Source for Parts
Old Apr 30, 2010 | 06:00 AM
Turbo Wax's Avatar
Default Source for Parts
Where can I purchase the protection pieces that are used when you get the exhaust through the hood or front fender? I don't even know what they are called?
Old Apr 30, 2010 | 06:06 AM
turbodano's Avatar
Default Re: Source for Parts
http://autofabcart.net/stainlessfend...eadertrim.aspx
Old Apr 30, 2010 | 06:43 AM
1992Si's Avatar
Once again Dan proves why he is the man.
Old Apr 30, 2010 | 06:49 AM
tuhboek's Avatar
What about hood exit from an up pipe? Gotta make ur own im guessing? They are more oval shape rather than just a circle...
Old Apr 30, 2010 | 06:52 AM
99blackdc2's Avatar
..... http://www.xtremeoutlaw.com/
Old Apr 30, 2010 | 07:07 AM
tuhboek's Avatar
Nice ^^
Old Apr 30, 2010 | 07:26 AM
tony1's Avatar
Something like that is VERY easy to build.
Old Apr 30, 2010 | 07:35 AM
rota92
Guest
Posts: n/a
You should make pourous T1 logo's that are 4" in the center so people can rock those, maybe the flames would be in the shape of the T1 lol
Old Apr 30, 2010 | 08:09 AM
tuhboek's Avatar
looks easy enough..but lets say everything is mocked up, what is the best way to determine where to cut the exit hole in the hood? I mean you cant see where to start a cut when the hood is closed. Any suggestion?
Old Apr 30, 2010 | 08:14 AM
tony1's Avatar
Get it close, but leave it long on length. Once you can get the hood closer to closed you can figure out where it's going to come through. The actual hole in the hood will be bigger than the opening in the trim ring, the trim ring will cover up the bottom hole in the hood being too big. Once the tube is through the hood, make the trim ring from posterboard until you're happy with it and then make it out of whatever material you want to use.
Old Apr 30, 2010 | 08:38 AM
tuhboek's Avatar
Cool thanks...one more thing...U think a dremel would be the most precise tool to cut with on say a CF hood to reduce chance of spider web cracks? Also would rivets work well to hold the trim ring in place?
Old Apr 30, 2010 | 08:40 AM
MazworxRacing's Avatar
Looking for something like this?
Old Apr 30, 2010 | 09:48 AM
Turbo Wax's Avatar
Thanks turbodano
Mazworx
I'm actually looking for that one or the one that Tony has for the hood.
What's the correct name for those things?
Old Apr 30, 2010 | 09:52 AM
rota92
Guest
Posts: n/a
Trim rings is what most people call them I think.
Tony can make you one I'm sure, send him a template and cash lol
Old Apr 30, 2010 | 04:14 PM
90blackcrx's Avatar
What are you guys using to cut carbon fiber ? Hole saw , body saw, cut off wheel ?
I thought it was because of his large hands.
Old Apr 30, 2010 | 05:24 PM
DSRxCandyh2bEG's Avatar
You can use a laser pointing device mounted to a wall or something. Point it in the center of your downpipe/dumptube/etc and close the hood. Once your hood is closed, the laser pointer will still be pointing at the spot on your hood that needs to be cut... Probably the most accurate/precise way IMHO... It works well for hood pins etc too...
The laser pointer I have in mind is probably sold at home depot or Lowe's. I have seen them used for hanging up pictures and other stuff as well...
Old Apr 30, 2010 | 07:23 PM
ALL IMPORT's Avatar
^^^ good idea. smart guy
Originally Posted by 99blackdc2
they sell the same thing jsut almost twice the price.
Dan is the man!!!!!!!!
Old May 1, 2010 | 03:48 AM
Turbo Wax's Avatar
Any other sources? anyone from the forum sells them? I prefer to support our own guys
Old May 1, 2010 | 04:13 AM
AllMoToRB18c's Avatar
I just did what tony said. I made the templet out of poster board. This way you can make it any shape you want. Then trace it out on sheet metal and cut it out then rivet it on. Was pretty easy actually
Old May 1, 2010 | 04:22 AM
Turbo Wax's Avatar
cool idea, any more photos of the car?
Old May 1, 2010 | 07:46 AM
Mikey3000's Avatar
wow i love this idea! it could be applied to a lot of things. Thanks
runderwo
Nov 14, 2010 05:02 PM
Black Diamond
Paint and Body
12
May 16, 2009 06:17 AM
trixr
10
Jul 10, 2008 01:19 PM
Fo-Do Fanatic
Apr 16, 2008 02:56 AM
Qikcivic
15
Feb 4, 2004 06:12 PM
