b16 boost build
Old Mar 31, 2010 | 05:40 PM
1990hondacrx's Avatar
Default b16 boost build
Hi Honda tech this is going to be my first engine build and I am wanting to do it right the first time and not be driving around a ticking time bomb.
Its going to be a weekend warrior and a Sunday drive type car and if needed every day driver. To be safe to run from low boost 11psi to high boost of 24psi
I'm shooting for a 300 too 550 hp range running the car on E85
I have some questions of what has worked for you guys the best on builds parts wise.
im starting off with a b16a obd0 engine 160 base model
plans are
b16a
bored .020 Twenty thousands of an inch for good clean start
decked
hot tanked
Micro polished Crank
Having the pistons Coated by http://www.swaintech.com/
and if its a good idea to have the bearings coated also
CP Pistons and Eagle H Beam Rods
Cp 9.0:1 Part# SC7001
Eagle Part# CRS5290H3D
ARP
Head Studs
Part# 208-4601
ARP
Rod Bolts
Part# 208-6401
Head Gasket
Oem 3 Layer head gasket
Bearings???
Oem Honda
ACL Race Bearing
Oil Pump?
Type R
Gsr
b16
Water Pump
Type R
Gsr
b16
Timing Belt
B16 Oem
The Head is B16a obd0 Head Stock with Ctr valve Train and new Lma's
already have
walbro 255 fuel pump
precision 880cc low impedance injectors
obd1 AEM Engine Management
Things i need info on
what year, make, and model to get parts numbers from for; like year vehicle Acura or Honda delsol
water pump
oil pump
timing belt
head gasket
and bearings
or provide me with a part number. I thank you guys for your help
just wanna make sure i get everything right before I order it.
Also What do you guys think about the b16 oil squirter's? keep them or buy the block offs?
Last edited by 1990hondacrx; Apr 1, 2010 at 02:54 AM. Reason: things in there that shouldnt be
Old Apr 1, 2010 | 02:54 AM
Default Re: b16 boost build
bump
1990hondacrx
Apr 1, 2010 02:54 AM
1990hondacrx
Mar 31, 2010 04:55 PM
NvUsEG6
Feb 5, 2009 05:02 PM
Powelly
Sep 26, 2007 04:22 PM
adubaz7
Sep 21, 2007 02:15 PM
