roll cage question
Old Apr 12, 2010 | 05:26 PM
blackeg's Avatar
Default roll cage question
i have a prebent cage for my 95 civic and the main hoop is very wide at the base. the outside of the piping is right up against the sill and i wont be able to get around it with the welder. can i weld it to the floor(well the 1/8" 6x6 plate on the floor) then run the bead up the side of the bar where it meets the door sill and then back down the other side? i just dont want to go through the work if it will not pass inspection.
Old Apr 13, 2010 | 01:23 PM
blackeg's Avatar
Default Re: roll cage question
or can i bend the plate and weld half of it to the sill and the other half to the floor, then weld the cage to that?
Old Apr 13, 2010 | 02:51 PM
1992Si's Avatar
Where in NY are you ? you should contact someone like Morgan at http://www.synapseturbo.com/
Or miller at http://www.nrgtechracing.com/
Old Apr 13, 2010 | 04:10 PM
joe95b18coupe's Avatar
Why not sandwich plate the 6x6 w/one under the car and bolt the main hoop in and weld all the other mounting points, just my 1 cent as I am a broke ****
gsp ej1-em1
Dec 5, 2006 08:40 AM
blueintegra90
Jan 5, 2006 08:58 PM
Viorent Grip! EG
Sep 10, 2003 02:06 AM
275Performance
May 1, 2003 02:43 PM
Want2race
Mar 8, 2003 11:18 AM
