vacum for itbs
Old Jun 25, 2007 | 07:25 PM
k24killer's Avatar
Default vacum for itbs
is there a proper size canister to buy or build, i did a search and did not find what i was looking for for an answer
Old Jun 26, 2007 | 12:30 AM
Richard...'s Avatar
Default Re: vacum for itbs (k24killer)
Old Jun 26, 2007 | 08:36 AM
D-Rob's Avatar
Default Re: vacum for itbs (richard7968)
I disagree with the use of GE's vacuum log with most ITB's on the market.
I ran this same log on mine for a while, and had a very erratic MAP signal. The car drove poorly, and was very hard to tune.
I made myself a canister roughly the size of your standard IM plenum, and ran my MAP signal/brakes off that.
The car drives 200% smoother now.
- Derek
Old Jun 26, 2007 | 11:36 AM
BoostedJeff's Avatar
Default Re: vacum for itbs (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">I disagree with the use of GE's vacuum log with most ITB's on the market.
- Derek</TD></TR></TABLE>
pics??
Old Jun 26, 2007 | 11:47 AM
Golden Eagle's Avatar
- Derek</TD></TR></TABLE> you must have had something hooked up wrong, they work fine on all the itb cars we run and lots of people use them for the same no problems, it is just a vacuum source
Old Jun 26, 2007 | 12:47 PM
D-Rob's Avatar
Default Re: vacum for itbs (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote"> you must have had something hooked up wrong, they work fine on all the itb cars we run and lots of people use them for the same no problems, it is just a vacuum source </TD></TR></TABLE>
Oh, I'm not trying to down-talk the product, I'm just sharing my personal experience with it.
Trust me, nothing was hooked up wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">pics??</TD></TR></TABLE>
I can.
- Derek
Old Jun 26, 2007 | 01:00 PM
I can.
- Derek</TD></TR></TABLE> its cool, i just don't see why you would have a problem when we do them all the time with no problems, its all good didn't meen to sound like i was picking on you ether just found it odd
Old Jun 26, 2007 | 01:01 PM
D-Rob's Avatar
Not sure 'why', but I just did not have good luck with it.
-Derek
Old Jun 26, 2007 | 01:03 PM
MrParks's Avatar
i personally put together 4 itb cars with golden eagle vac box, and never once had a problem. but i recommend you use a mercury stick before you start.
Old Jun 26, 2007 | 03:27 PM
.RTErnie's Avatar
Default Re: vacum for itbs (MrParks)
could be that the pressure waves from the port are very strong and cause the manifold pressure to oscillate....idk. the larger the manifold the less the pressure waves affect the signal.
Old Jun 27, 2007 | 04:11 AM
D-Rob's Avatar
Default Re: vacum for itbs (.R T E r n i e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .R T E r n i e &raquo;</TD></TR><TR><TD CLASS="quote">could be that the pressure waves from the port are very strong and cause the manifold pressure to oscillate....idk. the larger the manifold the less the pressure waves affect the signal.</TD></TR></TABLE>
My thoughts as well.
- Derek
[Ennis_D]
Jul 18, 2008 08:37 AM
Richard Noggin
Jun 13, 2006 12:57 PM
vaporboy12
Jun 1, 2006 02:56 PM
*Boostwerks*
Sep 22, 2005 09:25 AM
wildhorsesracing
Aug 24, 2004 07:42 PM
