Question to those that know
Is it possible to build an N/A car, with free labour and wholesale prices on parts, that will hit 11's for $10,000? We'd be using an EF chassis. Suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorguy »</TD></TR><TR><TD CLASS="quote">lighten the hell outa the chassis. h23 non-vtec, headers, big cams, light valvetrain, hi comp pistons, headwork, tuning. 11's easy.</TD></TR></TABLE>
why not h22?
why not h22?
We've thrown the H22 around, but what about CR-VTEC? I'm looking for some assemblance of "reliability". I'd rather have issues not associated with Frankensteining. But the thought is tempting.
i cant rember the name but he posted everything on h-t and he did it in a quick time
it was a white LS integra
and do you have that link to that deckplate block in the classifeids?
here is my input.... the link for the sick deckplate engine.
<FONT COLOR="blue">PUT THIS BEAST IN YOUR CAR</FONT>
very simple setup got us the time below, 2.0 high comp.(13.7:1) stock head, crower cams and some gearing, also stock re-programed ecu w/ v-afc
That motor is dope, but I think i may go H22 after thinking about it. Tough to argue with displacement, and compression shouldn't be a problem. Keep the suggestions coming.
I reckon a bolt on H22 in a light (1500lb) car would run 11's and you should be able to do it for 5000 if you can do it yourself.....or a carbied F22
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT »</TD></TR><TR><TD CLASS="quote">If you put a H22a in a light shell It will understeer like hell so will only be useable for the strip.</TD></TR></TABLE>
This would be a drag only project. No one in B.C. has a super fast all motor car designed as a straight drag car.
I really just want wheelie bars.
I believe it can be done for about 6k. Thats not going with a stock head though, thats the full port job and all but a known place. Thats the good ****.
I wish you luck man. It can be done cheaper than 10k for sure though. Almost 5k if you spend right
