Does ceramic coating make a big difference?
Old Apr 29, 2010 | 06:43 PM
92redhatch's Avatar
Default Does ceramic coating make a big difference?
I've been having issues with my car heating up at idle. At the track ill see temps up to 214 at idle. But after i race it goes Back down to around 208. I just added a second wastegate and sent my manifold and back housing to get ceramic coated. Will it make a big difference at idle temp wise?
Here are a couple pics of the setup
before the second wastegate
Thanks
mike
Old Apr 29, 2010 | 07:18 PM
1991civicsi's Avatar
Default Re: Does ceramic coating make a big difference?
Ceramic coating will keep underhood temp down, but your overheating issue is probably a different problem.
Old Apr 29, 2010 | 07:20 PM
90blackcrx's Avatar
Hell yes it should make a difference... no really I love to get things coated now a days, and or wrapped, or at least paint and wrap if you don't want to pay for coating. It keeps bay temperatures down so much, plus it help keeps heat in the exhaust which is a plus for performance. It just makes sense to get things coated, then again though you might also have a flow issue with air.
I recently am setting my car up and decided to paint my downpipe ( rather then coat ) because I also heat wrapped it because it sits super close to my radiator.
A picture I took from getting back from the coater today
My setup
Old Apr 30, 2010 | 02:45 AM
tepid1's Avatar
It does make a difference. I've done it since day one with my first 57trim setup. I'll ALWAYS coat my stuff now.
Old Apr 30, 2010 | 11:08 AM
92redhatch's Avatar
I can't wait to get my manifold and backhousing back so I can check my idle temps
Old Apr 30, 2010 | 11:24 AM
1992Si's Avatar
You will be very happy with the results.
Old Apr 30, 2010 | 04:14 PM
h22 civic's Avatar
inside and out !!!
Old May 1, 2010 | 08:09 AM
cfwthb_94's Avatar
Who do you guys normally use to get your stuff coated?
Old May 1, 2010 | 08:17 AM
.CUBISH.'s Avatar
might as well get the downpipe and dumps done while youre at it....
on another note...those temps seem pretty high for just idle. both of my turbo cars run around 180 deg.. even on the big end of the track
might want to look into your cooling system or motor
Old May 1, 2010 | 12:48 PM
92redhatch's Avatar
I have a stock radiator and $40 slim fan. That's probably why it's so hot. But going down the track it actually gets colder than at idle. It will drop to about 205-208
Old May 1, 2010 | 01:35 PM
.CUBISH.'s Avatar
should try to find a way to fit the stock fan with the stock radiator if possible. or get a aftermarket fan with a shroud. the thermal coating isnt going to help much with the coolant temps
Old May 1, 2010 | 01:46 PM
92redhatch's Avatar
I can definately fit a stock fan I got more then enough space. Ill try to pico one up at auto zone
Old May 1, 2010 | 01:51 PM
Honda Bull's Avatar
I only have my exhaust housing coated and it really hasn't made a difference in anything. To do manifold, housing, downpipe, etc. probably would help. But I couldn't answer you to a quantitative extent.
Old May 1, 2010 | 01:52 PM
92redhatch's Avatar
Auto zone is stupid expensive. I can't believe I threw my stock one away. Hpc if you have a stock fan for cheap let me know and I'll go pick it up
Old May 1, 2010 | 02:05 PM
.CUBISH.'s Avatar
yeah i have a couple stock ones
Old May 1, 2010 | 02:08 PM
92redhatch's Avatar
Pm me how much I'll pick it up Monday if it's cheap
Old May 1, 2010 | 02:22 PM
TDautowerkes's Avatar
Stop being a cheap bastard and get a spal fan with shroud and at least a mishimoto radiator!..
heat is a killer!
Old May 1, 2010 | 03:30 PM
92redhatch's Avatar
Damian after all the money I've spent with you guys you should just give me a free fan lol
Old May 5, 2010 | 03:15 AM
LS AzZkIkr's Avatar
Would you want to get the coating done before a retune or will it not change your tune much?
Old May 5, 2010 | 03:54 AM
92redhatch's Avatar
I don't know yet I tune my own car so if some changes are needed I'll let you know. I should get my parts back today or tomorrow.
Old May 5, 2010 | 08:25 AM
90blackcrx's Avatar
I'd say before, keeping in the heat will help performance.
LS AzZkIkr's Avatar
Please keep me posted. I would like to know if I need to hurry my re tune up or I can take
my time and do everything I need to without braking my wallet.
Old May 5, 2010 | 01:15 PM
robfrmny21's Avatar
THATS CUZ OF THE AIR FLOW THROUGH THE RAD, GET A BIGGER RADIATOR TO COOL IT DOWN AT IDLE.
YOUR IDLE TEMPS ARE RATHER HIGH
Old May 6, 2010 | 12:50 PM
92redhatch's Avatar
Old May 6, 2010 | 01:05 PM
Turbogixxer's Avatar
Looks VERY nice mike!
