Honda CR-V & Element 2WD & 4WD Element & CR-V
need help
Old Jul 1, 2025 | 09:52 AM
O.B.DEE's Avatar
Default need help
Hello everyone. I have a first gen Crv and I just replaced the thermostat. And I was ok for a day. The temp needle rises when I am idling or at a light. But as soon as I start driving. right back down? Like I mentioned. I replaced the thermostat. Could it be the sensor or the water pump? I have a fairly new engine. 73000 miles. Thank you all for any advice. If I had the money, I would hire help. I don't
Old Jul 1, 2025 | 04:25 PM
Ryanthegreat1's Avatar
Default Re: need help
Are the fans on the radiator running?
Old Jul 1, 2025 | 05:16 PM
O.B.DEE's Avatar
yes they are.
Old Jul 4, 2025 | 02:57 PM
canister's Avatar
5 Year Member
Right back down is not very precise. Does it drop all the way down to cold? That's a faulty temp sensor or electric circuitry between it and the cluster because there is no way to achieve so much cooling.
Old Jul 7, 2025 | 09:26 AM
pscarbor's Avatar
Sounds like the electric radiator fan isn't coming on as it should - or possibly it is. My Civic ran fine when the A/C was on but if it was off and the car left idling it would overheat. Turned out to be the sensor that turns the fan on was bad. I replaced it and the fan now comes on - but it still heats up before the fan engages. The actual temp is right on spec, so that's the way it was designed to work.
Also the Honda temp gauge is basically crap. I use the Torque app and a bluetooth adapter when I want to know the actual temperature.
Old Jul 8, 2025 | 08:27 AM
O.B.DEE's Avatar
Icon4 Re: need help
The fan is good, and it was going fine. Then it started. I replaced the temp sensor. OEM. drove great for about 5 miles. When I stopped at the light. The pin was on its way up. So I am at square one. But when I drive, it goes halfway on the meter as if ok. only goes up when driving.
Old Jul 8, 2025 | 08:32 AM
canister's Avatar
5 Year Member
Read the actual temperature by any means, i.e. OBD or a handheld IR thermometer and see what it is.
Old Jul 9, 2025 | 11:24 AM
O.B.DEE's Avatar
Swill do. Thanks for the help. Stay solid 👊
Old Jul 10, 2025 | 01:41 AM
O.B.DEE's Avatar
It drops down to normal right in the middle of where it's supposed to be
Old Jul 11, 2025 | 08:53 AM
O.B.DEE's Avatar
So we replaced thermostat and sensor. We were running to get air out of system with rad funnel. It did fine. Fans run and looks like thermostat is opening. But it got to a point where so much air bubble coming up and began to spill all over.
Old Jul 11, 2025 | 10:12 AM
That sounds like a blown head gasket.
Old Jul 15, 2025 | 05:20 AM
O.B.DEE's Avatar
Yeah nah
frankyjmr
Dec 6, 2011 11:43 AM
luvmihatch
Nov 27, 2010 06:15 PM
Dre_559
Jun 12, 2009 02:46 PM
bb4jdmh22a
Sep 18, 2008 05:32 AM
onetrueshyguy
Dec 20, 2003 10:26 PM
