CTC gear set
Drool....Are these supposed to be better than the Saenz gear set? I know the cheaper Saenz dont hold up to well to high HP apps, not too sure about the high dollar ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">yeah now we need billet case </TD></TR></TABLE>
But then with aftermarket cases, they will asses u a weight penalty cause its aftermarket...that would suck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx »</TD></TR><TR><TD CLASS="quote">
But then with aftermarket cases, they will asses u a weight penalty cause its aftermarket...that would suck.</TD></TR></TABLE>
But to use these gear sets with stock tranny casings dosn't it put more pressure on them and blow the casing or crack it? i mean cable trannys are rare now and it can and will happen to hydro casings also then all there will be is aftermarket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">
But to use these gear sets with stock tranny casings dosn't it put more pressure on them and blow the casing or crack it? i mean cable trannys are rare now and it can and will happen to hydro casings also then all there will be is aftermarket. </TD></TR></TABLE>
yeah, the cases will still break. Sucks...they need to find a way just to reinforce the stock case. Straight cut gears are not supposed to put pressure on the cases, but they still seem to do so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbologist »</TD></TR><TR><TD CLASS="quote">Drool....Are these supposed to be better than the Saenz gear set? I know the cheaper Saenz dont hold up to well to high HP apps, not too sure about the high dollar ones. </TD></TR></TABLE>
Exactly, so tom, dont buy em!
Here's the honda set. The gears are awesome, i know first hand.
Someone better get crackin on a case that will hold together. I don't think you will have any problems with less than a 28" tire or less than 750whp.
What matrial is that? also, you could argure that a billet tranny case is a safety issue, theres always a chance......... anyone buddy buddy with a sanctioning body pres?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE »</TD></TR><TR><TD CLASS="quote">
Tom??
</TD></TR></TABLE>Tom??
Tom??</TD></TR></TABLE>
yes ...ek9t's real name is TOM
i dont think anyone was supposed to know that...ooops
They will work on any b series tranny from 92 and up. Chris, this is the set you saw a while back. As for the case, you're talking big money to make a billet case! There's always the option of welding in all kinds of supports to the oem case. I was gonna do that on Kenny's car, but that's not a problem i have to deal with anymore.
