Name That LSD
Old Apr 24, 2010 | 07:25 AM
DOHCarp's Avatar
Icon3 Name That LSD
I just put an LSD i had laying around in an old YS1 cable Trans into a Hydro GSR trans. The problem is the VSS gear works for about 10 minutes then stops. Every time i pull the VSS out it is ground up and destroyed (see Pic below)
Im wondering if I need a special VSS gear for this LSD. I checked all the spacing and it goes in fine but I've had it apart 3 times and destroyed 4 VSS gears. So if anyone can help me out with what Brand LSD or why im having this problem it would be much appreciated. Thanks
Old Apr 24, 2010 | 05:46 PM
SPOOLINmatt's Avatar
Default Re: Name That LSD
wow is the speed ring gear seated nice and flat? Maybe you could try switching to the sensor with a metal gear on it. I've had no problems using the plastic one....and have had it on 2 or 3 different brands of Diffs.
Old Apr 24, 2010 | 10:32 PM
MFactory's Avatar
It's an oem viscous lsd (jdm factory option).
Old Apr 25, 2010 | 10:53 AM
DOHCarp's Avatar
Thanks MFactory. Thats kinda what i was thinking, but I really don't know much about LSD's
That being solved im guessing i don't need a special VSS gear or is the JDM VSS any diffrent? Or is their another reason the VSS gear is being destroyed. THe ring gear on the LSD is seated perfect and the spacing of the diff is set to what it was in the previous tranny.
Any ideas? Thanks.
Old Oct 21, 2010 | 03:48 PM
jdmdb8r's Avatar
oem jdm gsr lsd.it was a special order option....
Old Oct 21, 2010 | 04:12 PM
bosted coupe's Avatar
It's jdm gsr LSD
Old Oct 21, 2010 | 04:30 PM
Honda Bull's Avatar
Honda OEM hydro GSR LSD. 14-bolt 4.400 FD ring gear.
Old Oct 21, 2010 | 06:32 PM
JJsMotorsports's Avatar
X2
Did you see if you have your clearance right when you install this lsd into the bellhousing of tranny? From looking at pics i could see lsd has been rubbing in bellhousing case internally.
I'd shim it and test it again with metal Vss. Good luck.......
I'm not a tranny expert, just stating my opinion from experiance.
Old Oct 21, 2010 | 06:46 PM
looks like to me the bearings are on no shims put some shims
Old Oct 21, 2010 | 06:52 PM
Zer0_SpeedWorks's Avatar
use metal gear vss from type r etc...
also happened to me, plastic wont work...
Old Oct 21, 2010 | 08:59 PM
Mr. Em1's Avatar
they have plastic gears on the vss's?
trincivic
Transmission & Drivetrain
Aug 6, 2011 04:59 PM
DOHCarp
Apr 25, 2010 12:05 PM
zimmy709
Jun 25, 2008 04:06 PM
drift2004
Dec 17, 2007 10:46 AM
