h2b cam issue.
Old Apr 22, 2010 | 11:51 PM
hondah2b21's Avatar
Default h22 cam issue.
today i had a good friend look over my valve adjustment. while doing so he noticed something that was very displeasing. in my aftermarket cams (not mentioning no names) there was a very deep grove. now not to mention the car so just ran on idle due to it not being tuned. dont get tuned cuz we had to finish up the dual pumps. now i have a bigger headache in my hand.
so i was wondering does anyone know what could have cause this.
its a fully built h22 head using all ferrea valvetrain.
Old Apr 23, 2010 | 10:41 AM
zakura R's Avatar
Default Re: h2b cam issue.
Did u got those cams new when u build the head ??? And who install them
Old Apr 23, 2010 | 11:29 AM
2fastGSR's Avatar
King of the One Liners
What kind of oil were you using? Have you used these rockers before? I have seen H22 rockers wear irregularly quite a few times.
Is it on all of the lobes or just a few?
Old Apr 23, 2010 | 12:26 PM
pellis90's Avatar
Pic's ?
Old Apr 23, 2010 | 12:36 PM
TurboChurch's Avatar
Dirt on the rocker? Was the groove on the timing belt side? If so, how tight did you make the timing belt? Did you have oil pressure to the engine and verify on a gauge?
Just realized you didnt specify where the groove is... Is it in the cam journal or on a lobe? Lots of things cause valve train issues, be more specific!
Old Apr 23, 2010 | 08:55 PM
hondah2b21's Avatar
ok. the cams were brand new. it had good oil pressure. its on a aem oil pressure guage. the timing belt wasnt crazy tight. it was stock rockers on a fresh fully built head. oil was castrol oil. the motor wasnt rev'd mainly on idle due to it not being tuned. the grove was on the exhaust cam lobe by the second piston.
Old Apr 23, 2010 | 08:59 PM
nsxmatt's Avatar
Might be better to title the thread H22 cam issue instead of h2b. Since the trans has nothing at all to do with a cam problem.
Old Apr 24, 2010 | 01:01 AM
hondah2b21's Avatar
h22 cam issued updated.
Old Apr 24, 2010 | 01:04 AM
king06's Avatar
Post pics and call the manufacturer, maybe bad batch?
Old Apr 24, 2010 | 07:39 AM
KStuned's Avatar
Is it a groove or is the cam missing material where it contacts the rocker? Is it just on one lobe? Pics could help.
Old Apr 24, 2010 | 09:05 AM
hondah2b21's Avatar
its just the one lobe but the others look like it could have had problems in the future. it wasnt there when it was installed. ill post pics soon.
Old Apr 24, 2010 | 09:33 AM
hondah2b21's Avatar
this is wat it looks like. its at least 1/8 of a grove on the exhaust (2 piston) lobe.
Old Apr 24, 2010 | 10:00 AM
pellis90's Avatar
Do the other have wear, scarring ? what makes you think the other will have problems in the future ?
Old Apr 24, 2010 | 09:42 PM
king06's Avatar
You got a bad batch.
Old Apr 24, 2010 | 10:40 PM
hondah2b21's Avatar
the others had minor markings on them thats why i figured in the future they might have the same issue.
king06: im thinking its a bad batch and the company take care of the problem.
but the questin is if its a bad batch why do i get stuck with the bill on labor and if any other items get damage due to the defect of the product.
Old Apr 25, 2010 | 01:40 PM
h22 civic's Avatar
what cam breakin procedure did you follow??what lube did ya use???
mills7x
Jan 26, 2013 09:56 PM
K7-1Ktrevor
12
Jul 21, 2010 09:41 AM
eg_h22
Jul 21, 2009 12:24 AM
carlitosway12345678
Oct 3, 2008 09:55 PM
boostedb20z
Apr 7, 2008 10:58 AM
