transmission problem Help!
Old Jul 4, 2007 | 09:21 AM
jdmdelsol94's Avatar
Default transmission problem Help!
i just put in a ACT 6 puc clutch disc package....new release bearing and all the above...now when i turn the car on and pump the clutch no reasponse...new master and slave cylinder cuz they where leaking and bled the system....nothing...any help would be greatful and highly appreciated...thank you
Old Jul 4, 2007 | 09:24 AM
DaveF's Avatar
Default Re: transmission problem Help! (jdmdelsol94)
time to pull it back out !
you sure the release fork is on its ball pivot point ? also can you have someone push the pedal while you verify is the slave is indeed moving/pushing the release fork.
Old Jul 4, 2007 | 09:36 AM
Default Re: transmission problem Help! (dturbocivic)
yea i feel the lever moving and dosent compress like suppose to...because u dont feel the presure from the hard presure plate you know thanx for the help man...
Old Jul 4, 2007 | 10:21 AM
Mista Bone's Avatar
D Tranny Guru
disc in backwards?
Old Jul 4, 2007 | 04:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">disc in backwards?</TD></TR></TABLE>
my thought.
or since replacement of the master, wrong freeplay on the pedal.
Old Jul 4, 2007 | 08:14 PM
Default Re: (boostedcivicsir)
yea i matched the length and all and i know that i didnt put the disk the wrong way cuz wouldnt fit as i know but im going to take it apart and pull the tranny i believe its the clutch fork not properly on the pivot ball but if anything else all help would be appreciated..
Old Jul 5, 2007 | 12:37 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (jdmdelsol94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdelsol94 &raquo;</TD></TR><TR><TD CLASS="quote">yea i matched the length and all and i know that i didnt put the disk the wrong way cuz wouldnt fit as i know but im going to take it apart and pull the tranny i believe its the clutch fork not properly on the pivot ball but if anything else all help would be appreciated..</TD></TR></TABLE>
Comma ,
Period .
Old Jul 5, 2007 | 03:21 AM
1SLaMMeDC2's Avatar
tigersball
Jul 9, 2008 09:45 PM
DB1_559
Apr 29, 2006 07:41 PM
nubs
Dec 16, 2004 03:28 AM
Rpc07
Oct 7, 2003 03:36 PM
Mr.Armani
Jun 3, 2003 08:10 PM
