Liberty Gear Set Reverse problem
Old Jun 12, 2007 | 11:49 AM
94turboeg's Avatar
Default Liberty Gear Set Reverse problem
Has anyone had a reverse problem with this gear sets.Mine goes in when let out clutch it pops out.The gear set was installed at Liberty by them it went into reverse about 8-10 times.Any suggestions?
Old Jun 12, 2007 | 11:53 AM
DaveF's Avatar
Default Re: Liberty Gear Set Reverse problem (94turboeg)
i suggest you call liberty, they are the manufacture of the gearset and could answer your question
Old Jun 12, 2007 | 11:56 AM
jpenman50's Avatar
You have the wrong reverse gear in the transmission.. The trans needs a spacer under the gear so it will fully engage... What is happining is the gear is only engaging a quarter of the way.. You can buy the correct spacer for the reverse gear from acura.. or build a 1/4 spacer yourself... if you continue to use that gear... The other gear is a little taller, but I have found that they also need to be shimmed as well.
Old Jun 12, 2007 | 12:16 PM
94turboeg's Avatar
Default Re: Liberty Gear Set Reverse problem (jpenman50)
THe factory reverse gear is wrong one or the liberty ?
Old Jun 12, 2007 | 01:15 PM
jpenman50's Avatar
The gear set from liberty includes, the main shaft, counter shaft, ring gear, 1-4 gears, and sliders.. The reverse gear is still oem honda
Old Jun 12, 2007 | 02:01 PM
94turboeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpenman50 &raquo;</TD></TR><TR><TD CLASS="quote">The gear set from liberty includes, the main shaft, counter shaft, ring gear, 1-4 gears, and sliders.. The reverse gear is still oem honda</TD></TR></TABLE>So how is the reverse gear the wrong one?If so why didint Liberty say it was wrongreverse gear they changed other stuff in transmission that was bad?It seems to me it is a design problem for them on counter shaft where their part meets oem reverse.
Old Jun 12, 2007 | 02:05 PM
MrParks's Avatar
jeremy, i think he was stating that there is a brass washer that goes before the gear once installed on the casing
Old Jun 12, 2007 | 02:09 PM
uglyasscivic's Avatar
Liberty does not know about the problem. Everything they build is done right. Honda makes two different reverse gears, one of them sets the gear higher and you wont have a problem. The other sets the gear lower and you will have the problem you and I have. Mine is now fixed.
Old Jun 12, 2007 | 03:39 PM
fast is fun's Avatar
Default Re: Liberty Gear Set Reverse problem (MrParks)
Use a ls or b16 reverse gear,and a gsr brass spacer/washer under it. and put a spacer under the shift rod for 5/reverse fork rod in the hole. And it will not go down like if you had
5th gear you can call me if you want 801-569-1300
paul and cj at liberty and I have talk about the problem jj and I had this problem
3 years ago.
1/2 slider is so wide the reverse gear is small
Modified by fast is fun at 5:55 PM 6/12/2007
Old Jun 12, 2007 | 05:29 PM
5thgearburnout's Avatar
Default Re: Liberty Gear Set Reverse problem (fast is fun)
So is the gsr reverse gear is the wrong one? I used a gsr gear and spacer in my trans and havent got the car running yet, is ther anyway of telling if it is right or not without the car running?
Old Jun 12, 2007 | 06:19 PM
Tyler H's Avatar
Wow, sounds like Liberty sold a few gear sets in the off season...
Old Jun 12, 2007 | 06:25 PM
Innes's Avatar
Default Re: Liberty Gear Set Reverse problem (Tyler H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H &raquo;</TD></TR><TR><TD CLASS="quote">Wow, sounds like Liberty sold a few gear sets in the off season... </TD></TR></TABLE>
haha, no ****
Old Jun 13, 2007 | 02:43 AM
94turboeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrParks &raquo;</TD></TR><TR><TD CLASS="quote">jeremy, i think he was stating that there is a brass washer that goes before the gear once installed on the casing </TD></TR></TABLE>Whats this brass washer you speak of?
TomCat39
Transmission & Drivetrain
Oct 11, 2016 02:26 PM
theEGGmonsta
Jun 1, 2010 08:24 PM
killerpenguin21
10
Jun 3, 2009 02:01 PM
