C1 Intake Manifold and BBK Throttle Body $500 – maybe 2,000 miles on manifold setup. Also includes Golden Eagle TB Cable Bracket, OEM IAC, and Hondata gasket. Will not part. Name:  image-2678367424.jpg
1992 Civic CX Caged Shell https://honda-tech.com/vehicles-sale.../#post50153444 Name:  image-1931777553.jpg
Old Jan 7, 2015 | 08:36 AM
nappyracing001's Avatar
Sold
Old Jan 7, 2015 | 03:34 PM
Blown90hatcH's Avatar
FS: Custom air/air intercooler. Vibrant core PN: 12840 with core dimensions 27.5" x 9.85" x 4.5". 6061 Aluminum end tanks, .125" thick. 3" inlet and 3.5" outlet. Overall length is 35.5" and has gussets for extra strength for high boost. Has a small dent on top of the core from shipping. Car made 830@29psi as is.
Price $450 + shipping.
Old Jan 7, 2015 | 04:34 PM
kte324's Avatar
1993 Honda Civic Cx
Clean Clear Title
10 Point Chromoly Cage built by CCE to NHRA Specifications
5 Gallon RCi Fuel Cell
36mm Hubs
RCi Aluminum Drag Seat w/ EG Seat Rails
PCI Bronze Front Suspension (Solid Aluminum) Bushings
All Other Bushings Are Prothane
New Balljoints, Inner & Outer Tie Rods, Wheel Bearings, Brake Rotors & Pads
Extended Wheel Studs
New Fenders
Rolling on stock suspension and steel wheels
**Car comes as pictured in the recent photos, no hood or bumper.**
*****More Info & Pictures Here ---->>>https://honda-tech.com/vehicles-sale...title-3229000/
Price: $1200 or best offer. Make me an offer. Text/Call 706-627-9865 for more info or pictures. **Pick-up only**
Old Jan 8, 2015 | 04:46 AM
EDLOVA23's Avatar
Sold
Old Jan 8, 2015 | 06:40 AM
cleansi's Avatar
Default GT4201 Vband .81 and topmont kit
precision housings garret oil and water cooled .81hotside(VBAND) .75 coldside
no shaftplay! great working unit.
everything cleaned and freshly powder coated will come with vband clamps.
will sell turbo seperatly, for 900obo price slashed 650 obo!!!!!!!!!!
complete kit 2500.
4" down pipe
topmont
dump tube
Precision gate
PayPal verified and other can vouch for me here as well
located in NY everything forsale or trade for other bseries or ek parts
kburgos123@gmail.com
5085250284
Old Jan 11, 2015 | 03:25 PM
jdmek85's Avatar
Text me for quick response 203-556-5676
Obd2-a AEM V1 $450
AEM Fuel Rail with pressure gauge and Fuel Lab pressure regulator $175 will not part out!
Old Jan 11, 2015 | 05:51 PM
Ej1ownzu's Avatar
sold
Old Jan 13, 2015 | 06:04 AM
AZ_CIVIC's Avatar
Sold
I have for sale a Garrett t3t61 Journal Bearing Turbo that was purchased from Full Race. $550
Here is a run down on the specs,
It is a T3, it uses an ultra efficient GT35R compressor wheel
Stage 5 turbine wheel
0.82 A/R. turbine housing
Has been fitted with a 3 inch v-band turbine discharge
I also have for sale a Tial 44mm Wastegate that comes with the v-band clamps and a custom built dump tube which will fit perfect. $200
SOLD
Old Jan 14, 2015 | 11:35 PM
fbcfab's Avatar
for sale $12,000 runs 10's very capable of 9's....sohc full tube chassis text me if interested 5309331737
Old Jan 15, 2015 | 11:51 AM
firstgen225's Avatar
B series Exedy twin disc for sale $600 text for more info 3477331215 Ant
