need the answer once and for all!!!
Old May 1, 2010 | 01:30 PM
mattmatt57's Avatar
Default need the answer once and for all!!!
quick question guys i been looking and looking but i need an answer...
stock bottom end b16..... type r head complete....
b16 tranny clutch flywheel ect.ect.
will running open header on race day gain any hp? gain anything? i know there is more wear and tear on the motor but i only want to make 1-2 passes open header to see if my times increase.......
just wondering if anyone has a dyno comparison is running open header worth it! thanks! or even no muffler and just run axle back
Old May 1, 2010 | 01:39 PM
hondamn1320's Avatar
Default Re: need the answer once and for all!!!
Try it and find out.
Old May 1, 2010 | 01:46 PM
boostedcivicsir's Avatar
Mr. Badwrench
w/o a tune, you are only dropping weight (if you remove the exhaust completely)
you are opening it up way more than the ecm is used to. if you have the means to tune it, you will see a difference. allbeit a small one, but it will be different. audibly? it will be fast as hell.
Old May 1, 2010 | 03:13 PM
mattmatt57's Avatar
cool thanks. and i wasnt planning on dropping the whole exhaust just taking the test pipe out and running it like that. the car is tuned on hondata s200 unit. it was tuned for full exhaust. but it isnt a stock ecu. i will try next time. what about no muffler?
Old May 1, 2010 | 03:33 PM
Mr. Badwrench
i dont think it will make that much of a difference. but you will tell on a dyno.
Old May 1, 2010 | 06:09 PM
mattmatt57's Avatar
is it safe taking it 9000rpm open header?
and i know u said i wont feel it unless its tuned but it is dyno tunned so hopefully i gain 2-5whp open header i just need 1.5mph more to reach my goal besides the hytech replica i put on. thanks for the replies fellas
Old May 2, 2010 | 12:51 AM
Mr. Em1's Avatar
sounds like your ready to run 9's dude. SICK
Old May 2, 2010 | 02:39 AM
mattmatt57's Avatar
just messing around with it all motor till it goes back to boost.....
dont have anything good to say gtfo! just simply asking if u can benefit from it at all
Old May 2, 2010 | 06:28 AM
Mr. Badwrench
2 to 5 whp you arent going to get from that and to = 1-1.5mph may be a streatch.
Old May 2, 2010 | 02:01 PM
joe111599's Avatar
And whats your goal???
Old May 3, 2010 | 09:20 AM
tony tone's Avatar
GDD Moderator
if your motor isn't built for it, why would you want to run it to 9000?
2whp is certainly a stretch let alone 5.
5thgen_er
Oct 4, 2009 07:33 PM
1sikhatch
Aug 9, 2009 08:50 PM
umair
20
May 13, 2009 07:58 PM
94whtgsr
Sep 14, 2004 08:16 PM
topher
Mar 31, 2002 06:00 PM
