DC5 Type R muffler
Old 04-06-2011, 08:15 AM
wasanissanFL's Avatar
Default DC5 Type R muffler
A friend of mine just got a used DC5 Type R muffler "Axleback" and he isn't 100% positive he got a Type R muffler and not a Type S. Are there any markings or part numbers on the muffler we can look for? The bottom of his muffler reads
" Honda Futaba 1052"
Thanks for the help.
Old 04-06-2011, 08:26 AM
Mr. Spade's Avatar
Default Re: DC5 Type R muffler
The part number will differ. check one on a 2005/6 -S stock
Old 04-06-2011, 08:41 AM
I don't have a 05-06 muffler around to check. I'll do a some looking around for a type s part number.
Old 04-06-2011, 09:41 AM
Okay i did a lot of looking around and was only able to find one part number. Looks like the 06 Type S muffler is a "Futaba 1060" part # as seen here.
http://forums.clubrsx.com/showthread.php?t=728036
Still haven't been able to find any part number for any year DC5 Type R. Hopefully someone will chime in with one.
Old 04-07-2011, 09:48 AM
Mr. Spade's Avatar
If his says 1052 and stock S is 1060 then it's different. Doesnt he have any RSX-S friends that can just check there's? I'll check mine.
Where on the muffler does it say?
Old 04-07-2011, 01:09 PM
Thanks for chiming in. It's stamped on the left side toward the muffler tip. It will say.
HONDA
10XX
FUTABA
I'm going to remove the piping on the muffler today and i will be able to look inside the rear of the muffler and if it's a Type R i will be able to see the door or gate that allows for the chamber's to be bypassed. Ill update later tonight.
Old 04-07-2011, 01:28 PM
aemciv's Avatar
does yours have this polished tip? Not sure if they are all like this or not.
Source: http://www.icbmotorsport.com/usjdmdc5inty3.html
Old 04-07-2011, 03:37 PM
Okay i just got back from the shop. I cut the rear section of piping off and sure enough i looked inside with a flash light and there was a bypass gate about an 1" inside the muffler inlet. I pushed the gate open fairly easy with a screw driver. It feels spring loaded. I was also able to measure the ID of the muffler inlet. It's about 2 1/8.
I hope this helps someone since the 05-06 Type S muffler and the Type R look VERY much alike from the out side.
TYPE R = 1052
05-06 Type S = 1060
Old 04-08-2011, 05:26 AM
turboteg2nv's Avatar
So what does that exhaust flapper gate thingy do? Better flow?
Old 04-08-2011, 05:47 AM
aemciv's Avatar
guessing it opens up at WOT:
Old 04-08-2011, 06:16 AM
At around 5000RPM's the gate will open up and bypass two of the three chambers. Which gives the muffler a pretty much straight through route. I read at 8000RPM's this muffler gets rid of 2/3 of the back pressure that the model before the gated Type R muffler couldn't. So I'm guessing that was the Type S muffler.
Old 04-11-2011, 05:06 AM
That's sweet. I <3 OEM Honda
Old 05-17-2016, 05:38 PM
Frodom's Avatar
Does the DC5 exhaust catback will fit bolt on with the catalytic converter type s 05-06. Must I do modification to fit exhaust ?
Thank you!
nikkarocky
Texas -OK -LA (Sales)
09-24-2009 08:36 PM
chris3k
04-21-2006 01:55 PM
sLamMeD iNtEgRa
10-25-2001 06:33 AM
Quick Reply: DC5 Type R muffler
