are extended wheels studs necessary?????
Old Dec 9, 2003 | 09:30 AM
vtecdamian's Avatar
Default are extended wheels studs necessary?????
for 13x8 bogart wheels on 22x9x13's on a 00 civic cx with stock brakes and suspension(just coilovers)......help me out the wheels are on their way!
Old Dec 9, 2003 | 10:37 AM
PM-Performance's Avatar
Default Re: are extended wheels studs necessary????? (vtecdamian)
depends on the backspacing of the wheel and how the studs protrude from the wheels when installed.
Old Dec 9, 2003 | 05:00 PM
trackmasters's Avatar
With Bogarts you are required to use special lugnuts. As long as you dont have a 1inch spacer it will techincally work, but most tracks will not let you run without extended studs. Its only a few bucks, try Camp1320.com he stocks ARP and offer great prices. Would you risk the lugnuts holding on to 4-5 threads pushing 300-400hp with 300 ft lbs of torque at 9000 rpms?
Old Dec 11, 2003 | 01:40 AM
camp1320.com's Avatar
Default Re: are extended wheels studs necessary????? (trackmasters)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trackmasters &raquo;</TD></TR><TR><TD CLASS="quote">With Bogarts you are required to use special lugnuts. As long as you dont have a 1inch spacer it will techincally work, but most tracks will not let you run without extended studs. Its only a few bucks, try Camp1320.com he stocks ARP and offer great prices. Would you risk the lugnuts holding on to 4-5 threads pushing 300-400hp with 300 ft lbs of torque at 9000 rpms? </TD></TR></TABLE>
Nicely said, Thanks Guys.
Old Dec 11, 2003 | 01:57 AM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecdamian &raquo;</TD></TR><TR><TD CLASS="quote">for 13x8 bogart wheels on 22x9x13's on a 00 civic cx with stock brakes and suspension(just coilovers)......help me out the wheels are on their way!</TD></TR></TABLE>
Hi vtecdamian; if you need the M&H 9/22-13 let me know I have them in my warehouse.
John@M&H
Old Dec 24, 2003 | 02:59 PM
vtecdamian's Avatar
Default Re: are extended wheels studs necessary????? (SlicksMH)
ill get back to uou on those my setup should e done mid january...so some pretty slicks around my bogarts will be a must!
yOnKiNaToR
May 26, 2006 08:33 AM
jaxle
Mar 16, 2004 01:54 PM
1 2 NV
Jan 24, 2003 04:49 PM
TurboLude97
Jan 14, 2003 09:43 PM
