Old 10-08-2003, 01:52 PM   #1
B18C5-EH2
Moderator
B18C5-EH2's Avatar
Send a message via AIM to B18C5-EH2
Default ***Post Links to Helpful FAQs So We Can Get an Archive Going***
Like the title says.
The mods in here are trying to get together a bunch of 1992-2000 Civic/Del Sol tech articles together so we can cut down on repeated topics.
I'll then sticky the topic, and we can cut down on the repeated topics.
Topics such as brake swaps, ITR rear swaybar installs, Mini-Me VTEC, Si/Type R cluster in non-Si Civics, Mounts for Swaps in certain cars, H22A into Civic, B Series into Civics, Seat swaps, How-Tos for normal stuff like oil changes, bleeding brakes, etc.
I'd like to encourage the link to be H-T topics.
<FONT SIZE="2">Here is a list of the FAQ's listed so far, at least the ones with the HT Links-
[/b]</FONT>
Engine:
http://www.honda-tech.com/zerothread?id=1924483 B16 Bottom End Build
http://honda-tech.com/zerothread?id=554053- SOHC VTEC Mini Me 92-95
http://honda-tech.com/zerothread?id=735196- SOHC VTEC Mini Me 96-00
http://honda-tech.com/zerothread?id=335078- Spades Huge SOHC Upgrades Thread
http://honda-tech.com/zerothread?id=1018993- D16Y8 Manifold onto D16Z6
http://honda-tech.com/zerothread?id=550221- EK Auto to Manual Swap
http://honda-tech.com/zerothread?id=1377459- EK Auto to Manual Swap
http://honda-tech.com/zerothread?id=1316692- Auto to Manual Transmission Conversion for an EG
http://honda-tech.com/zerothread?id=382416- B Series Axle Replacement
http://honda-tech.com/zerothread?id=1135275- Replacing Axles
http://honda-tech.com/zerothread?id=596873- D Series Transmission Disassembly and Input Shaft Bearing Replacement
http://honda-tech.com/zerothread?id=474557- Filling Tranny Through VSS
http://honda-tech.com/zerothread?id=536593- Filling Tranny Through VSS
http://honda-tech.com/zerothread?id=851521- Changing Tranny Fluid
http://honda-tech.com/zerothread?id=644885- Tranny Inspection
http://honda-tech.com/zerothread?id=811691- Transmission Removal
http://honda-tech.com/zerothread?id=470849- Shift Linkage Bitch Pin
http://honda-tech.com/zerothread?id=569187- Fake J’s Intake Review
http://honda-tech.com/zerothread?id=469492- B16 vs B18 Head
http://honda-tech.com/zerothread?id=1007935- Short Shifter Install
http://honda-tech.com/zerothread?id=745235- Short Shifter Install
http://honda-tech.com/zerothread?id=1206651- Fastline Performance Shifter Review
http://honda-tech.com/zerothread?id=1001924- ES Shifter Bushings
http://honda-tech.com/zerothread?id=1002429- ES Shifter Bushings
http://honda-tech.com/zerothread?id=558236- Erratic Idle
http://honda-tech.com/zerothread?id=699787- Fixing Fast Idle Throttle Valve
http://honda-tech.com/zerothread?id=757695- DIY Catch Can
http://honda-tech.com/zerothread?id=649277- Timing Belt and Water Pump
http://honda-tech.com/zerothread?id=1424191- How to Flush Coolant and Change Thermostat
http://honda-tech.com/zerothread?id=184202- Power Steering to Manual Steering
http://honda-tech.com/zerothread?id=1065831- Distributor O Ring
http://honda-tech.com/zerothread?id=474849- DOHC VTEC Valve, Valve Spring, and Retainer Replacement
http://honda-tech.com/zerothread?id=864710- SOHC Camshaft and Valve Springs Install
http://honda-tech.com/zerothread?id=640755- Painting Valve Cover
http://honda-tech.com/zerothread?id=782937- Painting Valve Cover
http://honda-tech.com/zerothread?id=491789- Painting Valve Cover
http://honda-tech.com/zerothread?id=543704- Cleaning Engine Bay
http://honda-tech.com/zerothread?id=1305086- D-Series Valve Lash Adjustment
http://honda-tech.com/zerothread?id=1113916- Header Installation
http://honda-tech.com/zerothread?id=1563439- Polishing a Header
http://honda-tech.com/zerothread?id=1230433- Installing B&M Fuel Pressure Modifier
http://honda-tech.com/zerothread?id=1414880- Wire Tuck for SOHC EG
http://honda-tech.com/zerothread?id=1564019- Cleaning FITV aka Fast Idle Thermo Valve
http://honda-tech.com/zerothread?id=898904- Removing Crank Pulley
http://honda-tech.com/zerothread?id=1497875- DIY Leakdown Tester
http://honda-tech.com/zerothread?id=1491041- DIY Leakdown Test
http://honda-tech.com/zerothread?id=1521170- Everything You Need to Know About Fuel Setups
http://honda-tech.com/zerothread?id=1529645- Everything You Need to Know About Cooling Systems
http://honda-tech.com/zerothread?id=1534856- Everything You Need to Know About Motor Oil
Suspension/Brakes:
http://honda-tech.com/zerothread?id=152884- Putting X Brakes on Y Car
http://honda-tech.com/zerothread?id=514109- 96-97 JDM ITR 4 Lug Brake Information
http://honda-tech.com/zerothread?id=811892- ITR 4 Lug onto EK
http://honda-tech.com/zerothread?id=514109- ITR Brake Thread
http://honda-tech.com/zerothread?id=333061- Five Lug Conversion
http://honda-tech.com/zerothread?id=1036267- GSR Suspension into EG
http://honda-tech.com/zerothread?id=812062- Integra Rear Discs onto EG
http://honda-tech.com/zerothread?id=820484- Full Brake Swap for EG
http://honda-tech.com/zerothread?id=641639- EK Rear Disc Conversion
http://honda-tech.com/zerothread?id=1513752- How to put X Brake Setup on an EK
http://honda-tech.com/zerothread?id=641639- Complete Rear Disc Brake Conversion
http://honda-tech.com/zerothread?id=1030365- Integra Brake Swap
http://home.socal.rr.com/civic...x.htm- Cutting Away Old Control Arm Bushings and Using New Ones
http://honda-tech.com/zerothread?id=490117- Tie Rod End Removal
http://honda-tech.com/zerothread?id=1031874- Changing Tie Rod Ends
http://home.earthlink.net/~civ....html- Bolt and Washer Camber Fix
http://honda-tech.com/zerothread?id=481704- Jim Fab Traction Bar Install
http://honda-tech.com/zerothread?id=555391- HX Wheels on GSR or Si
http://honda-tech.com/zerothread?id=861481- Rear Lower Tie Brace Install
http://honda-tech.com/zerothread?id=972851- Front Tower Bar Install
http://honda-tech.com/zerothread?id=1079213- Lower Tie Brace Install
http://honda-tech.com/zerothread?id=1078663- Coilover Sleeve Install
http://honda-tech.com/zerothread?id=1278794- Installing Lowering Springs
[url="http://honda-tech.com/zerothread?id=600967"] http://honda-tech.com/zerothread?id=600967[/url]- NSX Calipers
http://honda-tech.com/zerothread?id=864784- Brake Rotor Replacement
http://honda-tech.com/zerothread?id=1317231- Quaife Steering into EG
http://honda-tech.com/zerothread?id=1427142- Shock/Strut Removal of EG
http://honda-tech.com/zerothread?id=1484555- Integra GSR Sized Brakes While Keeping Stock DX Civic Knuckles
http://honda-tech.com/zerothread?id=1437513- Blank vs. Cross Drilled Rotors
Interior:
http://honda-tech.com/zerothread?id=525936- Removing Sound Deadening Tar from EG
http://honda-tech.com/zerothread?id=512955- Removing Carpet from EG
http://honda-tech.com/zerothread?id=512901- Removing Back Seat from EG
http://honda-tech.com/zerothread?id=690687- Removing Rear Quarter Trim Panels from EG
http://honda-tech.com/zerothread?id=692729- Removing Headliner and Pillar Trim Panels from EG
http://honda-tech.com/zerothread?id=600430- EG Dash Removal
http://honda-tech.com/zerothread?id=598255- Removing Paint from Interior
http://honda-tech.com/zerothread?id=721218- Removing EG Clock
http://honda-tech.com/zerothread?id=814006- Steering Wheel and Intermittent Wiper Removal
http://honda-tech.com/zerothread?id=851733- EK Steering Wheel Replacement
http://honda-tech.com/zerothread?id=646354 - How To Fix Door Slam Sound
http://honda-tech.com/zerothread?id=632263- Window Visor How To
http://honda-tech.com/zerothread?id=629098- How To Install EK Window Visors
http://honda-tech.com/zerothread?id=347548- S2000 Seat Install
http://honda-tech.com/zerothread?id=1479028- S2000 Seats into Del Sol
http://honda-tech.com/zerothread?id=1436635- Integra Seats into EJ
http://honda-tech.com/zerothread?id=627857- Rear Seats in EG Hatch
http://honda-tech.com/zerothread?id=481758- ITR Seats into EK and EG
http://honda-tech.com/zerothread?id=826594- Del Sol Seats into EK
http://honda-tech.com/zerothread?id=1225538- RSX Seats with Custom Brackets into EK
http://honda-tech.com/zerothread?id=766603- 92-96 Prelude Seats into EK
http://honda-tech.com/zerothread?id=577769- DIY Seat Brackets
http://honda-tech.com/zerothread?id=473878- DIY Door Panels
http://honda-tech.com/zerothread?id=661308- EG Amber Dash Lighting
http://honda-tech.com/zerothread?id=1186091- EK Amber Climate Control
http://honda-tech.com/zerothread?id=374250- Amber GSR Cluster
http://honda-tech.com/zerothread?id=220512- Amber GSR Cluster
http://honda-tech.com/zerothread?id=605432- 99-00 Climate Control into 96-98 Civic
http://honda-tech.com/zerothread?id=407737- ITR Cluster into EK
http://honda-tech.com/zerothread?id=437408- GSR Cluster into EG
http://honda-tech.com/zerothread?id=504396- GSR Cluster into EG
http://honda-tech.com/zerothread?id=304752- GSR Cluster into EG
http://honda-tech.com/zerothread?id=364837- GSR Cluster into EG
http://honda-tech.com/zerothread?id=557403- EG Cluster Over Si Cluster
http://honda-tech.com/zerothread?id=602325- Si Cluster in EG
http://honda-tech.com/zerothread?id=1053318- Integra Cluster into Civic
http://honda-tech.com/zerothread?id=290569- Headlight Warning Buzzer
http://honda-tech.com/zerothread?id=651657- Headlight Warning Buzzer
http://honda-tech.com/zerothread?id=457308- Cleaning Out Blower Motor
http://honda-tech.com/zerothread?id=285567- Integra Dash in EG
http://honda-tech.com/zerothread?id=170977- Integra Dash in EG
http://honda-tech.com/zerothread?id=1211255- Integra Dash in EG
http://honda-tech.com/zerothread?id=276819- Changing Odometer
http://honda-tech.com/zerothread?id=413826- Changing Odometer
http://honda-tech.com/zerothread?id=851492- Calibrating Speedometer
http://honda-tech.com/zerothread?id=593924- Manual Door Locks
http://honda-tech.com/zerothread?id=612414- Power Windows into EG
http://honda-tech.com/zerothread?id=145543- Power Windows into EG
http://honda-tech.com/zerothread?id=619175– Power Windows into EG
http://honda-tech.com/zerothread?id=749123- Power Lock Conversion
http://honda-tech.com/zerothread?id=1065575- Power Windows, Locks, Mirrors into EG
http://honda-tech.com/zerothread?id=619175- EG Power Windows
http://honda-tech.com/zerothread?id=615442- Cargo or Trunk Light in EK Hatch
http://honda-tech.com/zerothread?id=724917- Water in EG
http://honda-tech.com/zerothread?id=264288- Resetting SRS Light
http://honda-tech.com/zerothread?id=747144- Raising Visibility with Spoon Knockoffs
http://honda-tech.com/zero...15302- Push Button Start
http://honda-tech.com/zerothread?id=949918- DIY Tach Installation
http://honda-tech.com/zerothread?id=1303448- DIY Shifter Plate
http://honda-tech.com/zerothread?id=1485735- Aftermarket steering wheel install
Exterior:
http://honda-tech.com/zerothread?id=476935- Prepping Car for Paint
http://honda-tech.com/zerothread?id=542359- Prepping Car for Paint
http://honda-tech.com/zerothread?id=376870- Painting Your Car, Tips, Tools and Techniques
http://honda-tech.com/zerothread?id=965005- Painted Door Handles and Mirrors
http://honda-tech.com/zerothread?id=489625- Painting Exterior Trim Pieces
http://honda-tech.com/zerothread?id=316500- Painting Wheels
http://honda-tech.com/zerothread?id=587932- EK Sidemarker Diagrams
http://honda-tech.com/zerothread?id=594739- HT’s Nicest EG
http://honda-tech.com/zerothread?id=597437- HT’s Nicest DC
http://honda-tech.com/zerothread?id=594775- HT’s Nicest EK
http://honda-tech.com/zerothread?id=142946- EK Sides on EG
http://honda-tech.com/zerothread?id=456775- EK Sides on EG
http://honda-tech.com/zerothread?id=500842- EK Sides on EG
http://honda-tech.com/zerothread?id=1528222- EG VX Lip on Del Sol
http://honda-tech.com/zerothread?id=491711- HX Wheels on EG
http://honda-tech.com/zerothread?id=343860- DIY Grille
http://honda-tech.com/zerothread?id=282131- Baking EK Headlights
http://honda-tech.com/zerothread?id=812732- DIY Black Housing EK Headlights
http://honda-tech.com/zerothread?id=813522- Sidemarkers
http://www.jdmvtec.com/silipinstall.html- Si Lip on EG
http://www.autodynamic.com/tra...r.htm- EG Lip Install
http://honda-tech.com/zerothread?id=964126- Home Depot Lip
http://honda-tech.com/zerothread?id=458570- City Lights
http://honda-tech.com/zerothread?id=683685- Main HID Thread
http://honda-tech.com/zerothread?id=495898- HID Thread
http://honda-tech.com/zerothread?id=503542- HID Thread
http://honda-tech.com/zerothread?id=574577- HID Thread
http://honda-tech.com/zerothread?id=501058- Projector Thread
http://honda-tech.com/zerothread?id=612520- Projector Thread
http://honda-tech.com/zerothread?id=622672- Projector Thread
http://honda-tech.com/zerothread?id=640997- Projector Thread
http://honda-tech.com/zerothread?id=751356- DIY Yellow Fogs
http://honda-tech.com/zerothread?id=1352749- EG 2/3 Door Foglight Install
http://honda-tech.com/zerothread?id=1268962- Lamin-X Your Foglights
http://honda-tech.com/zerothread?id=1268994- Lamin-X Your Foglights
http://honda-tech.com/zerothread?id=790135- 99-00 Front End on 96-98
http://honda-tech.com/zero...02068- Quarter Panel Glass
http://honda-tech.com/zerothread?id=817274- Del Sol Aux Light Rewire
http://honda-tech.com/zerothread?id=845731- Fixing Windshield Wipers
http://honda-tech.com/zerothread?id=1067080- Integra Sunroof into EG
http://honda-tech.com/zerothread?id=1132916- More Visibility/Adjustability from Fake Spoon Mirrors
http://honda-tech.com/zerothread?id=1299297- More Visibility from Fake Spoon Mirrors
http://honda-tech.com/zerothread?id=1130443- Polishing HX and VX Rims
http://honda-tech.com/zerothread?id=1201257- How To Prevent Your Doors From Rusting
http://honda-tech.com/zerothread?id=1235865- Fixing a Rubbing Fender
http://honda-tech.com/zerothread?id=885253- Fixing EK Hatch Water Leak
http://honda-tech.com/zerothread?id=1507848- Fender Installation
Specifications:
http://honda-tech.com/zerothread?id=150315- EG Hatchback Weights
http://honda-tech.com/zerothread?id=352990- EG Hatchback Stock Colors
http://honda-tech.com/zerothread?id=363047- VTEC Cams Comparison
http://honda-tech.com/zerothread?id=684550- H22 vs B Series Weight
http://honda-tech.com/zerothread?id=1169414- D-Series Torque Specifications
http://honda-tech.com/zerothread?id=682485- Engine Compression Ratio Formulas
http://www.hadamotorsport.com/....html- D Series Header Comparison
http://honda-tech.com/zerothread?id=694733- Civic Chassis Codes
http://honda-tech.com/zerothread?id=869206- EK Paint Colors
http://honda-tech.com/zerothread?id=850751- Identifying B Series Transmissions
http://honda-tech.com/zerothread?id=958024- Hood Weights
http://honda-tech.com/zerothread?id=1300459 - D-Series/B-Series Interchangeable Parts
http://honda-tech.com/zerothread?id=1024818- 92-00 Civic Interchangeable Parts
Electrical:
http://honda-tech.com/zerothread?id=682412- ECU Codes
http://honda-tech.com/zerothread?id=587460- Repinning an ECU
http://honda-tech.com/zerothread?id=810101- Identifying an ECU
http://honda-tech.com/zerothread?id=478377- ECU Pinouts
http://honda-tech.com/zerothread?id=558245- EK Wiring Information
http://honda-tech.com/zerothread?id=413799- Hondata Vs. AEM EMS
http://honda-tech.com/zerothread?id=644434- B18C1 into VX Wiring Instructions
http://honda-tech.com/zerothread?id=724252- Wiring VTEC
http://honda-tech.com/zerothread?id=461376- OBD2 to OBD1
http://honda-tech.com/zerothread?id=910218- Fuse Layout
http://honda-tech.com/zerothread?id=1966666- Civic & Del Sol Fuses (printable panel diagrams)
http://honda-tech.com/zerothread?id=418159- VAFC Wiring Diagrams
http://honda-tech.com/zerothread?id=539424- EG Mirrors Wiring
http://honda-tech.com/zerothread?id=646714- EG Mirrors Wiring
http://honda-tech.com/zero...98906- Tach Lead for EG
http://honda-tech.com/zerothread?id=807030- Reprogramming Keyless Entry Remotes
http://honda-tech.com/zerothread?id=1066681- Proper Form of Overcurrent Protection
http://honda-tech.com/zerothread?id=1513794- Code 1 Fix for EG VX/CX Owners
Swaps:
http://honda-tech.com/zerothread?id=878010- Swaps Available For Civics
http://honda-tech.com/zerothread?id=50010- Places People Got Their Swaps
http://honda-tech.com/zerothread?id=434668- H22 Axle Information
http://honda-tech.com/zerothread?id=362984- H22A General Information
http://honda-tech.com/zerothread?id=362984- H22 Swap, Rumors or Truth?
http://honda-tech.com/zerothread?id=650329- H22 Info
http://honda-tech.com/zerothread?id=550976- Swapping in a B Series
http://honda-tech.com/zerothread?id=856396- B18C1 into EG
http://honda-tech.com/zerothread?id=635782- ITR Swap into 92-95 VX
http://honda-tech.com/zerothread?id=131949- How To Swap a Motor
http://honda-tech.com/zerothread?id=626892- H22 vs. B18C5
http://honda-tech.com/zerothread?id=528602- B16 vs B18
http://honda-tech.com/zerothread?id=359189- B16 vs B18
http://honda-tech.com/zerothread?id=216389- B16 vs B18
http://honda-tech.com/zerothread?id=163450- B16 vs B18
http://honda-tech.com/zerothread?id=447623- B20 into EK
http://honda-tech.com/zerothread?id=504321- B20 into EK
http://honda-tech.com/zerothread?id=508054- B20 into EG
http://honda-tech.com/zerothread?id=466327- Removing Engine Without Hoist
Forced Induction:
http://honda-tech.com/zerothread?id=544653- Edelbrock Turbo
http://honda-tech.com/zerothread?id=377208- Oil Lines on Firewall
http://honda-tech.com/zerothread?id=635014- Turbo Kit Install
http://honda-tech.com/zerothread?id=517274- Resistor Box
General:
http://honda-tech.com/zerothread?id=352308- A Link to Many More FAQ’s
http://honda-tech.com/zerothread?id=629535- How Tire Size Affects Gearing
http://honda-tech.com/zerothread?id=183552- Road Racing on an H22 Civic
http://honda-tech.com/zerothread?id=721575- Helpful Tips by Emerika
http://honda-tech.com/zerothread?id=1016891- SeaFoam
http://honda-tech.com/zerothread?id=1059690- SeaFoam
http://honda-tech.com/zerothread?id=858511- SOHC Quarter Mile Times
http://honda-tech.com/zerothread?id=858510- DOHC Quarter Mile Times
http://honda-tech.com/zerothread?id=802260- Pros and Cons of A/C and PS
http://honda-tech.com/zerothread?id=551049- BAR Swap Approval in CA
http://honda-tech.com/zerothread?id=815454- Ref Station Review
http://honda-tech.com/zerothread?id=853679- Passing CA Ref
http://honda-tech.com/zero...59796- Converting JDM Intake Mani to US Specs for Ref
http://honda-tech.com/zerothread?id=906684- Converting JDM Motor to US Specs
http://honda-tech.com/zerothread?id=867722- How to Pass Exhaust Test in CA
http://honda-tech.com/zerothread?id=884696- Buying a Used Civic
http://honda-tech.com/zerothread?id=859655- What Octane Gas to Use?
http://www.honda-tech.com/zerothread?id=701236 Smog, what it is and how it affects you.
B18C5-EH2 is offline Report Post   Reply With Quote
Old 10-08-2003, 01:55 PM   #2
silverEH2
silverEH2's Avatar
Send a message via AIM to silverEH2
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (B18C5-EH2)
i like this one, all your ecu pinouts
silverEH2 is offline Report Post   Reply With Quote
Old 10-08-2003, 02:06 PM   #3
BauleyCivic
Risky Business
2005 Toyota Corolla
BauleyCivic's Avatar
Send a message via AIM to BauleyCivic
D15 SOHC VTEC Mini-Me How-To Writeup:
http://www.honda-tech.com/zerothread?id=554053
SOHC Transmission Disassembly and Input Shaft Bearing Replacement:
http://www.honda-tech.com/zerothread?id=596873
Tire Size and Gearing Information:
http://www.honda-tech.com/zerothread?id=629535
My comprehensive preview of the 2010 Formula 1 Season
http://www.honda-tech.com/showthread.php?t=2676702
BauleyCivic is offline Report Post   Reply With Quote
Old 10-08-2003, 02:47 PM   #4
Pho Real
Pho Real's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (BauleyCivic)
http://www.honda-tech.com/zerothread?id=605432
99-00 Climate control into 96-98
Pho Real is offline Report Post   Reply With Quote
Old 10-08-2003, 03:12 PM   #5
poison
poison's Avatar
H22A into Civic information:
MERGING OBD1 CIVIC HARNESS TO H22A ENGINE:
- Take off and mark every single harness connector on where it came from/where it goes from both H22A and stock civic engine. Make sure you label them of where pulled the plug from! This will save a TON of time!
Mount Civic harness on H22A and measure/modify wire to be lengthened/changed as follows:
- Change fuel injector connectors to H22A type and add resistor pack from H22A harness to Civic harness (see diagram on page 4)
- Extend Alternator wires to reach the H22A alternator (match the pinouts)
- Lengthen wire that goes to the starter solenoid on starter
- Attach reverse light sensor wire to the new H22A reverse light sensor wire
O2 sensor (CX only) add 3 wires to O2 sensor and follow o2 wires and change to Prelude O2 sensor connector. And wire the following:
- WHT/RED wire goes to D14 which is O2 Sensor Input
- ORG/BLK wire goes to A6, which is Heater Control
- GRN/WHT wire goes to D22 which is Sensor Ground
- YEL/BLK wire goes to A25 which is Sensor voltage
VTEC wiring: This applies to DX,LX,CX models only in 93-95!
- Wire from the VTEC Solenoid to the A4 pinout at the ECU. Add the pin to the shock tower harness, and female pin at the female shock tower connector.
Knock sensor wiring: (mounted at the rear of the engine near the cylinder head)
Air Intake Bypass solenoid (secondary butterflies)
- Sensor voltage to the A25 pinout (or splice into the Yel/Blk wire connector at the driver shock tower harness.
- ECU Signal leading to A17 pinout on ECU
EGR (Exhaust Gas Recirculation) System: Applies to all model civics except VX
- EGR lift valve solenoid – sensor voltage (A25 pinout) & ECU signal to A11
- EGR lift sensor – sensor voltage (A25 pinout), ground (D22 pinout) & ECU sensor signal to D12
MOUNT KITS AVAILABLE:
- HASport mount kit
- Place Racing Mounts
- HCP Mount kits
MAINTENANCE PRE-CAUTIONS
- Timing Belt for 92-96 USDM Prelude VTEC (2.2L) - $39.99 from AutoZone
- Water Pump for 92-96 USDM Prelude VTEC (2.2L) - $34.99 w/lifetime warranty from AutoZone
- Spark Plugs for USDM 92-96 Prelude VTEC (2.2L) – approx. $8
- Extended Fuel filter hose (from fuel filter to fuel rail) – You can use an extended fuel line and use hose connectors/clamps, or contact a local hose factory to have a custom hose made.
- Throttle Body gasket for Prelude VTEC (Honda dealership) $7
Drivetrain options:
- Right 90-93 Integra Axle
- Left Custom 92 Prelude Inner CV joint with 90-93 shaft & Outer CV joint from Raxles for $170 1-800-257-8192
OR
- 1990 Accord Intermediate Shaft
- Left and Right 90-93 Integra Axles
OR
- Driveshaftshop.com Stage/Level 1 axles Right & Left side using prelude intermediate shaft
Radiator options:
- FAL import racing fan for 92-00 Civic for $169.95 from Summit Racing 1-800-962-9094 with 1994-97 Del Sol VTEC Radiator or Integra Radiator
OR
- C&R Import Racing aluminum radiator with SPAL fan for DOHC motors - $439.95 (317) 293-4100
- 1992 Integra LS Upper Radiator Hose – approx. $15
- 1994 Del Sol VTEC lower radiator hose – approx. $15
If you are running NO A/C then you can get alternator belt - Part No. 25-060370 from NAPA Auto parts which is $20 or any 36-37” belt with 6 teeth.
I will post pictures here in a second...
-Brandon
'92 SM/TTE K20R hatch
"Most amateur drivers go too fast in slow corners and too slow in fast corners" Emerson Fittipaldi
poison is offline Report Post   Reply With Quote
Old 10-08-2003, 03:20 PM   #6
poison
poison's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (poison)
VX O2 sensor fix:
If you have a VX model Civic, and you do NOT use the VX engine harness, in order for your O2 sensor to properly work, you need to move the ORG/BLU wire from the 4th connector at the shock tower harness, and move it matching with the WHT wire on the 4 wire embedded engine harness.
-Brandon
Old 10-08-2003, 03:25 PM   #7
poison
poison's Avatar
GSR Dash into EG wiring information:
Using the GSR harness (which I have done), it's very simple to get your dash 100% working.
You can use the GREEN and BLUE plug, which plug right into the Civic fuse box plugs.
HOWEVER
The grey plug has additional pinouts on the Integra dash harness and cannot be used. Just retain the Civic grey plug and match the pinouts.
I am currently making a JPEG diagram for this -- will be up soon.
ONE THING, your turn signals will not work.
Why?
This is why:
The power wire going to the Integra hazard switch is the Yel/Blk wire, where-as the Civic hazard switch is the YEL wire.
Just simply take the Yel/Blk wire from the Integra harness (which is an unused wire from the grey plug), and splice that into the Yel wire on the GREEN plug (the middle pinout YEL wire.
Kaboom -- done.
More info soon...
Modified by poison at 4:43 PM 10/8/2003
-Brandon
Old 10-08-2003, 03:34 PM   #8
poison
poison's Avatar
Here is some of VX's awesome detailed How-To's
Remove Sound deadening Tar from an EG:
Remove Carpet from an EH hatch:
Remove Rear/Back seat from an EH hatch:
Awesome work VX!
-Brandon
Old 10-08-2003, 03:41 PM   #9
poison
poison's Avatar
Road racing on an H22 Civic by Newman:
H22A Civic Axle information by Newman:
EK wiring information by Katman:
http://www.honda-tech.com/zerothread?id=558245
Modified by poison at 4:54 PM 10/8/2003
-Brandon
Old 10-08-2003, 04:11 PM   #10
poison
poison's Avatar
Yet, more H22A information:
http://www.honda-tech.com/zerothread?id=362984
-Brandon
Old 10-08-2003, 05:03 PM   #11
TrickHonda98
TrickHonda98's Avatar
Send a message via AIM to TrickHonda98
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (splitime)
(I thought that this part of this thread was a small waste of space, i edited my old message and put thses in. )
What the engine codes mean:
~ex.~ B18C5
B stands for b series motor
18 stands for 1.8 liter
C, C1, C5 stands for the classification and USDM JDM.
C=JDM C1=USDM C5=TypeR
engine codes
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K20A3 2.0L DOHC i-VTEC '02+ RSX
'02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S
02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX
130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL
150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiRS Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
ECU CODES
PG6 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR2 : 89-91 ZC (Euro)
PR3 : 89-91 JDM B16A EF8/9
PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door Civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P08 : 92-95 OBD-1 Civic D15 JDM
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31 : 1997 Honda Accord 1.8 LS
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2E : 96+ OBD-2 Civic DX Coupe
P2M : 96+ OBD-2 NZ Civic SOHC VTEC
P2T : 99+ OBD-? Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA : 97+ US Acura 1.6EL
PCT : 98+ JDM ITR / CTR
PCX : 99+ OBD-? S2000
Modified by TrickHonda77 at 8:32 PM 6/18/2004
Modified by TrickHonda98 at 4:55 PM 6/28/2004
*PROJECT CAR*'92 Civic Hatch: Doing AWD conv. and b20swap
98Civic Coop w/B18C5 block/B16 head. DOHC VTEC- (
Time as of June 16th - 11.81sec@127.2 MPH
<U>H</u>ell <u>O</u>fa <u>N</u>ice <u>D</u>amn <u>A</u>uto
TrickHonda98 is offline Report Post   Reply With Quote
Old 10-08-2003, 06:04 PM   #12
VX
VX's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (TrickHonda77)
1995.5 - 1997 JDM ITR 4-Lug (4x114.3mm) Brake Tech Thread!
How-To: Change Out Main Rear Trailing Arm Bushings!
How-To: Cut Away Old Control Arm Bushings & Press In New Ones!
Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch!
Detailed How To: Remove Headliner & Pillar Trim Panels From An EH Hatch!
I'll edit this post in the future when i can dig up more tech threads.
Modified by VX at 8:05 PM 11/30/2003
VX is offline Report Post   Reply With Quote
Old 10-08-2003, 06:57 PM   #13
shorti
shorti's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (VX)
i know this is the eg+ forum but i have a bunch of links for 4th gens too
4th gen SiR cluster install
http://www.geocities.com/Motor....html
4th gen ECU Codes and trouble shooting
http://www.honda-tech.com/zerothread?id=468260
EF Canards
http://www.honda-tech.com/zerothread?id=432972
How-To: Extended Shock Travel
http://www.honda-tech.com/zerothread?id=469485
SOHC upgrades *REVISED* It's long and is a work in progress.
http://www.honda-tech.com/zerothread?id=335078
RNN14 KH3
shorti is offline Report Post   Reply With Quote
Old 10-08-2003, 07:32 PM   #14
Smith Wise
Smith Wise's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (shorti)
Y8 Manifold on Y7
Y8 Manifold swap on Y7
EG Dash Removal
EG Dash Removal
Remove Paint from Interior
Yes I was stupid enough to paint it!!
Manual Door Locks
Manual Door Locks
Auto to Manual
That's it for now.
edit: How could I forget.........
EK Dash Removal
EK Dash Removal
EM1 Cluster in Auto EK
Just a warning about the "extra plugs"
Smith Wise is offline Report Post   Reply With Quote
Old 10-08-2003, 07:41 PM   #15
Fred n J_v2.0
Fred n J_v2.0's Avatar
Send a message via AIM to Fred n J_v2.0
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (Jswpstdoff)
tom's post in here is very insightful... about the fifth/sixth one down
swapping in a b-series:
http://www.honda-tech.com/zerothread?id=550976
Fred n J_v2.0 is offline Report Post   Reply With Quote
Old 10-08-2003, 10:30 PM   #16
smnowell
smnowell's Avatar
How-To: DOHC VTEC Valve, Valve Spring, and Ti Retainer Replacement
http://www.honda-tech.com/zerothread?id=474849
How-To: Paint Your Car - Tips, Tools, and Techniques
http://www.honda-tech.com/zerothread?id=376870
smnowell is offline Report Post   Reply With Quote
Old 10-08-2003, 11:01 PM   #17
degooser
degooser's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (b16a ferio)
<FONT COLOR="blue"> California people who never thought that a JDM motor will pass at the State Ref...!</FONT>
Modified by degooser at 9:01 AM 4/2/2004
Club B.A.R. '03
bored? listen to this...
INTERNET RADIO
degooser is offline Report Post   Reply With Quote
Old 10-09-2003, 05:31 AM   #18
ki3t
ki3t's Avatar
Send a message via AIM to ki3t
5 lug conversion
http://www.honda-tech.com/zerothread?id=333061
<FONT COLOR="blue">Vouch </FONT>
Ex-Priv User Club Member
ki3t is offline Report Post   Reply With Quote
Old 10-09-2003, 06:37 AM   #19
2000blackgsr
2000blackgsr's Avatar
Send a message via AIM to 2000blackgsr
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (B18cR-Ej1)
How to put X Brakes on Y Car
http://www.honda-tech.com/zerothread?id=152884
2000blackgsr is offline Report Post   Reply With Quote
Old 10-09-2003, 07:10 AM   #20
B18C5-EH2
Moderator
B18C5-EH2's Avatar
Here's a nice DIY for painting your exterior trims to make them look like brand new O-E pieces:
Old 10-09-2003, 08:07 AM   #21
Nerv2g
Nerv2g's Avatar
This post shows pics of what poison is talking about. (The ITR swap into a 92-95 VX).
http://www.honda-tech.com/zerothread?id=635782
Your style is like dying in my sleep, i'm not feeling it.
Pics of my hatch http://www.honda-tech.com/zerothread?id=664611
Nerv2g is offline Report Post   Reply With Quote
Old 10-09-2003, 09:58 AM   #22
BauleyCivic
Risky Business
2005 Toyota Corolla
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (Nerv2g)
How to Paint Wheels:
http://www.honda-tech.com/zerothread?id=316500
Old 10-09-2003, 11:15 AM   #23
poison
poison's Avatar
Default Re: ***Post Links to Helpful FAQs So We Can Get an Archive Going*** (DvSiR)
Places people got their swap:
http://www.honda-tech.com/zerothread?id=50010
How to swap a motor:
http://www.honda-tech.com/zerothread?id=131949
-Brandon
Old 10-09-2003, 06:55 PM   #24
Turbogixxer
Turbogixxer's Avatar
There is mine:
Start paste
OK, I am trying to cover ALL you need to do this swap and all the myths and shit that people have been saying about this swap.
First, Try to find a car that has not been in a front end crash. The new motor mounts are made for a straight frame, so if you have frame damage, the mounts will not line up right.
Motor Mounts: Now, your stock or B-series mounts will not work. You have two choices: 1) Hasport or 2) HCP. The difference in the mounts are little. Hasports cost the is higher than the HCP. The HASport motor mounts were designed for better axles angles, so you have less broken axles. Now, HCP designed there kit more towards the stock prelude mounting position. I mostly use HCP because of the price and seen no real benefits for the HASport besides (in the HCP) if you do not grind enough off the transmission mount, it will grind 5th and reverse. Now, I know you are saying "what about other mounts that I have seen like Place racing, totem, etc?". With place racing, I have seen nothing but problems with axles binding and just poor R&D. With totem, The link will show you all: http://www.jdmshit.com/Totem/ . Totem copied the HCP design and did a shitty job at it. With ALL mounts you will have to use a 92-96 H-series prelude rear transmission bracket.
Axles: You have many choices here. You can use a 90-93 accord intermediate shaft with 90-93 integra axles, or use the prelude intermediate shaft with a 90-93 integra passenger side axle and a hybrid axle with a 'lude inner CV joint and the 90-93 integra shaft and outer CV joint for driver's side axle. The only difference in those axles set-up is the intermediate shaft you use. I have seen them hold to nice horsepower, so you do not have to go the more money route. Another way to go is, Use the prelude intermediate shaft and order up a pair of DSS axles for the swap.
Wiring: I know that people think that this is the hardest part of the swap, but it is not (thanks to that damn shift linkage pin ). Now, the easiest harness to use is your stock harness. Most of the plugs will match up. If the is the same OBD, the colors of the wires will match up too. Now, there we go:
1. You will have to change the injector clips to the h22a style, that is very easy, just cut and splice. Now, your stock injectors are saturated. The H22a injectors are Peak and hold. you will have to wire in a resistor box. It is easy. there is a diagram:
http://www.hondata.com/techinjectorwiring.html
2. You will have to extend the Alternator wiring. Now, if it is the SAME OBD then you should have no problem. All the colors are the same.
3. You will have to length the wire going to the starter solenoid.
4. You will have to use the H22a reverse light plug. No biggy, just cut and splice.
5. Depending on what model and year you have, it will determine how much wiring you will have to do. there is a diagram to help you:
also you may have to rewire the 02 sensor (on VX and CX only) there are the pinouts:
WHT wire goes to D14 (O2 Sensor Input) - needs to be a shielded wire with ground (it has to be shielded wire, or it will not work right)
BLK wire goes to A6 which is Heater Control
GRN wire goes to D22 which is Sensor Ground
BLK wire goes to B1 or A25 which is Sensor voltage
6. As for the EGR, JDM motors you do not have to wire it up, BUT USDM you do. The JDM motors will get a code for it off and on, but just reset the computer, and it will go away.
7. Sensor ID. There is a pic that will make the job easier:
#1 is ECT (engine coolant temperature switch)
#2 is the coolant sending unit (this is what sends your cluster how hot your water is)
#3 is the knock sensor.
#4 is the oil sensor.
NOW, label all the sensors when you take them off. It will make it easier when you put the new motor in.
THINGS TO REPLACE.
When you have the motor/transmission out, you should replace: the clutch, timing belt and balance shaft belt, water pump, spark plugs. Those are just the basics, you can replace more.
COOLING SYSTEM
You will need a 92 integra LS upper Radiator hose and a 1994 Del Sol VTEC lower radiator hose. You can get them almost anywhere. You will have to get a slim fan OR mod. your stock fan to work. I think that the slim fan is the best. They are like $30 at pep boys. Now, as far as the Radiator questions, you can run your stock single core Radiator with no problems, but I would upgrade to a Del Sol VTEC dual core Radiator.
CUTTING AND HACK TO THE CHASSIS
you will need to cut a 2x3 hole for the shift cables. Here is a pic:
you will also have to cut the transmission mount. With the HASport, you will have to cut it off totally. With the HCP, you will only have to cut about 1" x 1" off it.
I think that is it, if you have any questions, just ask!
Special thanks to Brandon (poison) and Dave Newman (Newman)
end paste
I will hopely have a new, better (a lot more pics) one in a week to two weeks.
Turbogixxer is offline Report Post   Reply With Quote
Old 10-09-2003, 11:30 PM   #25
allmtr
How to remove tar from the chassis:
~ http://www.honda-tech.com/zerothread?id=525936
How to remove carpet:
~ http://www.honda-tech.com/zerothread?id=512955
How to remove seats:
~ http://www.honda-tech.com/zerothread?id=512901
H22 vs. b18c5:
http://www.honda-tech.com/zerothread?id=626892
B18 vs. B16:
http://www.honda-tech.com/zerothread?id=528602
http://www.honda-tech.com/zerothread?id=359189
http://www.honda-tech.com/zerothread?id=216389
http://www.honda-tech.com/zerothread?id=163450
Modified by allmtr at 11:42 PM 10/9/2003
allmtr is offline Report Post   Reply With Quote
Bookmarks
16l, 2000, 92, 95, accord, axles, civic, cleaning, diagram, egr, fluid, lead, replace, rod, tie, transmission, vtec, wiring
