long wheel studs
Old Apr 16, 2004 | 08:47 PM
R THIS's Avatar
Default long wheel studs
are long wheel studs needed when using weld magnum import rims?? or will stock wheel studs be long enough??
Old Apr 17, 2004 | 12:17 AM
HYBRID_H@TCH's Avatar
Default Re: long wheel studs (R THIS)
for welds you need longer studs.
Old Apr 17, 2004 | 12:32 AM
G-money's Avatar
Default Re: long wheel studs (99Hybrid_Hatch)
thinkyo hve to have them after certain times also
Old Apr 17, 2004 | 04:03 AM
R THIS's Avatar
Default Re: long wheel studs (All MTR TODA HATCH)
ok thanx guys, thats all i needed to know
i didnt want to try to put my rims on, then realize i was 2 weeks away, by not having long enough wheel studs
thanx guys..
Old Apr 17, 2004 | 05:43 AM
GSRswapandslow.
Guest
Posts: n/a
i have magnum's....and they're on my car wiht OE wheel studs..........
i haven't run it yet...but they go on and seem to be fine...there's a decent amount ot threads sticking out
Old Apr 17, 2004 | 12:54 PM
badCRX's Avatar
New User
Default Re: (Ej6andslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6andslow &raquo;</TD></TR><TR><TD CLASS="quote">i have magnum's....and they're on my car wiht OE wheel studs..........
They are fine with stock wheel studs, however rules require extended studs at actual events. I just put my extended ones on this morning.
Old Apr 18, 2004 | 02:59 AM
GSRswapandslow.
Guest
Posts: n/a
i thought the rule was just about how much of the stud actually screwed into the lugnut itself?
Old Apr 18, 2004 | 06:48 AM
1 2 NV's Avatar
it is, the rules say that if u have a 7/16s stud, the lug nut has to b engaged on the stud 7/16ths of an inch. same with 1/2 studs, as the stud size goes up the engagement goes up. it has a diagram in the rule book in section 16 i believe. extended wheel studs are for 11.99 and faster cars.
Old Apr 18, 2004 | 07:00 AM
GSRswapandslow.
Guest
Posts: n/a
so no matter what...if you run 11.99...you HAVE TO HAVE long wheel studs??
Old Apr 20, 2004 | 07:03 PM
R THIS's Avatar
for 11.99 do you need front and REAR wheel studs?? or just on the power wheels??
also, does anyone know if they can be installed on a dc2 integra (4 bolt) without removing the hub??
Old Apr 20, 2004 | 07:05 PM
1 2 NV's Avatar
Default Re: (R THIS)
technically according to tom a NHRA tech official they can enforce the rear extended wheel stud rule but most do not because they arent on the drive wheels. i dont have extended studs in the rear and ive been to 2 tech sessions so far this yr and had no issues.
gakkuken
21
Jan 10, 2005 02:28 PM
BoOsTiN Dc2
Aug 31, 2004 02:45 PM
GreenR
Sep 12, 2003 01:49 PM
