adding abs sensors for traction control
Old May 17, 2015 | 12:17 PM
lindseyhunt1090's Avatar
Default adding abs sensors for traction control
hey guys. im planning on trying the hondata traction control system, i have an integra ls which did not come with abs. im just wondering if anyone has added the sensors to the front and back on a non abs car. are the ls castings the same as the gsr? is it as easy as drilling and tapping a couple holes and adding the sensors? or would i have to replace my front spindles and rear hubs?
Old May 17, 2015 | 02:58 PM
adam00's Avatar
Default Re: adding abs sensors for traction control
For the fronts you can just drill the holes. The rears i think you can drill the holes to but i swapped my rears to abs trailing arms
Old May 17, 2015 | 10:24 PM
a1320honda's Avatar
You can just drill and tap. The casting is there for them. I just added ABS stuff to my RS integra. Youll just need the hubs with the pulse rings in the rear and axles with the rings in front.
Old May 18, 2015 | 06:00 AM
ok. so i need to switch out my rear hubs for abs hubs and drill and tap trailing arm. then on the front i can drill and tap the spindles. i have dss axles they have the abs rings on them. then i should be good to go i guess.
curious how well you found it to work. im using it for a 650 700 whp street integra. ive seen some videos where it seems pretty harsh. then others where its really smooth. is the acceleration 100 times better>?
Old May 18, 2015 | 07:05 AM
crucian's Avatar
It all depends on how you have your settings. A lot of testing is needed.
Old May 18, 2015 | 12:24 PM
EJ1_Ex's Avatar
Lindsey, you will need to install 1 front and 1 rear abs sensor. Since you already have an integra you should already have abs sensors. YOu'll just have to wire them in. Hondata has the wiring diagram diag online.
Old May 18, 2015 | 01:48 PM
i have an ls. it never came with abs. i have to buy the sensors and install them. i only need 1 front? i figure 1 rear made sense but thats good news.
Old May 18, 2015 | 06:05 PM
EJ1_Ex's Avatar
Yea you'll just need factory abs sensors. yes you'll only need 1 front and 1 rear.
Old May 21, 2015 | 11:23 AM
98B18C1's Avatar
An LS should come with the abs sensors stock unless the person you bought it off of took everything out...like crucian said, a lot of testing involved to get it to work correctly
Old May 21, 2015 | 11:26 AM
burnoutboy's Avatar
The Credible Hulk
No matter if it has it or not all the correct holes will be there on an LS. I have OEM sensors off a 2000 LS if you're in the market BTW.
Old May 21, 2015 | 03:01 PM
BrowNKiD's Avatar
Rear abs hub and non abs hubs are different. You will need a ABS rear trailing arm.
Old May 21, 2015 | 03:05 PM
burnoutboy's Avatar
The Credible Hulk
Parts fiche lists exactly ONE rear trailing arm style for 2000 Integra LS... and it's ABS equipped. Just sayin. His sig says 2000 integra soooooo... if it's for sure an LS it has the right RTAs
Old May 22, 2015 | 04:04 AM
EJ1_Ex's Avatar
or you can run a hall sensor in the rear. xenocron has them in stock
Old May 22, 2015 | 08:54 AM
AZ_CIVIC's Avatar
I sold all my Hondata Traction control stuff. Really can't use it in first gear even at the lowest setting, it is just way too harsh.
Maybe for street use it will be a bit better, just not worth the money for drag racing in my opinion.
junkyard racer
Jan 8, 2015 03:20 PM
scottso990
Jul 26, 2011 05:25 PM
ED9man
Mar 14, 2007 01:42 PM
darockstar
Mar 11, 2006 07:26 PM
