4.73 final drive and boost ???
Old Apr 12, 2004 | 03:46 PM
Big O's Avatar
Default 4.73 final drive and boost ???
Is this a realistic setup? 4.73 and boost anywhere from 4psi to 12 psi? I'm using a D series motor. I wanna do this on a 4dr 88-91 civic with lsd and use this as a street/drag setup. Is this too radical a final drive for boost? I searched the final drive and boost but all I found was hydraulic tranny tegs or swapped civics with b series and hydraulic trannys. Didn't yeild definitive results. Anyone here doin this setup? thx
Old Apr 12, 2004 | 04:30 PM
Jared's Avatar
Default Re: 4.73 final drive and boost ??? (BIG O)
will be pretty crazy, lots of tire smoking action, but it might be nice with a set of 25 or 26" slicks. what kind of power do you plan on making?
Old Apr 12, 2004 | 04:49 PM
Big O's Avatar
Default Re: 4.73 final drive and boost ??? (Jared)
I wanna shoot for 200-225? I'm thinkin of a t3 with .42 .48 or a rhb5, I wanna test both. I have a 4.25 final drive l3 Si tranny but since I'm doin the lsd I thought I'd do a 4.73 final drive.
Seems like the gsrs have success with these. people still boost em.
What about on street tires? Or am I crazy?
Old Apr 12, 2004 | 05:06 PM
MrParks's Avatar
we run a 478 final drive in our car 11.1 at 127 in a lsvtec turbo stock motor
Old Apr 12, 2004 | 06:03 PM
V-SPEC 1's Avatar
Default Re: 4.73 final drive and boost ??? (HARTENG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HARTENG &raquo;</TD></TR><TR><TD CLASS="quote">we run a 478 final drive in our car 11.1 at 127 in a lsvtec turbo stock motor</TD></TR></TABLE>
what size slicks did u use?
Old Apr 12, 2004 | 08:15 PM
Akiraboy's Avatar
wow, what weight and hp do you run @ with that 4.78 final drive?
Old Apr 13, 2004 | 01:48 PM
MrParks's Avatar
Default Re: (akiraboy)
ls vtec turbo w/ sparks turbo kit 24.5x8x13 mt slicks and ctr trans note the car was going into 5th for a good second oh yeah the car wiegh in at a hefty 2420lbs stock trim street car full glass nothing cut plus a roll cage the car is capable for high tens but the car would not hook for **** at cmi....
p.s got the in car video to post still but here is the car at the street rtaces in the socal valley herehttp://teamstealthonline.com/vids.html
scoll down to turbo gsr they didnt know it was a ls v vs a blown mustang gt not a cobra,note the cobra was a low low 11 car this is at a street not thack so we didnt hook as hard as we should of just watch its cool vid also note we are not alfiliated with team stealth in any way shape or form they just got us on video
Modified by HARTENG at 3:05 PM 4/13/2004
Old Apr 13, 2004 | 03:14 PM
Jared's Avatar
Default Re: (HARTENG)
you'll pick up time by NOT going into 5th through the traps. pick your rev limiter, gearing, and tires to accomplish that.
Old Apr 13, 2004 | 06:00 PM
prestonpark's Avatar
Default Re: (Jared)
harteng
i saw u at cmi im wondering wat rpm u shift at
wat kind of power u making witht that sleeper teg and what u suspension setup
Old Apr 13, 2004 | 11:48 PM
MrParks's Avatar
Default Re: (Jared)
yes we know the stats the car should have all the way down to the nutz bro but thanks for the info jared people need to know this stuff on this site
Old Apr 13, 2004 | 11:51 PM
MrParks's Avatar
Default Re: (civic2003)
8000rpm the motor will go higher in shift points but remember it is STOCK NO SPRING RET COMBO NO PISTONS,RODS,CAMS, S T O C K BLOCK GUARD AND HEAD STUDS THATS IT WHAT YOU SEE IS WHAT YOU GET TYPE OF DEAL
Old Apr 14, 2004 | 12:36 AM
simple4012's Avatar
New User
i would definately do it
Old Apr 15, 2004 | 12:26 PM
Big O's Avatar
1 vote 4 yes, 4.73 in my civic, coo coo
Old Apr 18, 2004 | 10:05 PM
Default Re: (BIG O)
i just pic up one of this feel like u fhying threw geears and im allso boosted jrsc
MOVE OVER
Sep 3, 2006 05:30 PM
Big O
Apr 12, 2004 08:08 PM
Big O
Apr 12, 2004 04:43 PM
Big O
Apr 12, 2004 04:16 PM
