Golden Eagle scatter shield
Old Mar 16, 2015 | 11:22 AM
Steeve_Civic's Avatar
Default Golden Eagle scatter shield
It is a nightmare to fix it on my b series gearbox!
Need to drill, ground some lugs and it doesn t fix well with the OEM clutch cylinder!
Did you have same problem?
Is there other brandis better?
Old Mar 16, 2015 | 12:46 PM
$MIKE$'s Avatar
Default Re: Golden Eagle scatter shield
I used one from dp racing and I had to cut off the back end but this was because I had -12an lines for my rad, I woundnt grind nothing down maybe they shipped you the wrong one
Old Mar 16, 2015 | 12:48 PM
Golden Eagle has only 2 models, one for b series and one for h series, but they are differents
Old Mar 16, 2015 | 01:59 PM
luck4rmkc's Avatar
I have a GE scatter shield and I did not have to modify it at all. Make sure you have the pieces in the right places. Easy to get confused.
Old Mar 21, 2015 | 06:33 PM
95eggsr66's Avatar
I have same problem. I had to run a ss clutch line but still could only fit 1 bolt where the slave cylinder is.
Old Mar 21, 2015 | 06:46 PM
Turbo-LS's Avatar
You've got something wrong. They go on pretty easy in the correct configuration.
Old Mar 22, 2015 | 01:33 AM
A real nightmare right!
Just finished and bolts behind the starter were too short and need to buy others and spacers!
The end of scatter was touching the speed sensor too, need to bend it a bit.
I think the model I bought was a bad series!
chrismanis
Jan 19, 2015 05:17 PM
Heman4588
Sep 11, 2014 06:49 PM
dirty19
Northern California (Sales)
Aug 12, 2011 05:01 PM
KaJeR
May 30, 2010 09:33 AM
tlarimer
11
May 20, 2010 10:43 PM
