***Post Links to Helpful FAQs So We Can Get an Archive Going***
Old 10-08-2003, 12:52 PM
Former Moderator
B18C5-EH2's Avatar
Default ***Post Links to Helpful FAQs So We Can Get an Archive Going***
Like the title says.
The mods in here are trying to get together a bunch of 1992-2000 Civic/Del Sol tech articles together so we can cut down on repeated topics.
I'll then sticky the topic, and we can cut down on the repeated topics.
Topics such as brake swaps, ITR rear swaybar installs, Mini-Me VTEC, Si/Type R cluster in non-Si Civics, Mounts for Swaps in certain cars, H22A into Civic, B Series into Civics, Seat swaps, How-Tos for normal stuff like oil changes, bleeding brakes, etc.
I'd like to encourage the link to be H-T topics.
<FONT SIZE="2">Here is a list of the FAQ's listed so far, at least the ones with the HT Links-
[/b]</FONT>
<U>Engine:</U>
https://honda-tech.com/zerothread?id=1924483 B16 Bottom End Build
https://honda-tech.com/zerothread?id=554053- SOHC VTEC Mini Me 92-95
https://honda-tech.com/zerothread?id=735196- SOHC VTEC Mini Me 96-00
https://honda-tech.com/zerothread?id=335078- Spades Huge SOHC Upgrades Thread
https://honda-tech.com/zerothread?id=1018993- D16Y8 Manifold onto D16Z6
https://honda-tech.com/zerothread?id=550221- EK Auto to Manual Swap
https://honda-tech.com/zerothread?id=1377459- EK Auto to Manual Swap
https://honda-tech.com/zerothread?id=1316692- Auto to Manual Transmission Conversion for an EG
https://honda-tech.com/zerothread?id=382416- B Series Axle Replacement
https://honda-tech.com/zerothread?id=1135275- Replacing Axles
https://honda-tech.com/zerothread?id=596873- D Series Transmission Disassembly and Input Shaft Bearing Replacement
https://honda-tech.com/zerothread?id=474557- Filling Tranny Through VSS
https://honda-tech.com/zerothread?id=536593- Filling Tranny Through VSS
https://honda-tech.com/zerothread?id=851521- Changing Tranny Fluid
https://honda-tech.com/zerothread?id=644885- Tranny Inspection
https://honda-tech.com/zerothread?id=811691- Transmission Removal
https://honda-tech.com/zerothread?id=470849- Shift Linkage Bitch Pin
https://honda-tech.com/zerothread?id=569187- Fake J’s Intake Review
https://honda-tech.com/zerothread?id=469492- B16 vs B18 Head
https://honda-tech.com/zerothread?id=1007935- Short Shifter Install
https://honda-tech.com/zerothread?id=745235- Short Shifter Install
https://honda-tech.com/zerothread?id=1206651- Fastline Performance Shifter Review
https://honda-tech.com/zerothread?id=1001924- ES Shifter Bushings
https://honda-tech.com/zerothread?id=1002429- ES Shifter Bushings
https://honda-tech.com/zerothread?id=558236- Erratic Idle
https://honda-tech.com/zerothread?id=699787- Fixing Fast Idle Throttle Valve
https://honda-tech.com/zerothread?id=757695- DIY Catch Can
https://honda-tech.com/zerothread?id=649277- Timing Belt and Water Pump
https://honda-tech.com/zerothread?id=1424191- How to Flush Coolant and Change Thermostat
https://honda-tech.com/zerothread?id=184202- Power Steering to Manual Steering
https://honda-tech.com/zerothread?id=1065831- Distributor O Ring
https://honda-tech.com/zerothread?id=474849- DOHC VTEC Valve, Valve Spring, and Retainer Replacement
https://honda-tech.com/zerothread?id=864710- SOHC Camshaft and Valve Springs Install
https://honda-tech.com/zerothread?id=640755- Painting Valve Cover
https://honda-tech.com/zerothread?id=782937- Painting Valve Cover
https://honda-tech.com/zerothread?id=491789- Painting Valve Cover
https://honda-tech.com/zerothread?id=543704- Cleaning Engine Bay
https://honda-tech.com/zerothread?id=1305086- D-Series Valve Lash Adjustment
https://honda-tech.com/zerothread?id=1113916- Header Installation
https://honda-tech.com/zerothread?id=1563439- Polishing a Header
https://honda-tech.com/zerothread?id=1230433- Installing B&M Fuel Pressure Modifier
https://honda-tech.com/zerothread?id=1414880- Wire Tuck for SOHC EG
https://honda-tech.com/zerothread?id=1564019- Cleaning FITV aka Fast Idle Thermo Valve
https://honda-tech.com/zerothread?id=898904- Removing Crank Pulley
https://honda-tech.com/zerothread?id=1497875- DIY Leakdown Tester
https://honda-tech.com/zerothread?id=1491041- DIY Leakdown Test
https://honda-tech.com/zerothread?id=1521170- Everything You Need to Know About Fuel Setups
https://honda-tech.com/zerothread?id=1529645- Everything You Need to Know About Cooling Systems
https://honda-tech.com/zerothread?id=1534856- Everything You Need to Know About Motor Oil
<U>Suspension/Brakes: </U>
https://honda-tech.com/zerothread?id=152884- Putting X Brakes on Y Car
https://honda-tech.com/zerothread?id=514109- 96-97 JDM ITR 4 Lug Brake Information
https://honda-tech.com/zerothread?id=811892- ITR 4 Lug onto EK
https://honda-tech.com/zerothread?id=514109- ITR Brake Thread
https://honda-tech.com/zerothread?id=333061- Five Lug Conversion
https://honda-tech.com/zerothread?id=1036267- GSR Suspension into EG
https://honda-tech.com/zerothread?id=812062- Integra Rear Discs onto EG
https://honda-tech.com/zerothread?id=820484- Full Brake Swap for EG
https://honda-tech.com/zerothread?id=641639- EK Rear Disc Conversion
https://honda-tech.com/zerothread?id=1513752- How to put X Brake Setup on an EK
https://honda-tech.com/zerothread?id=641639- Complete Rear Disc Brake Conversion
https://honda-tech.com/zerothread?id=1030365- Integra Brake Swap
http://home.socal.rr.com/civic...x.htm- Cutting Away Old Control Arm Bushings and Using New Ones
https://honda-tech.com/zerothread?id=490117- Tie Rod End Removal
https://honda-tech.com/zerothread?id=1031874- Changing Tie Rod Ends
http://home.earthlink.net/~civ....html- Bolt and Washer Camber Fix
https://honda-tech.com/zerothread?id=481704- Jim Fab Traction Bar Install
https://honda-tech.com/zerothread?id=555391- HX Wheels on GSR or Si
https://honda-tech.com/zerothread?id=861481- Rear Lower Tie Brace Install
https://honda-tech.com/zerothread?id=972851- Front Tower Bar Install
https://honda-tech.com/zerothread?id=1079213- Lower Tie Brace Install
https://honda-tech.com/zerothread?id=1078663- Coilover Sleeve Install
https://honda-tech.com/zerothread?id=1278794- Installing Lowering Springs
[url="https://honda-tech.com/zerothread?id=600967"] https://honda-tech.com/zerothread?id=600967[/url]- NSX Calipers
https://honda-tech.com/zerothread?id=864784- Brake Rotor Replacement
https://honda-tech.com/zerothread?id=1317231- Quaife Steering into EG
https://honda-tech.com/zerothread?id=1427142- Shock/Strut Removal of EG
https://honda-tech.com/zerothread?id=1484555- Integra GSR Sized Brakes While Keeping Stock DX Civic Knuckles
https://honda-tech.com/zerothread?id=1437513- Blank vs. Cross Drilled Rotors
<U>Interior:</U>
https://honda-tech.com/zerothread?id=525936- Removing Sound Deadening Tar from EG
https://honda-tech.com/zerothread?id=512955- Removing Carpet from EG
https://honda-tech.com/zerothread?id=512901- Removing Back Seat from EG
https://honda-tech.com/zerothread?id=690687- Removing Rear Quarter Trim Panels from EG
https://honda-tech.com/zerothread?id=692729- Removing Headliner and Pillar Trim Panels from EG
https://honda-tech.com/zerothread?id=600430- EG Dash Removal
https://honda-tech.com/zerothread?id=598255- Removing Paint from Interior
https://honda-tech.com/zerothread?id=721218- Removing EG Clock
https://honda-tech.com/zerothread?id=814006- Steering Wheel and Intermittent Wiper Removal
https://honda-tech.com/zerothread?id=851733- EK Steering Wheel Replacement
https://honda-tech.com/zerothread?id=646354 - How To Fix Door Slam Sound
https://honda-tech.com/zerothread?id=632263- Window Visor How To
https://honda-tech.com/zerothread?id=629098- How To Install EK Window Visors
https://honda-tech.com/zerothread?id=347548- S2000 Seat Install
https://honda-tech.com/zerothread?id=1479028- S2000 Seats into Del Sol
https://honda-tech.com/zerothread?id=1436635- Integra Seats into EJ
https://honda-tech.com/zerothread?id=627857- Rear Seats in EG Hatch
https://honda-tech.com/zerothread?id=481758- ITR Seats into EK and EG
https://honda-tech.com/zerothread?id=826594- Del Sol Seats into EK
https://honda-tech.com/zerothread?id=1225538- RSX Seats with Custom Brackets into EK
https://honda-tech.com/zerothread?id=766603- 92-96 Prelude Seats into EK
https://honda-tech.com/zerothread?id=577769- DIY Seat Brackets
https://honda-tech.com/zerothread?id=473878- DIY Door Panels
https://honda-tech.com/zerothread?id=661308- EG Amber Dash Lighting
https://honda-tech.com/zerothread?id=1186091- EK Amber Climate Control
https://honda-tech.com/zerothread?id=374250- Amber GSR Cluster
https://honda-tech.com/zerothread?id=220512- Amber GSR Cluster
https://honda-tech.com/zerothread?id=605432- 99-00 Climate Control into 96-98 Civic
https://honda-tech.com/zerothread?id=407737- ITR Cluster into EK
https://honda-tech.com/zerothread?id=437408- GSR Cluster into EG
https://honda-tech.com/zerothread?id=504396- GSR Cluster into EG
https://honda-tech.com/zerothread?id=304752- GSR Cluster into EG
https://honda-tech.com/zerothread?id=364837- GSR Cluster into EG
https://honda-tech.com/zerothread?id=557403- EG Cluster Over Si Cluster
https://honda-tech.com/zerothread?id=602325- Si Cluster in EG
https://honda-tech.com/zerothread?id=1053318- Integra Cluster into Civic
https://honda-tech.com/zerothread?id=290569- Headlight Warning Buzzer
https://honda-tech.com/zerothread?id=651657- Headlight Warning Buzzer
https://honda-tech.com/zerothread?id=457308- Cleaning Out Blower Motor
https://honda-tech.com/zerothread?id=285567- Integra Dash in EG
https://honda-tech.com/zerothread?id=170977- Integra Dash in EG
https://honda-tech.com/zerothread?id=1211255- Integra Dash in EG
https://honda-tech.com/zerothread?id=276819- Changing Odometer
https://honda-tech.com/zerothread?id=413826- Changing Odometer
https://honda-tech.com/zerothread?id=851492- Calibrating Speedometer
https://honda-tech.com/zerothread?id=593924- Manual Door Locks
https://honda-tech.com/zerothread?id=612414- Power Windows into EG
https://honda-tech.com/zerothread?id=145543- Power Windows into EG
https://honda-tech.com/zerothread?id=619175– Power Windows into EG
https://honda-tech.com/zerothread?id=749123- Power Lock Conversion
https://honda-tech.com/zerothread?id=1065575- Power Windows, Locks, Mirrors into EG
https://honda-tech.com/zerothread?id=619175- EG Power Windows
https://honda-tech.com/zerothread?id=615442- Cargo or Trunk Light in EK Hatch
https://honda-tech.com/zerothread?id=724917- Water in EG
https://honda-tech.com/zerothread?id=264288- Resetting SRS Light
https://honda-tech.com/zerothread?id=747144- Raising Visibility with Spoon Knockoffs
https://honda-tech.com/zero...15302- Push Button Start
https://honda-tech.com/zerothread?id=949918- DIY Tach Installation
https://honda-tech.com/zerothread?id=1303448- DIY Shifter Plate
https://honda-tech.com/zerothread?id=1485735- Aftermarket steering wheel install
<U>Exterior:</U>
https://honda-tech.com/zerothread?id=476935- Prepping Car for Paint
https://honda-tech.com/zerothread?id=542359- Prepping Car for Paint
https://honda-tech.com/zerothread?id=376870- Painting Your Car, Tips, Tools and Techniques
https://honda-tech.com/zerothread?id=965005- Painted Door Handles and Mirrors
https://honda-tech.com/zerothread?id=489625- Painting Exterior Trim Pieces
https://honda-tech.com/zerothread?id=316500- Painting Wheels
https://honda-tech.com/zerothread?id=587932- EK Sidemarker Diagrams
https://honda-tech.com/zerothread?id=594739- HT’s Nicest EG
https://honda-tech.com/zerothread?id=597437- HT’s Nicest DC
https://honda-tech.com/zerothread?id=594775- HT’s Nicest EK
https://honda-tech.com/zerothread?id=142946- EK Sides on EG
https://honda-tech.com/zerothread?id=456775- EK Sides on EG
https://honda-tech.com/zerothread?id=500842- EK Sides on EG
https://honda-tech.com/zerothread?id=1528222- EG VX Lip on Del Sol
https://honda-tech.com/zerothread?id=491711- HX Wheels on EG
https://honda-tech.com/zerothread?id=343860- DIY Grille
https://honda-tech.com/zerothread?id=282131- Baking EK Headlights
https://honda-tech.com/zerothread?id=812732- DIY Black Housing EK Headlights
https://honda-tech.com/zerothread?id=813522- Sidemarkers
http://www.jdmvtec.com/silipinstall.html- Si Lip on EG
http://www.autodynamic.com/tra...r.htm- EG Lip Install
https://honda-tech.com/zerothread?id=964126- Home Depot Lip
https://honda-tech.com/zerothread?id=458570- City Lights
https://honda-tech.com/zerothread?id=683685- Main HID Thread
https://honda-tech.com/zerothread?id=495898- HID Thread
https://honda-tech.com/zerothread?id=503542- HID Thread
https://honda-tech.com/zerothread?id=574577- HID Thread
https://honda-tech.com/zerothread?id=501058- Projector Thread
https://honda-tech.com/zerothread?id=612520- Projector Thread
https://honda-tech.com/zerothread?id=622672- Projector Thread
https://honda-tech.com/zerothread?id=640997- Projector Thread
https://honda-tech.com/zerothread?id=751356- DIY Yellow Fogs
https://honda-tech.com/zerothread?id=1352749- EG 2/3 Door Foglight Install
https://honda-tech.com/zerothread?id=1268962- Lamin-X Your Foglights
https://honda-tech.com/zerothread?id=1268994- Lamin-X Your Foglights
https://honda-tech.com/zerothread?id=790135- 99-00 Front End on 96-98
https://honda-tech.com/zero...02068- Quarter Panel Glass
https://honda-tech.com/zerothread?id=817274- Del Sol Aux Light Rewire
https://honda-tech.com/zerothread?id=845731- Fixing Windshield Wipers
https://honda-tech.com/zerothread?id=1067080- Integra Sunroof into EG
https://honda-tech.com/zerothread?id=1132916- More Visibility/Adjustability from Fake Spoon Mirrors
https://honda-tech.com/zerothread?id=1299297- More Visibility from Fake Spoon Mirrors
https://honda-tech.com/zerothread?id=1130443- Polishing HX and VX Rims
https://honda-tech.com/zerothread?id=1201257- How To Prevent Your Doors From Rusting
https://honda-tech.com/zerothread?id=1235865- Fixing a Rubbing Fender
https://honda-tech.com/zerothread?id=885253- Fixing EK Hatch Water Leak
https://honda-tech.com/zerothread?id=1507848- Fender Installation
<U>Specifications:</U>
https://honda-tech.com/zerothread?id=150315- EG Hatchback Weights
https://honda-tech.com/zerothread?id=352990- EG Hatchback Stock Colors
https://honda-tech.com/zerothread?id=363047- VTEC Cams Comparison
https://honda-tech.com/zerothread?id=684550- H22 vs B Series Weight
https://honda-tech.com/zerothread?id=1169414- D-Series Torque Specifications
https://honda-tech.com/zerothread?id=682485- Engine Compression Ratio Formulas
http://www.hadamotorsport.com/....html- D Series Header Comparison
https://honda-tech.com/zerothread?id=694733- Civic Chassis Codes
https://honda-tech.com/zerothread?id=869206- EK Paint Colors
https://honda-tech.com/zerothread?id=850751- Identifying B Series Transmissions
https://honda-tech.com/zerothread?id=958024- Hood Weights
https://honda-tech.com/zerothread?id=1300459 - D-Series/B-Series Interchangeable Parts
https://honda-tech.com/zerothread?id=1024818- 92-00 Civic Interchangeable Parts
<U>Electrical: </U>
https://honda-tech.com/zerothread?id=682412- ECU Codes
https://honda-tech.com/zerothread?id=587460- Repinning an ECU
https://honda-tech.com/zerothread?id=810101- Identifying an ECU
https://honda-tech.com/zerothread?id=478377- ECU Pinouts
https://honda-tech.com/zerothread?id=558245- EK Wiring Information
https://honda-tech.com/zerothread?id=413799- Hondata Vs. AEM EMS
https://honda-tech.com/zerothread?id=644434- B18C1 into VX Wiring Instructions
https://honda-tech.com/zerothread?id=724252- Wiring VTEC
https://honda-tech.com/zerothread?id=461376- OBD2 to OBD1
https://honda-tech.com/zerothread?id=910218- Fuse Layout
https://honda-tech.com/zerothread?id=1966666- Civic & Del Sol Fuses (printable panel diagrams)
https://honda-tech.com/zerothread?id=418159- VAFC Wiring Diagrams
https://honda-tech.com/zerothread?id=539424- EG Mirrors Wiring
https://honda-tech.com/zerothread?id=646714- EG Mirrors Wiring
https://honda-tech.com/zero...98906- Tach Lead for EG
https://honda-tech.com/zerothread?id=807030- Reprogramming Keyless Entry Remotes
https://honda-tech.com/zerothread?id=1066681- Proper Form of Overcurrent Protection
https://honda-tech.com/zerothread?id=1513794- Code 1 Fix for EG VX/CX Owners
<U>Swaps:</U>
https://honda-tech.com/zerothread?id=878010- Swaps Available For Civics
https://honda-tech.com/zerothread?id=50010- Places People Got Their Swaps
https://honda-tech.com/zerothread?id=434668- H22 Axle Information
https://honda-tech.com/zerothread?id=362984- H22A General Information
https://honda-tech.com/zerothread?id=362984- H22 Swap, Rumors or Truth?
https://honda-tech.com/zerothread?id=650329- H22 Info
https://honda-tech.com/zerothread?id=550976- Swapping in a B Series
https://honda-tech.com/zerothread?id=856396- B18C1 into EG
https://honda-tech.com/zerothread?id=635782- ITR Swap into 92-95 VX
https://honda-tech.com/zerothread?id=131949- How To Swap a Motor
https://honda-tech.com/zerothread?id=626892- H22 vs. B18C5
https://honda-tech.com/zerothread?id=528602- B16 vs B18
https://honda-tech.com/zerothread?id=359189- B16 vs B18
https://honda-tech.com/zerothread?id=216389- B16 vs B18
https://honda-tech.com/zerothread?id=163450- B16 vs B18
https://honda-tech.com/zerothread?id=447623- B20 into EK
https://honda-tech.com/zerothread?id=504321- B20 into EK
https://honda-tech.com/zerothread?id=508054- B20 into EG
https://honda-tech.com/zerothread?id=466327- Removing Engine Without Hoist
<U>Forced Induction:</U>
https://honda-tech.com/zerothread?id=544653- Edelbrock Turbo
https://honda-tech.com/zerothread?id=377208- Oil Lines on Firewall
https://honda-tech.com/zerothread?id=635014- Turbo Kit Install
https://honda-tech.com/zerothread?id=517274- Resistor Box
<U>General:</U>
https://honda-tech.com/zerothread?id=352308- A Link to Many More FAQ’s
https://honda-tech.com/zerothread?id=629535- How Tire Size Affects Gearing
https://honda-tech.com/zerothread?id=183552- Road Racing on an H22 Civic
https://honda-tech.com/zerothread?id=721575- Helpful Tips by Emerika
https://honda-tech.com/zerothread?id=1016891- SeaFoam
https://honda-tech.com/zerothread?id=1059690- SeaFoam
https://honda-tech.com/zerothread?id=858511- SOHC Quarter Mile Times
https://honda-tech.com/zerothread?id=858510- DOHC Quarter Mile Times
https://honda-tech.com/zerothread?id=802260- Pros and Cons of A/C and PS
https://honda-tech.com/zerothread?id=551049- BAR Swap Approval in CA
https://honda-tech.com/zerothread?id=815454- Ref Station Review
https://honda-tech.com/zerothread?id=853679- Passing CA Ref
https://honda-tech.com/zero...59796- Converting JDM Intake Mani to US Specs for Ref
https://honda-tech.com/zerothread?id=906684- Converting JDM Motor to US Specs
https://honda-tech.com/zerothread?id=867722- How to Pass Exhaust Test in CA
https://honda-tech.com/zerothread?id=884696- Buying a Used Civic
https://honda-tech.com/zerothread?id=859655- What Octane Gas to Use?
https://honda-tech.com/zerothread?id=701236 Smog, what it is and how it affects you.
Old 10-08-2003, 12:55 PM
silverEH2's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (B18C5-EH2)
i like this one, all your ecu pinouts
Old 10-08-2003, 01:06 PM
Risky Business
BauleyCivic's Avatar
D15 SOHC VTEC Mini-Me How-To Writeup:
SOHC Transmission Disassembly and Input Shaft Bearing Replacement:
Tire Size and Gearing Information:
Old 10-08-2003, 01:47 PM
Pho Real's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (BauleyCivic)
99-00 Climate control into 96-98
Old 10-08-2003, 02:12 PM
poison's Avatar
H22A into Civic information:
MERGING OBD1 CIVIC HARNESS TO H22A ENGINE:
- Take off and mark every single harness connector on where it came from/where it goes from both H22A and stock civic engine. Make sure you label them of where pulled the plug from! This will save a TON of time!
Mount Civic harness on H22A and measure/modify wire to be lengthened/changed as follows:
- Change fuel injector connectors to H22A type and add resistor pack from H22A harness to Civic harness (see diagram on page 4)
- Extend Alternator wires to reach the H22A alternator (match the pinouts)
- Lengthen wire that goes to the starter solenoid on starter
- Attach reverse light sensor wire to the new H22A reverse light sensor wire
O2 sensor (CX only) add 3 wires to O2 sensor and follow o2 wires and change to Prelude O2 sensor connector. And wire the following:
- WHT/RED wire goes to D14 which is O2 Sensor Input
- ORG/BLK wire goes to A6, which is Heater Control
- GRN/WHT wire goes to D22 which is Sensor Ground
- YEL/BLK wire goes to A25 which is Sensor voltage
VTEC wiring: This applies to DX,LX,CX models only in 93-95!
- Wire from the VTEC Solenoid to the A4 pinout at the ECU. Add the pin to the shock tower harness, and female pin at the female shock tower connector.
Knock sensor wiring: (mounted at the rear of the engine near the cylinder head)
Air Intake Bypass solenoid (secondary butterflies)
- Sensor voltage to the A25 pinout (or splice into the Yel/Blk wire connector at the driver shock tower harness.
- ECU Signal leading to A17 pinout on ECU
EGR (Exhaust Gas Recirculation) System: Applies to all model civics except VX
- EGR lift valve solenoid – sensor voltage (A25 pinout) & ECU signal to A11
- EGR lift sensor – sensor voltage (A25 pinout), ground (D22 pinout) & ECU sensor signal to D12
MOUNT KITS AVAILABLE:
- HASport mount kit
- Place Racing Mounts
- HCP Mount kits
MAINTENANCE PRE-CAUTIONS
- Timing Belt for 92-96 USDM Prelude VTEC (2.2L) - $39.99 from AutoZone
- Water Pump for 92-96 USDM Prelude VTEC (2.2L) - $34.99 w/lifetime warranty from AutoZone
- Spark Plugs for USDM 92-96 Prelude VTEC (2.2L) – approx. $8
- Extended Fuel filter hose (from fuel filter to fuel rail) – You can use an extended fuel line and use hose connectors/clamps, or contact a local hose factory to have a custom hose made.
- Throttle Body gasket for Prelude VTEC (Honda dealership) $7
Drivetrain options:
- Right 90-93 Integra Axle
- Left Custom 92 Prelude Inner CV joint with 90-93 shaft & Outer CV joint from Raxles for $170 1-800-257-8192
OR
- 1990 Accord Intermediate Shaft
- Left and Right 90-93 Integra Axles
OR
- Driveshaftshop.com Stage/Level 1 axles Right & Left side using prelude intermediate shaft
Radiator options:
- FAL import racing fan for 92-00 Civic for $169.95 from Summit Racing 1-800-962-9094 with 1994-97 Del Sol VTEC Radiator or Integra Radiator
OR
- C&R Import Racing aluminum radiator with SPAL fan for DOHC motors - $439.95 (317) 293-4100
- 1992 Integra LS Upper Radiator Hose – approx. $15
- 1994 Del Sol VTEC lower radiator hose – approx. $15
If you are running NO A/C then you can get alternator belt - Part No. 25-060370 from NAPA Auto parts which is $20 or any 36-37” belt with 6 teeth.
I will post pictures here in a second...
Old 10-08-2003, 02:20 PM
poison's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (poison)
VX O2 sensor fix:
If you have a VX model Civic, and you do NOT use the VX engine harness, in order for your O2 sensor to properly work, you need to move the ORG/BLU wire from the 4th connector at the shock tower harness, and move it matching with the WHT wire on the 4 wire embedded engine harness.
Old 10-08-2003, 02:25 PM
poison's Avatar
GSR Dash into EG wiring information:
Using the GSR harness (which I have done), it's very simple to get your dash 100% working.
You can use the GREEN and BLUE plug, which plug right into the Civic fuse box plugs.
HOWEVER
The grey plug has additional pinouts on the Integra dash harness and cannot be used. Just retain the Civic grey plug and match the pinouts.
I am currently making a JPEG diagram for this -- will be up soon.
ONE THING, your turn signals will not work.
Why?
This is why:
The power wire going to the Integra hazard switch is the Yel/Blk wire, where-as the Civic hazard switch is the YEL wire.
Just simply take the Yel/Blk wire from the Integra harness (which is an unused wire from the grey plug), and splice that into the Yel wire on the GREEN plug (the middle pinout YEL wire.
Kaboom -- done.
More info soon...
Modified by poison at 4:43 PM 10/8/2003
Old 10-08-2003, 02:34 PM
poison's Avatar
Here is some of VX's awesome detailed How-To's
Remove Sound deadening Tar from an EG:
Remove Carpet from an EH hatch:
Remove Rear/Back seat from an EH hatch:
Awesome work VX!
Old 10-08-2003, 02:41 PM
poison's Avatar
Road racing on an H22 Civic by Newman:
H22A Civic Axle information by Newman:
EK wiring information by Katman:
Modified by poison at 4:54 PM 10/8/2003
Old 10-08-2003, 03:11 PM
poison's Avatar
Yet, more H22A information:
Old 10-08-2003, 04:03 PM
TrickHonda98's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (splitime)
(I thought that this part of this thread was a small waste of space, i edited my old message and put thses in. )
What the engine codes mean:
~ex.~ B18C5
B stands for b series motor
18 stands for 1.8 liter
C, C1, C5 stands for the classification and USDM JDM.
C=JDM C1=USDM C5=TypeR
engine codes
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K20A3 2.0L DOHC i-VTEC '02+ RSX
'02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S
02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX
130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL
150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiRS Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
ECU CODES
PG6 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR2 : 89-91 ZC (Euro)
PR3 : 89-91 JDM B16A EF8/9
PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door Civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P08 : 92-95 OBD-1 Civic D15 JDM
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31 : 1997 Honda Accord 1.8 LS
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2E : 96+ OBD-2 Civic DX Coupe
P2M : 96+ OBD-2 NZ Civic SOHC VTEC
P2T : 99+ OBD-? Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA : 97+ US Acura 1.6EL
PCT : 98+ JDM ITR / CTR
PCX : 99+ OBD-? S2000
Modified by TrickHonda77 at 8:32 PM 6/18/2004
Modified by TrickHonda98 at 4:55 PM 6/28/2004
Old 10-08-2003, 05:04 PM
VX
VX's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (TrickHonda77)
1995.5 - 1997 JDM ITR 4-Lug (4x114.3mm) Brake Tech Thread!
How-To: Change Out Main Rear Trailing Arm Bushings!
How-To: Cut Away Old Control Arm Bushings & Press In New Ones!
Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch!
Detailed How To: Remove Headliner & Pillar Trim Panels From An EH Hatch!
I'll edit this post in the future when i can dig up more tech threads.
Modified by VX at 8:05 PM 11/30/2003
Old 10-08-2003, 05:57 PM
shorti's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (VX)
i know this is the eg+ forum but i have a bunch of links for 4th gens too
4th gen SiR cluster install
http://www.geocities.com/Motor....html
4th gen ECU Codes and trouble shooting
https://honda-tech.com/zerothread?id=468260
EF Canards
https://honda-tech.com/zerothread?id=432972
How-To: Extended Shock Travel
https://honda-tech.com/zerothread?id=469485
SOHC upgrades *REVISED* It's long and is a work in progress.
Old 10-08-2003, 06:32 PM
Smith Wise's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (shorti)
Y8 Manifold on Y7
Y8 Manifold swap on Y7
EG Dash Removal
EG Dash Removal
Remove Paint from Interior
Yes I was stupid enough to paint it!!
Manual Door Locks
Manual Door Locks
Auto to Manual
That's it for now.
edit: How could I forget.........
EK Dash Removal
EK Dash Removal
EM1 Cluster in Auto EK
Just a warning about the "extra plugs"
Old 10-08-2003, 06:41 PM
Fred n J_v2.0's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (Jswpstdoff)
tom's post in here is very insightful... about the fifth/sixth one down
swapping in a b-series:
Old 10-08-2003, 09:30 PM
smnowell's Avatar
How-To: DOHC VTEC Valve, Valve Spring, and Ti Retainer Replacement
How-To: Paint Your Car - Tips, Tools, and Techniques
Old 10-08-2003, 10:01 PM
degooser's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (b16a ferio)
<FONT COLOR="blue"> California people who never thought that a JDM motor will pass at the State Ref...!</FONT>
Modified by degooser at 9:01 AM 4/2/2004
Old 10-09-2003, 04:31 AM
This user can set his title.
ki3t's Avatar
5 lug conversion
Old 10-09-2003, 05:37 AM
2000blackgsr's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (B18cR-Ej1)
How to put X Brakes on Y Car
Old 10-09-2003, 06:10 AM
Former Moderator
B18C5-EH2's Avatar
Here's a nice DIY for painting your exterior trims to make them look like brand new O-E pieces:
Old 10-09-2003, 07:07 AM
Nerv2g's Avatar
This post shows pics of what poison is talking about. (The ITR swap into a 92-95 VX).
Old 10-09-2003, 08:58 AM
Risky Business
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (Nerv2g)
How to Paint Wheels:
Old 10-09-2003, 10:15 AM
poison's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (DvSiR)
Places people got their swap:
How to swap a motor:
Old 10-09-2003, 05:55 PM
Turbogixxer's Avatar
There is mine:
Start paste
OK, I am trying to cover ALL you need to do this swap and all the myths and **** that people have been saying about this swap.
First, Try to find a car that has not been in a front end crash. The new motor mounts are made for a straight frame, so if you have frame damage, the mounts will not line up right.
Motor Mounts: Now, your stock or B-series mounts will not work. You have two choices: 1) Hasport or 2) HCP. The difference in the mounts are little. Hasports cost the is higher than the HCP. The HASport motor mounts were designed for better axles angles, so you have less broken axles. Now, HCP designed there kit more towards the stock prelude mounting position. I mostly use HCP because of the price and seen no real benefits for the HASport besides (in the HCP) if you do not grind enough off the transmission mount, it will grind 5th and reverse. Now, I know you are saying "what about other mounts that I have seen like Place racing, totem, etc?". With place racing, I have seen nothing but problems with axles binding and just poor R&D. With totem, The link will show you all: http://www.jdmshit.com/Totem/ . Totem copied the HCP design and did a shitty job at it. With ALL mounts you will have to use a 92-96 H-series prelude rear transmission bracket.
Axles: You have many choices here. You can use a 90-93 accord intermediate shaft with 90-93 integra axles, or use the prelude intermediate shaft with a 90-93 integra passenger side axle and a hybrid axle with a 'lude inner CV joint and the 90-93 integra shaft and outer CV joint for driver's side axle. The only difference in those axles set-up is the intermediate shaft you use. I have seen them hold to nice horsepower, so you do not have to go the more money route. Another way to go is, Use the prelude intermediate shaft and order up a pair of DSS axles for the swap.
Wiring: I know that people think that this is the hardest part of the swap, but it is not (thanks to that damn shift linkage pin ). Now, the easiest harness to use is your stock harness. Most of the plugs will match up. If the is the same OBD, the colors of the wires will match up too. Now, there we go:
1. You will have to change the injector clips to the h22a style, that is very easy, just cut and splice. Now, your stock injectors are saturated. The H22a injectors are Peak and hold. you will have to wire in a resistor box. It is easy. there is a diagram:
http://www.hondata.com/techinjectorwiring.html
2. You will have to extend the Alternator wiring. Now, if it is the SAME OBD then you should have no problem. All the colors are the same.
3. You will have to length the wire going to the starter solenoid.
4. You will have to use the H22a reverse light plug. No biggy, just cut and splice.
5. Depending on what model and year you have, it will determine how much wiring you will have to do. there is a diagram to help you:
also you may have to rewire the 02 sensor (on VX and CX only) there are the pinouts:
WHT wire goes to D14 (O2 Sensor Input) - needs to be a shielded wire with ground (it has to be shielded wire, or it will not work right)
BLK wire goes to A6 which is Heater Control
GRN wire goes to D22 which is Sensor Ground
BLK wire goes to B1 or A25 which is Sensor voltage
6. As for the EGR, JDM motors you do not have to wire it up, BUT USDM you do. The JDM motors will get a code for it off and on, but just reset the computer, and it will go away.
7. Sensor ID. There is a pic that will make the job easier:
#1 is ECT (engine coolant temperature switch)
#2 is the coolant sending unit (this is what sends your cluster how hot your water is)
#3 is the knock sensor.
#4 is the oil sensor.
NOW, label all the sensors when you take them off. It will make it easier when you put the new motor in.
THINGS TO REPLACE.
When you have the motor/transmission out, you should replace: the clutch, timing belt and balance shaft belt, water pump, spark plugs. Those are just the basics, you can replace more.
COOLING SYSTEM
You will need a 92 integra LS upper Radiator hose and a 1994 Del Sol VTEC lower radiator hose. You can get them almost anywhere. You will have to get a slim fan OR mod. your stock fan to work. I think that the slim fan is the best. They are like $30 at pep boys. Now, as far as the Radiator questions, you can run your stock single core Radiator with no problems, but I would upgrade to a Del Sol VTEC dual core Radiator.
CUTTING AND HACK TO THE CHASSIS
you will need to cut a 2x3 hole for the shift cables. Here is a pic:
you will also have to cut the transmission mount. With the HASport, you will have to cut it off totally. With the HCP, you will only have to cut about 1" x 1" off it.
I think that is it, if you have any questions, just ask!
Special thanks to Brandon (poison) and Dave Newman (Newman)
end paste
I will hopely have a new, better (a lot more pics) one in a week to two weeks.
Old 10-09-2003, 10:30 PM
allmtr's Avatar
How to remove tar from the chassis:
~ https://honda-tech.com/zerothread?id=525936
How to remove carpet:
~ https://honda-tech.com/zerothread?id=512955
How to remove seats:
~ https://honda-tech.com/zerothread?id=512901
H22 vs. b18c5:
B18 vs. B16:
Modified by allmtr at 11:42 PM 10/9/2003
Quick Reply: ***Post Links to Helpful FAQs So We Can Get an Archive Going***
