rollcage help
Old Apr 3, 2010 | 04:46 PM
extreme intent's Avatar
Default rollcage help
im upgrading to a 10 pt but im confussed about where the bars that come from main hoop down to center hump if its nhra legal to run there or do i need to put a bar at bottom of main hoop to run them?
Old Apr 3, 2010 | 04:47 PM
Default Re: rollcage help
pics of that would be a great help
Old Apr 3, 2010 | 06:08 PM
PRO1's Avatar
just run your side pillar bars all the way down of your harness bar, then a short bar in the middle of pillar bars
Old Apr 3, 2010 | 06:13 PM
22_42r_eg's Avatar
I have done them to 6x6 plates to the exhaust tunnel. Never had problems getting certified.
Old Apr 3, 2010 | 06:34 PM
narfdanarf's Avatar
I am pretty sure I read somewhere in 2010 you need to run them down to a cross bar that goes between the rocker panels.
Old Apr 3, 2010 | 07:45 PM
Mr. Em1's Avatar
you can run the two bars down from the main hoop to the center of the car but there has to be a bar that connects the main hoop from side to side and those two bars that go diagonally from the main hoop have to go onto that bar.
Old Apr 3, 2010 | 11:11 PM
can the bar go to the bottom of the main hoop or does it need to go to the rocker panels with 6x6 plates to be certified
Old Apr 4, 2010 | 12:05 AM
narfdanarf's Avatar
must go to rocker panels for 2010
Old Apr 4, 2010 | 05:52 AM
boostedcivicsir's Avatar
Mr. Badwrench
the d bars should go to the bar spanning the rocker panel. ALTHOUGH, people, including myself, have had them pass. in my case they passed original cert and re cert.
Old Apr 4, 2010 | 08:00 AM
turbotypeR@SPEC's Avatar
25 Year Member
The d bars have to go to a bar that goes from rocker to rocker in order to keep the car from crushing inward on unibody cars. Some NHRA techs aren't aware of this and let some go through anyway. Here is how I did mine:
Old Apr 4, 2010 | 08:12 AM
evilone's Avatar
some pics of mine
Da_1991
Suspension & Brakes
Apr 18, 2012 10:14 PM
SR20S13
Jan 7, 2012 11:43 AM
allmtrdc4
Mar 12, 2006 05:34 PM
94HybridEX
Apr 30, 2003 01:07 PM
seineil
Aug 27, 2002 06:51 PM
