full throttle shift
Old Apr 1, 2004 | 03:14 PM
CaptainMorgan's Avatar
Default full throttle shift
how many of you guys do a full throttle shift (not letting off the gas at all)? I have two questions about it.
1. What stops the tranny from grinding?
2. How much times does it take off?
I heard this is really good, because it keeps the turbo spooled. Also i heard its better to do it with a MSD 2 step. I have hondata where the fuel is set to cut off at 7200, but i was told this is not as good as the msd.
Old Apr 1, 2004 | 03:50 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: full throttle shift (CaptainMorgan)
that is called "power shifting and yes i do it, if you are quick enough there will be no grind and it can take off up to a tenth of a sec per shift
Old Apr 1, 2004 | 04:03 PM
kwik93si's Avatar
Default Re: full throttle shift (HOOKUPS)
power shifting is the way to go...you've just got to practise a lot to get good at it...for some reason when you power shift it lowers your et and mph...regular shifting gives slower et but more mph...this is just what i've experienced...
Old Apr 1, 2004 | 08:30 PM
Group Tenacity's Avatar
Power shifting definately works.. only problem is i blew a few trannys learning how to do it properly.. my current tranny has lasted me over a year so i think i got it down pretty good...
Old Apr 1, 2004 | 08:37 PM
Jokerluv's Avatar
done it before
Old Apr 1, 2004 | 08:54 PM
Default Re: (Jokerluv)
Any pointers. I know its really basic but anything i should watch or listen when i do this. ALso do you guys ran the MSD 2 step or can you do this on a reg car.
Old Apr 1, 2004 | 10:08 PM
racerx7's Avatar
Default Re: (CaptainMorgan)
I always shift full throttle. It just takes a lot of practice. it helps if you practice by just shifting fast. If you screw up you can over rev your engine or trash your tranny so be careful!!!
Old Apr 1, 2004 | 10:36 PM
kwik93si's Avatar
Default Re: (racerx7)
when i was learning i would practise at a lower rpm...so that i had room for error.
also instead of just pushing the clutch in...kick it hard because you're going to be shifting very fast...it's not pretty when the clutch doesn't engage in time...i've got an msd 2step so if i ever miss, then i've got that rev limiter to protect the engine.
good luck man
Old Apr 2, 2004 | 08:33 AM
DYNO-PRO
Default Re: (kwik93si)
yes a i agree practice on the street just normal driving but when you shift leave the gas pedal down, kick the clutch pedal and at the same time SLAM the next gear you will get it, however you need to have a good clutch in the car or you will fry it
Old Apr 2, 2004 | 03:26 PM
rico91stang's Avatar
I ask Twitter, not xtrac1
Community Builder
Community Influencer
Default Re: (HOOKUPS)
I can't full throttle shift in my car.
Old Apr 3, 2004 | 12:27 AM
nevin's Avatar
yeah it takes alot of practice to get it consistantly. my only tip is to scoot the seat forward so you make sure to press the clutch down enough not to grind gears.
Old Apr 3, 2004 | 01:40 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (nevin)
Who has the audio clip of mike laskey doing full throttle shifts?
Old Apr 3, 2004 | 02:37 AM
NJIN BUILDR's Avatar
Default Re: (Arturbo)
Hondata has a short clip on there website.
Glenn
Old Apr 3, 2004 | 03:55 PM
slowsi00's Avatar
my times suck
and it becasue i dont power shift.
however this is my only trans i have ever had after 3 seasons(nitrous,turbo,turbo) of hard core banging gear shifting regular but fast.
i expect to blow it to the moon this year tho.
Old Apr 3, 2004 | 09:43 PM
flatty's Avatar
you said you hondata cut fuel at 7500 )it's better to us msd msd cuts spark not fuel so you won't have to worry about lienin out msd is a great tool for the dragster
Old Apr 3, 2004 | 09:50 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (flatty311)
somebody posted a sound clip of Mike Laskey but I dont know who it was. Who has that clip? You can hear the full-throttle shifts he does.
art
Old Apr 3, 2004 | 11:07 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatty311 &raquo;</TD></TR><TR><TD CLASS="quote">you said you hondata cut fuel at 7500 )it's better to us msd msd cuts spark not fuel so you won't have to worry about lienin out msd is a great tool for the dragster</TD></TR></TABLE>
Its only for a split second so it shouldn't cause any problems at all. Its the same exact thing that the rev limiter uses. Obviously if it was so horrible, Honda wouldn't have used a fuel cut. Don't sit there and ride on it for 10 minutes and you should be ok.
Old Apr 4, 2004 | 07:53 AM
alpha's Avatar
Do you have the older Hondata, s100 or s200?
http://hondata.com/media/fullthrottleshift.mov
http://hondata.com/media/fullthrottlefeet.mov
Old Apr 4, 2004 | 03:39 PM
bigblockEG's Avatar
Default Re: full throttle shift (0x64)
Dont be scared of the rev limiter but try to shift before you hit the limiter, it will throw you off..
Old Apr 4, 2004 | 05:54 PM
drvfast's Avatar
i do it all the time, it helps.
Old Apr 4, 2004 | 07:20 PM
Community Builder
Default Re: (nevin)
IF I don't get of the gas in between shifts and am on street tires, I just destroy all resemblance of traction.
Old Apr 6, 2004 | 12:07 AM
Speedworks801's Avatar
IT NEVER REALLY WORKED FOR ME!
Old Apr 6, 2004 | 12:15 AM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">somebody posted a sound clip of Mike Laskey but I dont know who it was. Who has that clip? You can hear the full-throttle shifts he does.
art</TD></TR></TABLE>
Here is the sound clip if you scroll mid page
https://honda-tech.com/zerothread?id=813863
Old Apr 6, 2004 | 12:19 AM
SKDRCR's Avatar
here's a clip off hondata.com
http://www.hondata.com/media/fullthrottlefeet.mov
g0tgot
Jan 23, 2011 05:08 PM
ej6.sean
Nov 26, 2007 05:40 AM
mike93eh2
Aug 30, 2007 08:17 PM
EDVxRICHARD
10
Jan 22, 2005 06:23 PM
bs2k
Honda S2000
Dec 13, 2004 12:30 PM
