MSD 2 step module HELP!!!
Old Nov 29, 2003 | 09:41 PM
white_98_gsr's Avatar
Default MSD 2 step module HELP!!!
Hey guys,
I just finished wiring up my 6AL box with external coil and my 2 stepper. I'm having problems getting my 2 stepper to work correctly. The way I have it wired now, the RPM's never go above 3000 RPM(the RPM i want to launch from) even if im just driving my car normally.
Does anybody know how exactly to wire this? I know you need to wire it to your clutch switch, with a momentary button, but how exactly do you do this? Where is the clutch switch located? Any other help would be greatly appreciated. Im lost.
thanks
Old Nov 30, 2003 | 04:19 AM
boostedh22a's Avatar
there are two switches at the clutch, try moving it to the other one, if it still does this you might need to reconfigure where the pills are on the two step,you might have the 3000 in the high rpm spot
Old Nov 30, 2003 | 06:12 PM
Default Re: (boostedh22a)
are these switches by the clutch pedal or the clutch itself?
SPOOLINmatt
Sep 17, 2004 10:42 AM
underpressure02
Apr 5, 2004 01:02 PM
underpressure02
Dec 22, 2003 04:11 PM
Lei Siew Long
Aug 5, 2003 03:02 AM
